Obrigado pela sua resposta, atualizei para a versão 3.1.2, mas a página recebida no navegador está em branco. Uma observação, está instalado sobre o kubernetes. Aqui está o log:
discourse 14:24:20.30 INFO ==> ** Starting Discourse **
=============== Phusion Passenger(R) Standalone web server started ===============
PID file: /opt/bitnami/discourse/passenger.8080.pid
Log file: /opt/bitnami/discourse/log/passenger.8080.log
Environment: production
Accessible via: http://0.0.0.0:8080/
You can stop Phusion Passenger(R) Standalone by pressing Ctrl-C.
Problems? Check https://www.phusionpassenger.com/library/admin/standalone/troubleshooting/
[ N 2023-10-19 14:24:23.0045 875/T5 age/Cor/SecurityUpdateChecker.h:519 ]: Security update check: no update found (next check in 24 hours)
Started HEAD "/" for 127.0.0.1 at 2023-10-19 14:24:29 +0000
Processing by ListController#latest as HTML
Rendered exceptions/not_found.html.erb within layouts/no_ember (Duration: 182.8ms | Allocations: 94576)
Rendered layout layouts/no_ember.html.erb (Duration: 313.7ms | Allocations: 150094)
Rendered html template (Duration: 0.0ms | Allocations: 7)
Completed 403 Forbidden in 462ms (Views: 0.7ms | ActiveRecord: 0.0ms | Allocations: 229600)
Started GET "/" for 10.2.2.0 at 2023-10-19 14:40:12 +0000
Rendered list/list.erb within layouts/application (Duration: 14.6ms | Allocations: 12112)
Rendered layout layouts/application.html.erb (Duration: 194.1ms | Allocations: 93857)
Completed 200 OK in 730ms (Views: 196.6ms | ActiveRecord: 0.0ms | Allocations: 288887)
Started GET "/extra-locales/overrides?v=284ac3c8dead8b93a53206ee318c7b3c" for 10.2.2.0 at 2023-10-19 14:40:13 +0000
Processing by ExtraLocalesController#show as */*
Parameters: {"v"=>"284ac3c8dead8b93a53206ee318c7b3c", "bundle"=>"overrides"}
Rendered text template (Duration: 0.0ms | Allocations: 1)
Completed 200 OK in 17ms (Views: 1.7ms | ActiveRecord: 0.0ms | Allocations: 2330)
[ N 2023-10-19 14:52:13.8628 875/T4 age/Cor/CoreMain.cpp:1146 ]: Checking whether to disconnect long-running connections for process 1410, application /opt/bitnami/discourse (production)
Started GET "/admin" for 10.2.2.0 at 2023-10-19 14:53:21 +0000
Processing by Admin::AdminController#index as HTML
Rendered default/empty.html.erb within layouts/application (Duration: 0.4ms | Allocations: 177)
Rendered layout layouts/application.html.erb (Duration: 479.1ms | Allocations: 182114)
Completed 200 OK in 934ms (Views: 481.4ms | ActiveRecord: 0.0ms | Allocations: 349246)
Started GET "/admin" for 10.2.3.0 at 2023-10-19 14:54:02 +0000
Rendered default/empty.html.erb within layouts/application (Duration: 0.0ms | Allocations: 11)
Rendered layout layouts/application.html.erb (Duration: 11.3ms | Allocations: 4650)
Completed 200 OK in 109ms (Views: 12.1ms | ActiveRecord: 0.0ms | Allocations: 19340)
Started GET "/extra-locales/wizard?v=c155b44f23dcee8a7513016ec793d055" for 10.2.3.0 at 2023-10-19 14:54:03 +0000
Parameters: {"v"=>"c155b44f23dcee8a7513016ec793d055", "bundle"=>"wizard"}
Started GET "/extra-locales/admin?v=a43add616a42c5cead63cdd53b0dda4a" for 10.2.3.0 at 2023-10-19 14:54:03 +0000
Parameters: {"v"=>"a43add616a42c5cead63cdd53b0dda4a", "bundle"=>"admin"}
Completed 200 OK in 173ms (Views: 3.3ms | ActiveRecord: 0.0ms | Allocations: 12837)
Parece que o plugin discourse-local-dates foi o culpado. Assim que o desativei, tudo começou a funcionar. Terei que ver como posso recolocar este plugin.
Francamente, estou um pouco perdido. Não sei o que aconteceu, realizei uma atualização com o kubectl. A atualização teve que usar uma versão mais antiga do postgres (por padrão, a 16ª é instalada com o último chart, o que não é bom para o discourse 3.1.2). Nenhum erro, mas aquela página em branco, e depois que movi o discourse-local-dates tudo correu bem, e não houve mais erros no console do navegador.
