Discourse AI bug?
昊毅_周 reports a bug in Discourse AI translations where system-created category description posts, even when written in Simplified Chinese, are incorrectly detected as English (en) and thus not translated properly. nat explains that the AI language detection is flawed in this case, possibly due to the category being created before the site language was set to Chinese. 昊毅_周 confirms the issue persists even with a newly created category, where the post is still detected as English despite containing Chinese text. nat suggests running a data explorer query to diagnose the LLM’s detection output and proposes adjusting the prompts or using a different model like qwen. 昊毅_周 concludes that the issue is not critical and has not been resolved, but it does not significantly impact functionality.
I’m encountering some bugs while using Discourse AI. Here’s the situation:
First, let’s look at a correct post to demonstrate that my configuration is not the issue and everything is working as I intended.
My site’s base language is Simplified Chinese, and there are 9 other languages available.
This “New post test 0 translation” post is normal.
However, some individual posts are experiencing issues. For example:
This “About ‘Image Library’ category” post. The original post was published in Simplified Chinese (it was automatically published when the category was created).
But in the translation results, the original Simplified Chinese has been translated into “zh_CN” again, instead of being translated into English.
When I tried to manually add the English translation using the red globe icon, something strange
In the dropdown list, I am unable to add a separate translation for English.
However, in my global settings, English (US) has already been added correctly.
I have disabled the CDN cache and repeatedly cleared the local browser cache.
This rules out caching as the problem.
My basic configuration can also be ruled out, as the first image shows the correct behavior.
I don’t understand why this problem is happening. How can I fix it?
My Discourse version is 3.6.0.beta1-dev(b8e86ceb23)
The server OS is Debian 12.12
I have tested this locally using the latest versions of both Chrome and Opera browsers.
URL for the correct case: https://openttc.com/t/topic/61
URL for the incorrect case: https://openttc.com/t/topic/58
Dit is geen bug. Omdat de standaardtaal voor alle categoriebeschrijvingen (systeemschepping) En is. Wat je ook invoert, het is standaard een En-post. Daarom wordt de vertaling niet geactiveerd.
Every post has a detected language done by AI.
If you have a post originally written in “Chinese”, by right, the LLM should detect it to be “zh_CN”. You can view the detected language in the regular composer (not the translation composer) next to the :globe_with_meridians: .
The detected language is important so that the translator does not unnecessarily translate it to the detected language itself, and translates the post to every other language.
I suspect what is happening with https://openttc.com/t/topic/58 is that the detected language is incorrect, can you check?
Ja. Het werd ten onrechte gedetecteerd als en in plaats van zh_CN. Ik heb gecontroleerd en ontdekt dat alle door het systeem gemaakte categoriebeschrijvingsberichten als en werden gedetecteerd. Zelfs als ze in het Chinees zijn geschreven.
Nieuw probleem: Ondersteunt de FAQ-pagina meerdere talen? Waar moeten vertalingen worden toegevoegd?
I believe the FAQ page uses the typical I18n keys. You can go to your site’s admin page for site texts @ e.g. https://openttc.com/admin/customize/site_texts?q=guidelines_topic.body to replace it.
Okay, thank you very much for your help.
I think this is a real problem. I don’t know if this situation is common or due to my configuration error.
Het kan ook met de tijd te maken hebben. Als de categorieën zijn aangemaakt voordat de sitetaal werd gewijzigd, kunnen de talen van de categorieonderwerpen allemaal Engels zijn.
In dat geval kunt u naar het eerste bericht van de onderwerpen gaan, de composer openen en deze naar het Chinees schakelen.
Hello. After my attempts.
I created a new category 6 minutes ago: https://openttc.com/t/topic/66
Then I did nothing. Waiting for the translation to take effect.
After that, I got a post whose content is Chinese but was recognized as en.
When this category was created, my site language was 100% Simplified Chinese.
My AI model uses Openrouter’s Llama3.1 8b.
Interesting, can you run this data explorer query?
-- [params]
-- integer :topic_id = 66
SELECT
  a.id,
  a.created_at,
  a.response_tokens,
  (REGEXP_MATCH(a.raw_response_payload, '"text": "([^"\\]+)"'))[1] AS llm_detected_locale,
FROM ai_api_audit_logs a
JOIN posts p ON p.id = a.post_id AND p.deleted_at IS NULL
LEFT JOIN topics t ON t.id = a.topic_id AND t.deleted_at IS NULL
WHERE t.id = :topic_id
AND p.post_number = 1
AND a.feature_name = 'translation'
AND a.response_tokens < 5
This should tell us what the LLM is actually returning.
If we’re seeing an “en” in the llm_detected_locale column, I suspect your site’s prompts for locale detection may need a change, or you can use a more suitable LLM (maybe qwen?)
Hello. I ultimately did not resolve this issue, but it has had little impact.
The most accurate description of the problem should be: When I create a new category, the default language of the “About this category” post automatically generated by the system is recognized as “en”. Although the text content is indeed Simplified Chinese, when I open the post, it is recognized as English and needs to be manually changed.
I’m not sure if this is related to my app.yml file settings?
