Se encontró containers/app.yml
==================== CONFIGURACIONES YML ====================
DISCOURSE_HOSTNAME=forum.jimclair.com
SMTP_ADDRESS=in-v3.mailjet.com
DEVELOPER_EMAILS=OCULTADO
SMTP_PASSWORD=OCULTADO
SMTP_PORT=587
SMTP_USER_NAME=495e2921d498a8d1d5ebb0afaccd7b1e
LETSENCRYPT_ACCOUNT_EMAIL=OCULTADO
==================== INFO DE DOCKER ====================
VERSIÓN DE DOCKER: Docker version 24.0.7, build afdd53b
PROCESOS DE DOCKER (docker ps -a)
ID DE CONTENEDOR IMAGEN COMANDO CREADO ESTADO PUERTOS NOMBRES
==================== ¡¡¡PROBLEMA GRAVE!!! ====================
¡La aplicación no se está ejecutando!
Intentando reconstruir
==================== REGISTRO DE RECONSTRUCCIÓN ====================
Arquitectura x86_64 detectada.
Asegurando que el lanzador esté actualizado
El lanzador está actualizado
2.0.20231023-1945: Pulling from discourse/base
Digest: sha256:2b0eb484d20888cc2daadb690dcfa73522105650c1420212e99345a36a424d77
Status: Image is up to date for discourse/base:2.0.20231023-1945
docker.io/discourse/base:2.0.20231023-1945
/usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2023-12-06T20:26:30.044059 #1] INFO -- : Reading from stdin
I, [2023-12-06T20:26:30.054996 #1] INFO -- : > locale-gen $LANG && update-locale
I, [2023-12-06T20:26:30.127937 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2023-12-06T20:26:30.129014 #1] INFO -- : > mkdir -p /shared/postgres_run
I, [2023-12-06T20:26:30.136308 #1] INFO -- :
I, [2023-12-06T20:26:30.137496 #1] INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2023-12-06T20:26:30.146483 #1] INFO -- :
I, [2023-12-06T20:26:30.147545 #1] INFO -- : > chmod 775 /shared/postgres_run
I, [2023-12-06T20:26:30.151785 #1] INFO -- :
I, [2023-12-06T20:26:30.152774 #1] INFO -- : > rm -fr /var/run/postgresql
I, [2023-12-06T20:26:30.156678 #1] INFO -- :
I, [2023-12-06T20:26:30.157561 #1] INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2023-12-06T20:26:30.161932 #1] INFO -- :
I, [2023-12-06T20:26:30.162762 #1] INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2023/12/06 20:26:30 socat[18] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2023-12-06T20:26:30.178043 #1] INFO -- :
I, [2023-12-06T20:26:30.178987 #1] INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2023-12-06T20:26:30.185013 #1] INFO -- :
I, [2023-12-06T20:26:30.186426 #1] INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2023-12-06T20:26:30.192271 #1] INFO -- :
I, [2023-12-06T20:26:30.193332 #1] INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-12-06T20:26:30.198906 #1] INFO -- :
I, [2023-12-06T20:26:30.200224 #1] INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-12-06T20:26:30.205350 #1] INFO -- :
I, [2023-12-06T20:26:30.216408 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2023-12-06T20:26:30.226083 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2023-12-06T20:26:30.235233 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2023-12-06T20:26:30.244692 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2023-12-06T20:26:30.246204 #1] INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2023-12-06T20:26:32.183094 #1] INFO -- :
I, [2023-12-06T20:26:32.184301 #1] INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2023-12-06T20:26:32.188149 #1] INFO -- :
I, [2023-12-06T20:26:32.188988 #1] INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2023-12-06T20:26:32.234190 #1] INFO -- :
I, [2023-12-06T20:26:32.235330 #1] INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2023-12-06T20:26:32.239962 #1] INFO -- :
I, [2023-12-06T20:26:32.241087 #1] INFO -- : > /root/upgrade_postgres
I, [2023-12-06T20:26:32.250757 #1] INFO -- :
I, [2023-12-06T20:26:32.251706 #1] INFO -- : > rm /root/upgrade_postgres
I, [2023-12-06T20:26:32.255928 #1] INFO -- :
I, [2023-12-06T20:26:32.258122 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T20:26:32.259713 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T20:26:32.260811 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T20:26:32.262442 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T20:26:32.263355 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T20:26:32.264184 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T20:26:32.264947 #1] INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2023-12-06T20:26:32.272176 #1] INFO -- :
I, [2023-12-06T20:26:32.273754 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T20:26:32.274919 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T20:26:32.275763 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T20:26:32.276744 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/13/main/pg_hba.conf
I, [2023-12-06T20:26:32.277507 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-12-06T20:26:32.278326 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-12-06T20:26:32.279092 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2023-12-06T20:26:32.282210 #1] INFO -- : > sleep 5
2023-12-06 20:26:32.359 UTC [41] LOG: starting PostgreSQL 13.12 (Debian 13.12-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2023-12-06 20:26:32.361 UTC [41] LOG: listening on IPv4 address "0.0.0.0", port 5432
2023-12-06 20:26:32.362 UTC [41] LOG: listening on IPv6 address "::", port 5432
2023-12-06 20:26:32.365 UTC [41] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-12-06 20:26:32.373 UTC [44] LOG: database system was shut down at 2023-12-06 20:24:03 UTC
