Discourse-kalenderfout
User jucajuca reports an error while installing the discourse-calendar plugin on a Bitnami setup, citing a missing gem rrule-0.4.4.gem and a failed git reset --hard command during provisioning. The error log shows system shutdown messages and a Pups::ExecError indicating a git operation failure. Moin suggests consulting the Bitnami troubleshooting guide, while itsbhanusharma requests system resource details (free -h, df -h) to diagnose further. jucajuca links to another thread indicating broader issues with cloud installation, suggesting the problem may stem from an unsupported or broken Bitnami Discourse installation rather than the plugin itself. The thread remains unresolved, with the core issue pointing to gem dependency handling and possibly environment misconfiguration in Bitnami deployments.
Hello,
I am having som troubles instlling the discourse calendar plugin.
Any ideas what could be the problem?
Attached the whole html error report. Here a extract with the error:
ERROR: While executing gem … (Errno::ENOENT)
No such file or directory @ rb_sysopen - /home/discourse/.local/share/gem/ruby/2.7.0/cache/rrule-0.4.4.gem
You are specifying the gem rrule in /opt/bitnami/discourse/plugins/discourse-calendar/plugin.rb, however it does not exist!
Looked for: /opt/bitnami/discourse/plugins/discourse-calendar/gems/2.7.5/specifications/rrule-0.4.4.gemspec
Error: The application encountered the following error: exit (SystemExit)
passenger-error-XzYHj8.txt (415.6 KB)
Ok, but the official installation is broken:
I, [2022-04-02T15:13:26.316835 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2022-04-02T15:13:26.323689 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2022-04-02T15:13:26.330548 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2022-04-02T15:13:26.337595 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2022-04-02T15:13:26.344711 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2022-04-02T15:13:26.351608 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2022-04-02T15:13:26.351736 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2022-04-02T15:13:26.352214 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2022-04-02T15:13:26.354936 #1]  INFO -- : > cd /var/www/discourse && git reset --hard
130:C 02 Apr 2022 15:13:26.361 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
130:C 02 Apr 2022 15:13:26.361 # Redis version=6.2.6, bits=64, commit=00000000, modified=0, pid=130, just started
130:C 02 Apr 2022 15:13:26.361 # Configuration loaded
130:M 02 Apr 2022 15:13:26.362 * monotonic clock: POSIX clock_gettime
fatal: Unable to create '/var/www/discourse/.git/index.lock': Disk quota exceeded
130:M 02 Apr 2022 15:13:26.362 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
130:M 02 Apr 2022 15:13:26.362 # Failed listening on port 6379 (TCP), aborting.
I, [2022-04-02T15:13:26.363767 #1]  INFO -- :
I, [2022-04-02T15:13:26.364354 #1]  INFO -- : Terminating async processes
I, [2022-04-02T15:13:26.364466 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
I, [2022-04-02T15:13:26.364546 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 103
2022-04-02 15:13:26.364 UTC [42] LOG:  received fast shutdown request
103:signal-handler (1648912406) Received SIGTERM scheduling shutdown...
2022-04-02 15:13:26.366 UTC [42] LOG:  aborting any active transactions
2022-04-02 15:13:26.368 UTC [42] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2022-04-02 15:13:26.369 UTC [46] LOG:  shutting down
2022-04-02 15:13:26.383 UTC [42] LOG:  database system is shut down
103:M 02 Apr 2022 15:13:26.414 # User requested shutdown...
103:M 02 Apr 2022 15:13:26.414 * Saving the final RDB snapshot before exiting.
103:M 02 Apr 2022 15:13:26.415 * DB saved on disk
103:M 02 Apr 2022 15:13:26.415 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && git reset --hard failed with return #<Process::Status: pid 132 exit 128>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"code", "cmd"=>["git reset --hard", "git clean -f", "git remote set-branches --add origin main", "git remote set-branches origin $version", "git fetch --depth 1 origin $version", "git checkout $version", "mkdir -p tmp", "chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets", "touch tmp/.gitkeep", "mkdir -p                    /shared/log/rails", "bash -c \"touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\"", "bash -c \"ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\"", "bash -c \"mkdir -p           /shared/{uploads,backups}\"", "bash -c \"ln    -s           /shared/{uploads,backups} $home/public\"", "bash -c \"mkdir -p           /shared/tmp/{backups,restores}\"", "bash -c \"ln    -s           /shared/tmp/{backups,restores} $home/tmp\"", "chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp", "find public/plugins/ -maxdepth 1 -xtype l -delete"]}
bootstrap failed with exit code 128
8a2a9754c5d0f9d252a6a6ebd22dac970389c2a21a58ca39a25e867b30e17396
Can you share the output of free -h and df -h
I opened another issue for this:
