Impossible de charger le fichier « sass » dans la dernière version
getting this when rebuilding latest
LoadError: cannot load such file -- sass
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2.1/lib/active_support/dependencies.rb:291:in `require'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2.1/lib/active_support/dependencies.rb:291:in `block in        require'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2.1/lib/active_support/dependencies.rb:257:in `load_dep        endency'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/autoload/sass.rb:1:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/sass_processor.rb:47:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/sass_processor.rb:26:in `new'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/sass_processor.rb:26:in `instance'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/sass_processor.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:75:in `call_processor'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:57:in `block in call_pro        cessors'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:56:in `reverse_each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:56:in `call_processors'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:134:in `load_from_unloaded'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:60:in `block in load'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:317:in `fetch_asset_from_dependen        cy_cache'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:44:in `load'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/cached_environment.rb:20:in `block in initi        alize'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/cached_environment.rb:47:in `load'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/bundle.rb:23:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/utils.rb:200:in `dfs'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/bundle.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/base.rb:66:in `find_asset'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/base.rb:73:in `find_all_linked_assets'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/manifest.rb:134:in `block in find'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/manifest.rb:133:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/manifest.rb:133:in `find'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/sprockets/manifest.rb:186:in `compile'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-rails-3.2.1/lib/sprockets/rails/task.rb:68:in `block (3 levels)        in define'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-3.7.2/lib/rake/sprocketstask.rb:147:in `with_logger'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sprockets-rails-3.2.1/lib/sprockets/rails/task.rb:67:in `block (2 levels)        in define'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => assets:precompile
I, [2019-03-21T06:33:43.759098 #13]  INFO -- : Purging temp files
Bundling assets
I, [2019-03-21T06:33:43.760047 #13]  INFO -- : Terminating async processes
I, [2019-03-21T06:33:43.760215 #13]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgre        s:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main pid: 68
I, [2019-03-21T06:33:43.760489 #13]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/red        is/redis.conf pid: 234
234:signal-handler (1553150023) Received SIGTERM scheduling shutdown...
2019-03-21 06:33:43.761 UTC [68] LOG:  received fast shutdown request
2019-03-21 06:33:43.770 UTC [68] LOG:  aborting any active transactions
234:M 21 Mar 2019 06:33:43.783 # User requested shutdown...
234:M 21 Mar 2019 06:33:43.783 * Saving the final RDB snapshot before exiting.
2019-03-21 06:33:43.792 UTC [68] LOG:  worker process: logical replication launcher (PID 77) exited with exit code 1
2019-03-21 06:33:43.795 UTC [72] LOG:  shutting down
2019-03-21 06:33:43.850 UTC [68] LOG:  database system is shut down
234:M 21 Mar 2019 06:33:44.016 * DB saved on disk
234:M 21 Mar 2019 06:33:44.016 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile' failed with return #<Proces        s::Status: pid 3929 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake assets        :precompile'"]}
d2c2035ab07ee807e48782f6c80be6b06c0be48fe3181cd3fe59a51f90254434
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Setting:
version: ed73cc60a99aebb30c0631e2e5862bf987367da2
Makes it work (the change before the sass related change)
Any plugins running there? @david will have a look at this in a few hours
Nothing fancy, had these for ages:
          - git clone https://github.com/joebuhlig/discourse-feature-voting.git
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/discourse/discourse-staff-notes.git
          - git clone https://github.com/discourse/discourse-push-notifications.git
          - git clone https://github.com/discourse/discourse-chat-integration.git
          - git clone https://github.com/discourse/discourse-policy.git
          - cp -R /shared/plugins/buttons buttons
          - git clone https://github.com/discourse/discourse-assign.git
          - git clone https://github.com/discourse/discourse-data-explorer.git
          - git clone https://github.com/angusmcleod/discourse-custom-wizard.git
Buttons is based on the “buttons at the bottom of the page” plugin (I think you wrote that)
This is caused by an incompatibility between the custom-wizard plugin and the sassc upgrade. I think we can work around the problem, and will update here with a solution when I have it. cc @angus
This should now be fixed, following this commit
@carlokok please can you try updating to the latest version and confirm that it’s working for you?
That’s fixed it :+1: Thanks @david.