2023-12-06 20:26:32.383 UTC [41] LOG: database system is ready to accept connections
I, [2023-12-06T20:26:37.289395 #1] INFO -- :
I, [2023-12-06T20:26:37.289669 #1] INFO -- : > su postgres -c 'createdb discourse' || true
2023-12-06 20:26:37.379 UTC [54] postgres@postgres ERROR: database "discourse" already exists
2023-12-06 20:26:37.379 UTC [54] postgres@postgres STATEMENT: CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR: database "discourse" already exists
I, [2023-12-06T20:26:37.385520 #1] INFO -- :
I, [2023-12-06T20:26:37.386567 #1] INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2023-12-06 20:26:37.489 UTC [58] postgres@discourse ERROR: role "discourse" already exists
2023-12-06 20:26:37.489 UTC [58] postgres@discourse STATEMENT: create user discourse;
I, [2023-12-06T20:26:37.493228 #1] INFO -- :
I, [2023-12-06T20:26:37.494395 #1] INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2023-12-06T20:26:37.580872 #1] INFO -- : GRANT
I, [2023-12-06T20:26:37.582256 #1] INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2023-12-06T20:26:37.675825 #1] INFO -- : ALTER SCHEMA
I, [2023-12-06T20:26:37.676981 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE: extension "hstore" already exists, skipping
I, [2023-12-06T20:26:37.768934 #1] INFO -- : CREATE EXTENSION
I, [2023-12-06T20:26:37.770031 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE: extension "pg_trgm" already exists, skipping
I, [2023-12-06T20:26:37.859735 #1] INFO -- : CREATE EXTENSION
I, [2023-12-06T20:26:37.860890 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists vector;"'
NOTICE: extension "vector" already exists, skipping
I, [2023-12-06T20:26:37.935265 #1] INFO -- : CREATE EXTENSION
I, [2023-12-06T20:26:37.936060 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2023-12-06T20:26:37.997652 #1] INFO -- : CREATE EXTENSION
I, [2023-12-06T20:26:37.998539 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2023-12-06T20:26:38.064153 #1] INFO -- : CREATE EXTENSION
I, [2023-12-06T20:26:38.065166 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists vector;"'
I, [2023-12-06T20:26:38.129276 #1] INFO -- : CREATE EXTENSION
I, [2023-12-06T20:26:38.130194 #1] INFO -- : > sudo -u postgres psql discourse
I, [2023-12-06T20:26:38.135353 #1] INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2023-12-06T20:26:38.239022 #1] INFO -- : File > /var/lib/postgresql/take-database-backup chmod: +x chown: postgres:postgres
I, [2023-12-06T20:26:38.244519 #1] INFO -- : File > /var/spool/cron/crontabs/postgres chmod: chown:
I, [2023-12-06T20:26:38.245255 #1] INFO -- : > echo postgres installed!
I, [2023-12-06T20:26:38.248470 #1] INFO -- : postgres installed!
I, [2023-12-06T20:26:38.255515 #1] INFO -- : File > /etc/service/redis/run chmod: +x chown:
I, [2023-12-06T20:26:38.261932 #1] INFO -- : File > /etc/service/redis/log/run chmod: +x chown:
I, [2023-12-06T20:26:38.268388 #1] INFO -- : File > /etc/runit/3.d/10-redis chmod: +x chown:
I, [2023-12-06T20:26:38.270088 #1] INFO -- : Replacing daemonize yes with in /etc/redis/redis.conf
I, [2023-12-06T20:26:38.271335 #1] INFO -- : Replacing (?-mix:^pidfile.*$) with in /etc/redis/redis.conf
I, [2023-12-06T20:26:38.272324 #1] INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2023-12-06T20:26:38.276442 #1] INFO -- :
I, [2023-12-06T20:26:38.277583 #1] INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2023-12-06T20:26:38.278657 #1] INFO -- : Replacing (?-mix:^bind .*$) with in /etc/redis/redis.conf
I, [2023-12-06T20:26:38.281449 #1] INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2023-12-06T20:26:38.283018 #1] INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2023-12-06T20:26:38.284259 #1] INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2023-12-06T20:26:38.286500 #1] INFO -- : > echo redis installed
I, [2023-12-06T20:26:38.289930 #1] INFO -- : redis installed
I, [2023-12-06T20:26:38.290767 #1] INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2023-12-06T20:26:38.300057 #1] INFO -- : logfile ""
I, [2023-12-06T20:26:38.300939 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-12-06T20:26:38.303702 #1] INFO -- : > sleep 10
110:C 06 Dec 2023 20:26:38.320 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
110:C 06 Dec 2023 20:26:38.321 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=110, just started
110:C 06 Dec 2023 20:26:38.322 # Configuration loaded
110:M 06 Dec 2023 20:26:38.323 * monotonic clock: POSIX clock_gettime
110:M 06 Dec 2023 20:26:38.325 * Running mode=standalone, port=6379.
110:M 06 Dec 2023 20:26:38.325 # Server initialized
110:M 06 Dec 2023 20:26:38.326 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
110:M 06 Dec 2023 20:26:38.327 * Loading RDB produced by version 7.0.7
110:M 06 Dec 2023 20:26:38.328 * RDB age 155 seconds
110:M 06 Dec 2023 20:26:38.328 * RDB memory usage when created 1.44 Mb
110:M 06 Dec 2023 20:26:38.329 * Done loading RDB, keys loaded: 34, keys expired: 0.
110:M 06 Dec 2023 20:26:38.330 * DB loaded from disk: 0.003 seconds
110:M 06 Dec 2023 20:26:38.330 * Ready to accept connections
I, [2023-12-06T20:26:48.309711 #1] INFO -- :
I, [2023-12-06T20:26:48.310733 #1] INFO -- : > thpoff echo "thpoff is installed!"
I, [2023-12-06T20:26:48.315835 #1] INFO -- : thpoff is installed!
