Regarding the plugin
I believe I have meticulously followed the Installation and Configuration outlined in the Github.
Is there anything more needed to activate the Algolia index/search on the Discourse?
(Let me know if you need more info!)
I have not used it in a while, but I think it takes a bit for the index to populate, especially for larger sites. On the Algolia side, does your index show records?
@maiki it’s a new site with just a few records, but here are screenshots…
Algolia Dashboard…
Corresponding Discourse site…
Did you run the index rake tasks? From the screenshot it shows there are 0 records for discourse posts, so it isn’t indexed yet. ![]()
