Discourse calendar plugin failing on stable branch
Hi guys,
At the time of precompiling assets, there is a glitch by using the Discourse calendar plugin.
Done compressing all JS files : 82.84 secs
Start compiling CSS: 2020-01-14 13:20:06 UTC
Compiling css for default 2020-01-14 13:20:06 UTC
precompile target: desktop Dark
rake aborted!
Discourse::ScssError: Error: no mixin named ellipsis
        on line 36 of plugins/discourse-calendar/assets/stylesheets/common/discourse-calendar.scss
        from line 28 of desktop.scss
>>       @include ellipsis;
/var/www/discourse/lib/stylesheet/manager.rb:175:in `rescue in compile'
/var/www/discourse/lib/stylesheet/manager.rb:163:in `compile'
/var/www/discourse/lib/stylesheet/manager.rb:98:in `block (2 levels) in precompile_css'
/var/www/discourse/lib/stylesheet/manager.rb:91:in `each'
/var/www/discourse/lib/stylesheet/manager.rb:91:in `block in precompile_css'
/var/www/discourse/lib/stylesheet/manager.rb:90:in `each'
/var/www/discourse/lib/stylesheet/manager.rb:90:in `precompile_css'
/var/www/discourse/lib/tasks/assets.rake:59:in `block (2 levels) in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.0.7/lib/rails_multisite/connection_management.rb:63:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.0.7/lib/rails_multisite/connection_management.rb:73:in `each_connection'
/var/www/discourse/lib/tasks/assets.rake:52:in `block in <top (required)>'
/var/www/discourse/lib/tasks/assets.rake:318:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-12.3.2/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Caused by:
SassC::SyntaxError: Error: no mixin named ellipsis
>>       @include ellipsis;
/var/www/discourse/plugins/discourse-calendar/assets/stylesheets/common/discourse-calendar.scss:36
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sassc-2.0.1/lib/sassc/engine.rb:49:in `render'
/var/www/discourse/lib/stylesheet/compiler.rb:40:in `compile'
/var/www/discourse/lib/stylesheet/compiler.rb:22:in `compile_asset'
/var/www/discourse/lib/stylesheet/manager.rb:164:in `compile'
Tasks: TOP => assets:precompile:css
Any hint?
Cheers,
Ismael
1 „Gefällt mir“
Hello,
can you tell me your Discourse version please ?
3 „Gefällt mir“
Hi Joffrey,
It’s stable branch, so should point to v2.3.8 in theory.
Cheers,
Ismael
Hi,
Any news on this?
Yes, I found the root cause.
I thought it has been for longer than this, but actually the ellipsis mixin has been added recently:
I have been fouled by the fact that we are using it in local-dates, but as local-dates is a core plugin it can’t be out of sync of core functions.
This should be fixed by:
If you try again that should work, sorry and thanks for report.
8 „Gefällt mir“
Yeah, confirm it works! :clap: Big thank you for your quick action!
Cheers,
Ismael
2 „Gefällt mir“
Cool, thanks for update!
1 „Gefällt mir“