I, [2023-12-06T20:26:48.316614 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2023-12-06T20:26:48.421314 #1] INFO -- :
I, [2023-12-06T20:26:48.422469 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2023-12-06T20:26:48.505162 #1] INFO -- :
I, [2023-12-06T20:26:48.506193 #1] INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2023-12-06T20:26:48.592535 #1] INFO -- :
I, [2023-12-06T20:26:48.593337 #1] INFO -- : > rm -f /etc/cron.d/anacron
I, [2023-12-06T20:26:48.597070 #1] INFO -- :
I, [2023-12-06T20:26:48.601327 #1] INFO -- : File > /etc/cron.d/anacron chmod: chown:
I, [2023-12-06T20:26:48.608402 #1] INFO -- : File > /etc/runit/1.d/copy-env chmod: +x chown:
I, [2023-12-06T20:26:48.614544 #1] INFO -- : File > /etc/service/unicorn/run chmod: +x chown:
I, [2023-12-06T20:26:48.620938 #1] INFO -- : File > /etc/service/nginx/run chmod: +x chown:
I, [2023-12-06T20:26:48.627641 #1] INFO -- : File > /etc/runit/3.d/01-nginx chmod: +x chown:
I, [2023-12-06T20:26:48.634446 #1] INFO -- : File > /etc/runit/3.d/02-unicorn chmod: +x chown:
I, [2023-12-06T20:26:48.635292 #1] INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2023-12-06T20:26:48.636055 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-12-06T20:26:48.639453 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
137:C 06 Dec 2023 20:26:48.649 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
137:C 06 Dec 2023 20:26:48.650 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=137, just started
137:C 06 Dec 2023 20:26:48.650 # Configuration loaded
137:M 06 Dec 2023 20:26:48.651 * monotonic clock: POSIX clock_gettime
137:M 06 Dec 2023 20:26:48.654 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
137:M 06 Dec 2023 20:26:48.654 # Failed listening on port 6379 (TCP), aborting.
Updating files: 14% (4924/33858)^MUpdating files: 15% (5079/33858)^MUpdating files: 16% (5418/33858)^MUpdating files: 17% (5756/33858)^MUpdating files: 18% (6095/33858)^MUpdating files: 19% (6434/33858)^MUpdating files: 20% (6772/33858)^MUpdating files: 21% (7111/33858)^MUpdating files: 22% (7449/33858)^MUpdating files: 23% (7788/33858)^MUpdating files: 24% (8126/33858)^MUpdating files: 25% (8465/33858)^MUpdating files: 26% (8804/33858)^MUpdating files: 27% (9142/33858)^MUpdating files: 28% (9481/33858)^MUpdating files: 28% (9556/33858)^MUpdating files: 29% (9819/33858)^MUpdating files: 30% (10158/33858)^MUpdating files: 31% (10496/33858)^MUpdating files: 32% (10835/33858)^MUpdating files: 33% (11174/33858)^MUpdating files: 34% (11512/33858)^MUpdating files: 35% (11851/33858)^MUpdating files: 36% (12189/33858)^MUpdating files: 37% (12528/33858)^MUpdating files: 38% (12867/33858)^MUpdating files: 39% (13205/33858)^MUpdating files: 40% (13544/33858)^MUpdating files: 41% (13882/33858)^MUpdating files: 42% (14221/33858)^MUpdating files: 43% (14559/33858)^MUpdating files: 44% (14898/33858)^MUpdating files: 45% (15237/33858)^MUpdating files: 45% (15499/33858)^MUpdating files: 46% (15575/33858)^M^MUpdating files: 47% (15914/33858)^MUpdating files: 48% (16252/33858)^MUpdating files: 49% (16591/33858)^MUpdating files: 50% (16929/33858)^MUpdating files: 51% (17268/33858)^MUpdating files: 52% (17607/33858)^MUpdating files: 53% (17945/33858)^MUpdating files: 54% (18284/33858)^MUpdating files: 55% (18622/33858)^MUpdating files: 56% (18961/33858)^MUpdating files: 57% (19300/33858)^MUpdating files: 58% (19638/33858)^MUpdating files: 59% (19977/33858)^MUpdating files: 60% (20315/33858)^MUpdating files: 61% (20654/33858)^MUpdating files: 62% (20992/33858)^MUpdating files: 63% (21331/33858)^MUpdating files: 64% (21670/33858)^MUpdating files: 64% (21754/33858)^MUpdating files: 65% (22008/33858)^MUpdating files: 66% (22347/33858)^MUpdating files: 67% (22685/33858)^MUpdating files: 68% (23024/33858)^MUpdating files: 69% (23363/33858)^MUpdating files: 70% (23701/33858)^MUpdating files: 71% (24040/33858)^MUpdating files: 72% (24378/33858)^MUpdating files: 73% (24717/33858)^MUpdating files: 74% (25055/33858)^MUpdating files: 75% (25394/33858)^MUpdating files: 76% (25733/33858)^MUpdating files: 77% (26071/33858)^MUpdating files: 78% (26410/33858)^MUpdating files: 79% (26748/33858)^MUpdating files: 80% (27087/33858)^MUpdating files: 80% (27336/33858)^MUpdating files: 81% (27425/33858)^MUpdating files: 82% (27764/33858)^MUpdating files: 83% (28103/33858)^MUpdating files: 84% (28441/33858)^MUpdating files: 85% (28780/33858)^MUpdating files: 86% (29118/33858)^MUpdating files: 87% (29457/33858)^MUpdating files: 88% (29796/33858)^MUpdating files: 89% (30134/33858)^MUpdating files: 90% (30473/33858)^MUpdating files: 91% (30811/33858)^MUpdating files: 92% (31150/33858)^MUpdating files: 93% (31488/33858)^MUpdating files: 94% (31827/33858)^MUpdating files: 94% (32069/33858)^MUpdating files: 95% (32166/33858)^MUpdating files: 96% (32504/33858)^MUpdating files: 97% (32843/33858)^MUpdating files: 98% (33181/33858)^MUpdating files: 99% (33520/33858)^MUpdating files: 100% (33858/33858)^MUpdating files: 100% (33858/33858), done.
