Ever opened a topic, read the first post, and realized you don’t need to read the rest? Then find you have to scroll through all the posts to reach the suggested topics at the bottom? We have too. Now you can use the keyboard shortcut of g followed by s to load the first suggested topic from anywhere in the current topic.
Display report description when hovering on activity metrics
We now display each report’s description when hovering to make it easier for admins to know what each statistic details, without the need to open the full report.
New API to register topic footer buttons
We’ve simplified the process of adding buttons to the topic footer. Previously, buttons added to desktop used a different process than mobile, and this complicated plugins that needed to add such buttons. The API is now unified and simpler to use - plus is backwards compatible so existing plugins will not break with this change. We do encourage plugin authors to update their plugins to take advantage of the new system.
2.2.0 bug and UX fixes
This release also includes a number of small bug and UX fixes from our 2.2.0/2.3.0.beta1 release last week. Sites on all branches, stable, beta, and tests-passed are encouraged to update to resolve these issues, including:
checkboxes were too close to other inputs
minor button icon color fixes
in:title search filter should work irrespective of order
But wait, there’s more! We do our best to highlight new features and changes for you, but there’s always too many changes to detail. For a full list of new features, bug fixes, UX improvements, and more, be sure to review the Additional Features and Fixes listed below.
Security Updates
This beta includes 1 security fix for issues reported by our community and HackerOne.
Escape HTML in dashboard report tables
Plugin improvements
Code Review
Uses new topic footer button API
Bug fixes
Discourse Auth
Remove deprecated enabled_setting
Policy
Bug fix
Akismet
Ember 3 support
Intercom
Use API method to get current user object
OAuth2 Basic
Download avatar for new users
Previously avatars were only loaded on subsequent logins