I, [2023-12-06T20:26:56.173644 #1] INFO -- : HEAD is now at 043b4a418 FIX: replaces data-tooltip usage by <DTooltip /> (#24062)
I, [2023-12-06T20:26:56.177410 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2023-12-06T20:26:56.982967 #1] INFO -- :
I, [2023-12-06T20:26:56.983710 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
set -o errexit
if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
git remote set-branches --add origin main
git remote set-branches origin tests-passed
git fetch --depth 1 origin tests-passed
else
git fetch --tags --prune-tags --prune --force origin
fi
From https://github.com/discourse/discourse
- [deleted] (none) -> origin/0-flake-key
- [deleted] (none) -> origin/0-obscuring
- [deleted] (none) -> origin/0-router-lint
- [deleted] (none) -> origin/0-router-service
- [deleted] (none) -> origin/autoimport-cleanup
- [deleted] (none) -> origin/category-bullet-only
- [deleted] (none) -> origin/dependabot/bundler/syntax_tree-6.2.0
- [deleted] (none) -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.4.0
- [deleted] (none) -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.8.0
- [deleted] (none) -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.6.0
- [deleted] (none) -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/utils-5.5.2
- [deleted] (none) -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.4.2
- [deleted] (none) -> origin/dev-upgrade-reject-reason-reviewable-modal
- [deleted] (none) -> origin/dev/ability-to-collect-stats-without-public-exposing
- [deleted] (none) -> origin/dev/minio-s3-system-specs
- [deleted] (none) -> origin/dev/re-enable-minio-specs
- [deleted] (none) -> origin/dev/switch-over-category-settings
- [deleted] (none) -> origin/dev/switch-over-more-category-settings
- [deleted] (none) -> origin/discovery-named-outlets
- [deleted] (none) -> origin/feature/theme-settings-migration
- [deleted] (none) -> origin/fix/account-for-empty-string-site-settings
- [deleted] (none) -> origin/footnote-plugin
- [deleted] (none) -> origin/metadata-update
- [deleted] (none) -> origin/modal-ux
- [deleted] (none) -> origin/neil-2
- [deleted] (none) -> origin/perf_cache_async_search
- [deleted] (none) -> origin/spoiler-plugin
- [deleted] (none) -> origin/support-search-customizationz
043b4a418..42a75e3df main -> origin/main
* [new branch] 0-lint-suffix -> origin/0-lint-suffix
* [new branch] 0-rubocop -> origin/0-rubocop
* [new branch] 0-timeoubara -> origin/0-timeoubara
* [new branch] 0-typos -> origin/0-typos
* [new branch] add-custom-emoji-sanitization-clean -> origin/add-custom-emoji-sanitization-clean
* [new branch] add-ds-store-to-gitignore -> origin/add-ds-store-to-gitignore
+ 64520a075...ff17131c9 add-new-chat-indicator-preference-only-mentions -> origin/add-new-chat-indicator-preference-only-mentions (actualización forzada)
* [new branch] api-topic-title-decorator -> origin/api-topic-title-decorator
* [new branch] array-custom-field-fix -> origin/array-custom-field-fix
* [new branch] array-custom-field-order -> origin/array-custom-field-order
* [new branch] avatar-notifications -> origin/avatar-notifications
* [new branch] boosted-searches -> origin/boosted-searches
* [new branch] bulk-button-class -> origin/bulk-button-class
* [new branch] category_definition -> origin/category_definition
* [new branch] chat-github-onebox -> origin/chat-github-onebox
* [new branch] chat-reaction-emoji-alignment -> origin/chat-reaction-emoji-alignment
* [new branch] chat/direct-messages -> origin/chat/direct-messages
* [new branch] custom-field-store-cleanup -> origin/custom-field-store-cleanup
* [new branch] delete-backups-based-on-time-window -> origin/delete-backups-based-on-time-window
* [new branch] dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.5.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.5.0
* [new branch] dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.9.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.9.0
* [new branch] dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.7.1 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.7.1
* [new branch] dependabot/npm_and_yarn/app/assets/javascripts/uppy/utils-5.6.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/utils-5.6.0
* [new branch] dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.5.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.5.0
* [new branch] desktop-notification-handlers -> origin/desktop-notification-handlers
* [new branch] dev/add-a-reference-column-to-notifications -> origin/dev/add-a-reference-column-to-notifications
+ ee95e6359...346f9d1cd dev/add-new-chat-metrics -> origin/dev/add-new-chat-metrics (actualización forzada)
* [new branch] dev/dry-up-user-status-serializers -> origin/dev/dry-up-user-status-serializers
* [new branch] dev/flaky-chat-details-collapser-spec -> origin/dev/flaky-chat-details-collapser-spec
* [new branch] dev/no-need-to-include-user-status-twice -> origin/dev/no-need-to-include-user-status-twice
* [new branch] dev/rethink-mass-mentions -> origin/dev/rethink-mass-mentions
* [new branch] dev/rethink-mass-mentions-polymorphic -> origin/dev/rethink-mass-mentions-polymorphic
* [new branch] dev/revert-guardian-devex -> origin/dev/revert-guardian-devex
* [new branch] dev/use-system-user-id-const -> origin/dev/use-system-user-id-const
+ 54940ca5c...fb0c7ba69 dev_paginate_categories_json -> origin/dev_paginate_categories_json (actualización forzada)
* [new branch] dev_watched_words -> origin/dev_watched_words
+ 46fe4511f...a9d0e7069 ember-4 -> origin/ember-4 (actualización forzada)
* [new branch] ember-5-plugins -> origin/ember-5-plugins
* [new branch] extract_stripper -> origin/extract_stripper
* [new branch] feature/add-copy-share-link-post-functionality -> origin/feature/add-copy-share-link-post-functionality
9a6c6fd5b..8780daeee feature/bookmark-menu-and-modal-redesign -> origin/feature/bookmark-menu-and-modal-redesign
* [new branch] feature/migrations-schema-generator -> origin/feature/migrations-schema-generator
* [new branch] feature_watched_words_validation -> origin/feature_watched_words_validation
* [new branch] file-size-restriction -> origin/file-size-restriction
43df37774..4393dd37e filtered-events -> origin/filtered-events
* [new branch] fix/count-mass-mentions-correctly -> origin/fix/count-mass-mentions-correctly
* [new branch] fix_category_select_kits -> origin/fix_category_select_kits
* [new branch] full-page -> origin/full-page
ce7fb6906..a6227532d generic-import-latest -> origin/generic-import-latest
* [new branch] generic-import-latest-snowflake -> origin/generic-import-latest-snowflake
* [new branch] generic-import-update -> origin/generic-import-update
* [new branch] image-assets -> origin/image-assets
* [new branch] independent-theme-compiler -> origin/independent-theme-compiler
* [new branch] input-text-field-component -> origin/input-text-field-component
* [new branch] issue/fix-guardian-init-basic-user -> origin/issue/fix-guardian-init-basic-user
* [new branch] keyword-site-setting -> origin/keyword-site-setting
+ bdcc24f96...92e545292 list-wrapper -> origin/list-wrapper (actualización forzada)
e3636078c..5def32699 mock-chat-index-redesign -> origin/mock-chat-index-redesign
* [new branch] move_inflector -> origin/move_inflector
* [new branch] oklab -> origin/oklab
* [new branch] poc/auto-after-before-plugin-outlets -> origin/poc/auto-after-before-plugin-outlets
* [new branch] poc/insert-before-after-wrapping-outlet -> origin/poc/insert-before-after-wrapping-outlet
* [new branch] pretty-text-please -> origin/pretty-text-please
* [new branch] revert-maxmind -> origin/revert-maxmind
ef3f41543..223626d7a stable -> origin/stable
* [new branch] support-load-more-btn -> origin/support-load-more-btn
* [new branch] test-issue-temporary -> origin/test-issue-temporary
043b4a418..42a75e3df tests-passed -> origin/tests-passed
* [new branch] tobiaseigen-patch-3 -> origin/tobiaseigen-patch-3
* [new branch] transform-hooks -> origin/transform-hooks
* [new branch] transform-post-fn-api -> origin/transform-post-fn-api
* [new branch] tweaks-2-fr -> origin/tweaks-2-fr
* [new branch] use-sassc-embedded -> origin/use-sassc-embedded
* [new branch] username_cache -> origin/username_cache
* [new branch] ux-add-sorting-params-to-outlet -> origin/ux-add-sorting-params-to-outlet
t [tag update] beta -> beta
t [tag update] latest-release -> latest-release
* [new tag] v3.1.3 -> v3.1.3
* [new tag] v3.2.0.beta3 -> v3.2.0.beta3
I, [2023-12-06T20:26:58.926569 #1] INFO -- :
I, [2023-12-06T20:26:58.927227 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
set -o errexit
if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
git pull
else
git -c advice.detachedHead=false checkout tests-passed
fi
Cambiado a una nueva rama 'tests-passed'
I, [2023-12-06T20:27:03.240852 #1] INFO -- : La rama 'tests-passed' configurada para seguir la rama remota 'tests-passed' desde 'origin'.
I, [2023-12-06T20:27:03.241691 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2023-12-06T20:27:03.259458 #1] INFO -- :
I, [2023-12-06T20:27:03.260307 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2023-12-06T20:27:03.268215 #1] INFO -- :
I, [2023-12-06T20:27:03.268948 #1] INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2023-12-06T20:27:03.274182 #1] INFO -- :
I, [2023-12-06T20:27:03.274855 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2023-12-06T20:27:03.278878 #1] INFO -- :
I, [2023-12-06T20:27:03.279454 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2023-12-06T20:27:03.283264 #1] INFO -- :
I, [2023-12-06T20:27:03.283766 #1] INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2023-12-06T20:27:03.288610 #1] INFO -- :
I, [2023-12-06T20:27:03.289240 #1] INFO -- : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2023-12-06T20:27:03.294659 #1] INFO -- :
I, [2023-12-06T20:27:03.295302 #1] INFO -- : > cd /var/www/discourse && bash -c "touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2023-12-06T20:27:03.302627 #1] INFO -- :
I, [2023-12-06T20:27:03.303433 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2023-12-06T20:27:03.315829 #1] INFO -- :
I, [2023-12-06T20:27:03.316535 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/{uploads,backups}"
I, [2023-12-06T20:27:03.323346 #1] INFO -- :
I, [2023-12-06T20:27:03.324041 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/{uploads,backups} /var/www/discourse/public"
I, [2023-12-06T20:27:03.329963 #1] INFO -- :
I, [2023-12-06T20:27:03.330611 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/tmp/{backups,restores}"
I, [2023-12-06T20:27:03.336990 #1] INFO -- :
I, [2023-12-06T20:27:03.338135 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2023-12-06T20:27:03.344705 #1] INFO -- :
I, [2023-12-06T20:27:03.345357 #1] INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2023-12-06T20:27:03.352154 #1] INFO -- :
I, [2023-12-06T20:27:03.352907 #1] INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2023-12-06T20:27:03.356397 #1] INFO -- :
I, [2023-12-06T20:27:03.358224 #1] INFO -- : Reemplazando # redis con sv start redis || exit 1 en /etc/service/unicorn/run
I, [2023-12-06T20:27:03.359316 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Clonando en 'docker_manager'...
I, [2023-12-06T20:27:04.552327 #1] INFO -- :
I, [2023-12-06T20:27:04.553636 #1] INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2023-12-06T20:27:04.563675 #1] INFO -- :
I, [2023-12-06T20:27:04.565087 #1] INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2023-12-06T20:27:04.571639 #1] INFO -- :
I, [2023-12-06T20:27:04.573162 #1] INFO -- : > mkdir -p /var/nginx/cache
I, [2023-12-06T20:27:04.580350 #1] INFO -- :
I, [2023-12-06T20:27:04.582472 #1] INFO -- : Reemplazando pid /run/nginx.pid; con daemon off; en /etc/nginx/nginx.conf
I, [2023-12-06T20:27:04.583466 #1] INFO -- : Reemplazando (?m-ix:upstream[^\}]+\}) con upstream discourse { server 127.0.0.1:3000; } en /etc/nginx/conf.d/discourse.conf
I, [2023-12-06T20:27:04.584155 #1] INFO -- : Reemplazando (?-mix:server_name.+$) con server_name _ ; en /etc/nginx/conf.d/discourse.conf
I, [2023-12-06T20:27:04.584716 #1] INFO -- : Reemplazando (?-mix:client_max_body_size.+$) con client_max_body_size $upload_size ; en /etc/nginx/conf.d/discourse.conf
I, [2023-12-06T20:27:04.585271 #1] INFO -- : Reemplazando (?-mix:worker_connections.+$) con worker_connections $nginx_worker_connections ; en /etc/nginx/nginx.conf
I, [2023-12-06T20:27:04.585727 #1] INFO -- : > echo "configuración web completada"
I, [2023-12-06T20:27:04.588861 #1] INFO -- : configuración web completada
I, [2023-12-06T20:27:04.589566 #1] INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2023-12-06T20:27:04.923204 #1] INFO -- :
I, [2023-12-06T20:27:04.927970 #1] INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2023-12-06T20:27:10.523499 #1] INFO -- :
I, [2023-12-06T20:27:10.524699 #1] INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
rm -rf app/assets/javascripts/node_modules
fi
I, [2023-12-06T20:27:10.527759 #1] INFO -- :
I, [2023-12-06T20:27:10.528364 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
advertencia " > @glint/environment-ember-loose@1.1.0" tiene una dependencia peer "@glimmer/component@^1.1.2" no satisfecha.
advertencia " > @glint/environment-ember-template-imports@1.1.0" tiene una dependencia peer "ember-template-imports@^3.0.0" no satisfecha.
advertencia El campo de resolución "unset-value@2.0.1" es incompatible con la versión solicitada "unset-value@^1.0.0"
advertencia El patrón ["wrap-ansi@^7.0.0"] está intentando descomprimir en el mismo destino "/home/discourse/.cache/yarn/v6/npm-wrap-ansi-cjs-7.0.0-67e145cff510a6a6984bdf1152911d69d2eb9e43-integrity/node_modules/wrap-ansi-cjs" que el patrón ["wrap-ansi-cjs@npm:wrap-ansi@^7.0.0"]. Esto podría resultar en un comportamiento no determinista, omitiendo.
advertencia " > discourse-markdown-it@1.0.0" tiene una dependencia peer "xss@*" no satisfecha.
advertencia "workspace-aggregator-943550ef-70f9-4b27-bc8f-8ecafe854b91 > discourse > @ember/legacy-built-in-components@0.5.0" tiene una dependencia peer incorrecta "ember-source@>= 4.8".
advertencia "workspace-aggregator-943550ef-70f9-4b27-bc8f-8ecafe854b91 > discourse > @uppy/aws-s3@3.0.6" tiene una dependencia peer incorrecta "@uppy/core@^3.1.2".
advertencia "workspace-aggregator-943550ef-70f9-4b27-bc8f-8ecafe854b91 > discourse > @uppy/aws-s3-multipart@3.1.3" tiene una dependencia peer incorrecta "@uppy/core@^3.1.2".
advertencia "workspace-aggregator-943550ef-70f9-4b27-bc8f-8ecafe854b91 > discourse > @uppy/xhr-upload@3.1.1" tiene una dependencia peer incorrecta "@uppy/core@^3.1.2".
advertencia "workspace-aggregator-943550ef-70f9-4b27-bc8f-8ecafe854b91 > discourse-plugins > ember-this-fallback@0.4.0" tiene una dependencia peer "ember-source@^3.28.11 || ^4.0.0" no satisfecha.
advertencia "workspace-aggregator-943550ef-70f9-4b27-bc8f-8ecafe854b91 > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" tiene una dependencia peer incorrecta "@uppy/core@^3.2.1".
I, [2023-12-06T20:29:55.103882 #1] INFO -- : yarn install v1.22.19
[1/5] Validando package.json...
[2/5] Resolviendo paquetes...
[3/5] Obteniendo paquetes...
[4/5] Enlazando dependencias...
[5/5] Construyendo paquetes nuevos...
$ yarn --cwd app/assets/javascripts $(node -e 'const argv = JSON.parse(process.env.npm_config_argv).original; const passthrough = [`--frozen-lockfile`, `-s`].filter(arg => argv.includes(arg)); console.log(passthrough.join(` `));')
[1/4] Resolviendo paquetes...
[2/4] Obteniendo paquetes...
[3/4] Enlazando dependencias...
[4/4] Construyendo paquetes nuevos...
$ ./run-patch-package
patch-package 8.0.0
Aplicando parches...
babel-plugin-debug-macros@0.3.4 ✔
content-tag@1.1.2 ✔
ember-cli@5.0.0 ✔
ember-this-fallback@0.4.0 (1 deprecation-name) ✔
ember-this-fallback@0.4.0 (2 themes) ✔
virtual-dom@2.1.1 ✔
Listo en 78.38s.
Listo en 150.14s.
yarn cache v1.22.19
éxito Caché limpiada.
Listo en 13.55s.
I, [2023-12-06T20:29:55.136749 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local deployment true'
I, [2023-12-06T20:29:55.567684 #1] INFO -- :
I, [2023-12-06T20:29:55.568701 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local without "development test"'
I, [2023-12-06T20:29:55.820221 #1] INFO -- : Estás reemplazando el valor local actual de without, que actualmente es "test:development"
I, [2023-12-06T20:29:55.821029 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --retry 3 --jobs 4'
I, [2023-12-06T20:30:38.015883 #1] INFO -- : Obteniendo metadatos de gem de https://rubygems.org/.........
Obteniendo rake 13.1.0
Instalando rake 13.1.0
Usando builder 3.2.4
Usando erubi 1.12.0
Obteniendo racc 1.7.3
Usando crass 1.0.6
Usando minitest 5.20.0
Usando concurrent-ruby 1.2.2
Usando rack 2.2.8
Usando mini_mime 1.1.5
Obteniendo timeout 0.4.1
Obteniendo public_suffix 5.0.4
Obteniendo date 3.3.4
Instalando timeout 0.4.1
Instalando racc 1.7.3 con extensiones nativas
Instalando date 3.3.4 con extensiones nativas
Instalando public_suffix 5.0.4
Obteniendo aws-eventstream 1.3.0
Instalando aws-eventstream 1.3.0
Usando jmespath 1.6.2
Obteniendo base64 0.2.0
Usando aws-partitions 1.583.0
Usando msgpack 1.7.2
Usando bundler 2.4.13
Usando byebug 11.1.3
Usando cbor 0.5.9.6
Obteniendo cgi 0.4.1
Instalando base64 0.2.0
Instalando cgi 0.4.1 con extensiones nativas
Usando chunky_png 1.4.0
Usando coderay 1.1.3
Usando colored2 4.0.0
Usando connection_pool 2.4.1
Usando openssl 3.2.0
Usando cppjieba_rb 0.4.2
Obteniendo google-protobuf 3.25.1 (x86_64-linux)
Instalando google-protobuf 3.25.1 (x86_64-linux)
Usando diffy 3.4.2
Usando digest 3.1.1
Usando discourse-fonts 0.0.9
Usando email_reply_trimmer 0.1.13
Obteniendo excon 0.105.0
Instalando excon 0.105.0
Usando execjs 2.9.1
Usando exifr 1.4.0
Usando faraday-net_http 3.0.2
Usando ruby2_keywords 0.0.5
Usando fast_blank 1.0.1
Usando fast_xs 0.8.0
Usando fastimage 2.2.7
Usando ffi 1.16.3
Usando fspath 3.1.2
Usando gc_tracer 1.5.1
Usando guess_html_encoding 0.0.11
Usando hana 1.3.7
Usando hashie 5.0.0
Usando highline 2.1.0
Usando htmlentities 4.3.4
Usando http_accept_language 2.1.1
Usando image_size 3.3.0
Usando in_threads 1.6.0
Usando progress 3.6.0
Obteniendo json 2.7.1
Instalando json 2.7.1 con extensiones nativas
Obteniendo regexp_parser 2.8.3
Instalando regexp_parser 2.8.3
Obteniendo unf_ext 0.0.9.1
Instalando unf_ext 0.0.9.1 con extensiones nativas
Usando jwt 2.7.1
Usando kgio 2.11.4
Usando libv8-node 18.16.0.0 (x86_64-linux)
Usando method_source 1.0.0
Usando thor 1.3.0
Usando zeitwerk 2.6.12
Usando logstash-event 1.2.02
Obteniendo logster 2.13.1
Instalando logster 2.13.1
Usando lru_redux 1.1.0
Usando lz4-ruby 0.3.3
Usando maxminddb 0.1.22
Usando memory_profiler 1.0.1
Usando redis 4.8.1
Usando mini_sql 1.5.0
Usando multi_json 1.15.0
Usando multi_xml 0.6.0
Usando mustache 1.1.1
Obteniendo uri 0.13.0
Instalando uri 0.13.0
Obteniendo nio4r 2.7.0
Instalando nio4r 2.7.0 con extensiones nativas
Usando version_gem 1.1.3
Usando oj 3.16.1
Usando optimist 3.1.0
Usando pg 1.5.4
Usando raindrops 0.20.1
Usando rchardet 1.8.0
Usando rexml 3.2.6
Usando rinku 2.0.6
Usando rotp 6.3.0
Usando rqrcode_core 1.2.0
Usando rubyzip 2.3.2
Usando sshkey 3.0.0
Usando stackprof 0.2.25
Usando i18n 1.14.1
Usando tzinfo 2.0.6
Usando rack-test 2.1.0
Usando request_store 1.5.1
Usando message_bus 4.3.8
Usando rack-mini-profiler 3.1.1
Usando rack-protection 3.1.0
Usando sprockets 3.7.2 desde https://github.com/rails/sprockets (en 3.x@f4d3dae)
Obteniendo net-protocol 0.2.2
Instalando net-protocol 0.2.2
Usando aws-sigv4 1.5.0
Usando addressable 2.8.5
Obteniendo bootsnap 1.17.0
Instalando bootsnap 1.17.0 con extensiones nativas
Usando openssl-signature_algorithm 1.3.0
Obteniendo sass-embedded 1.66.1 (x86_64-linux-gnu)
Instalando sass-embedded 1.66.1 (x86_64-linux-gnu)
Usando uglifier 4.2.0
Obteniendo faraday 2.7.12
Instalando faraday 2.7.12
Usando mini_suffix 0.3.3
Usando omniauth 1.9.2
Usando image_optim 0.31.3
Obteniendo nokogiri 1.15.5 (x86_64-linux)
Instalando nokogiri 1.15.5 (x86_64-linux)
Obteniendo web-push 3.0.1
Instalando web-push 3.0.1
Usando mini_racer 0.8.0
Usando pry 0.14.2
Usando logstash-logger 0.26.1
Usando sidekiq 6.5.12
Usando redis-namespace 1.11.0
Obteniendo net-http 0.4.0
Usando unf 0.1.4
Instalando net-http 0.4.0
Usando oauth-tty 1.0.5
Usando snaky_hash 2.0.1
Obteniendo rbtrace 0.5.0
Usando rss 0.3.0
Usando unicorn 6.1.0
Usando rqrcode 2.2.0
Usando activesupport 7.0.7
Usando tzinfo-data 1.2023.3
Usando net-pop 0.1.2
Usando net-smtp 0.4.0
Usando aws-sdk-core 3.130.2
Usando css_parser 1.16.0
Usando cose 1.3.0
Obteniendo dartsass-ruby 3.0.2
Instalando rbtrace 0.5.0 con extensiones nativas
Instalando dartsass-ruby 3.0.2
Usando faraday-retry 2.2.0
Usando oauth2 1.4.11
Obteniendo loofah 2.22.0
Instalando loofah 2.22.0
Usando ruby-readability 0.7.0
Usando sanitize 6.1.0
Usando rtlcss 0.2.1
Usando pry-byebug 3.10.1
Usando pry-rails 0.3.9
Usando mini_scheduler 0.16.0
Usando simpleidn 0.2.1
Usando oauth 1.1.0
Usando rails-dom-testing 2.2.0
Usando globalid 1.2.1
Usando activemodel 7.0.7
Usando aws-sdk-kms 1.56.0
Usando aws-sdk-sns 1.53.0
Usando omniauth-oauth2 1.7.3
Usando rails-html-sanitizer 1.6.0
Obteniendo json_schemer 2.1.1
Instalando json_schemer 2.1.1
Usando omniauth-oauth 1.2.0
Usando actionview 7.0.7
Usando activejob 7.0.7
Usando active_model_serializers 0.8.4
Usando activerecord 7.0.7
Usando aws-sdk-s3 1.114.0
Usando omniauth-facebook 9.0.0
Usando omniauth-github 1.4.0
Usando omniauth-google-oauth2 0.8.2
Usando omniauth-twitter 1.4.0
Usando actionpack 7.0.7
Usando actionview_precompiler 0.3.0
Usando discourse-seed-fu 2.3.12
Usando railties 7.0.7
Usando sprockets-rails 3.4.2
Usando lograge 0.14.0
Usando rails_failover 2.0.1
Usando rails_multisite 5.0.0
Usando puma 6.4.0
Obteniendo net-imap 0.4.7
Instalando net-imap 0.4.7
Usando mail 2.8.1
Usando actionmailer 7.0.7
¡Bundle completo! 135 dependencias de Gemfile, 170 gems instaladas ahora.
Las gems en los grupos 'development' y 'test' no se instalaron.
Las gems empaquetadas se instalan en `./vendor/bundle`
I, [2023-12-06T20:30:38.029906 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2023-12-06T20:30:42.946058 #1] INFO -- : docker_manager ya está en la última versión compatible
I, [2023-12-06T20:30:42.947529 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2023-12-06T20:30:52.368108 #1] INFO -- :
I, [2023-12-06T20:30:52.370735 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
El límite de tamaño de heap de Node.js (488.25) es menor que 1024MB. Estableciendo --max-old-space-size=1024.
El límite de tamaño de heap de Node.js (488.25) es menor que 2048MB. Deshabilitando la paralelización de Webpack con JOBS=0 para conservar memoria.
110:M 06 dic 2023 20:31:39.033 * 100 cambios en 300 segundos. Guardando...
110:M 06 dic 2023 20:31:39.037 * Inicio del guardado en segundo plano por pid 3264
3264:C 06 dic 2023 20:31:39.055 * Base de datos guardada en disco
3264:C 06 dic 2023 20:31:39.056 * Fork CoW para RDB: actual 0 MB, pico 0 MB, promedio 0 MB
110:M 06 dic 2023 20:31:39.138 * Guardado en segundo plano terminado con éxito
<--- Últimos pocos GCs --->
[3250:0x75de170] 713299 ms: Scavenge 941.1 (1032.4) -> 939.7 (1032.4) MB, 11.8 / 0.0 ms (mu promedio = 0.392, mu actual = 0.720) fallo de asignación;
[3250:0x75de170] 713376 ms: Scavenge 941.4 (1032.4) -> 940.0 (1032.4) MB, 13.1 / 0.0 ms (mu promedio = 0.392, mu actual = 0.720) fallo de asignación;
[3250:0x75de170] 713474 ms: Scavenge 941.9 (1032.4) -> 940.4 (1036.4) MB, 19.8 / 0.0 ms (mu promedio = 0.392, mu actual = 0.720) fallo de asignación;
<--- Pila de JS --->
ERROR FATAL: Se alcanzó el límite de heap Fallo de asignación - memoria del heap de JavaScript agotada
1: 0xb83f50 node::Abort() [ember]
2: 0xa94834 [ember]
3: 0xd647c0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [ember]
4: 0xd64b67 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [ember]
5: 0xf42265 [ember]
6: 0xf5474d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [ember]
7: 0xf2ee4e v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [ember]
8: 0xf30217 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [ember]
9: 0xf113ea v8::internal::Factory::NewFillerObject(int, v8::internal::AllocationAlignment, v8::internal::AllocationType, v8::internal::AllocationOrigin) [ember]
10: 0x12d674f v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [ember]
11: 0x17035b9 [ember]
Abortado (se generó volcado)
error El comando falló con código de salida 134.
I, [2023-12-06T20:42:53.261307 #1] INFO -- : yarn run v1.22.19
$ /var/www/discourse/app/assets/javascripts/node_modules/.bin/ember build
Construyendo
Entorno: development
ADVERTENCIA: ember-test-selectors: Estás usando una versión de ember-cli-babel no soportada. Las propiedades data-test no se eliminan automáticamente de tu código JS.
construyendo...
...[ConfigLoader]
...[Babel: discourse-widget-hbs > applyPatches]
...[Babel: ember-source > applyPatches]
...[ember.js]
...[Babel: discourse-common > applyPatches]
...[Babel: truth-helpers > applyPatches]
...[Babel: @ember/legacy-built-in-components > applyPatches]
...[Babel: @ember/render-modifiers > applyPatches]
...[Babel: @ember/test-waiters > applyPatches]
...[Babel: @embroider/util > applyPatches]
...[Babel: dialog-holder > applyPatches]
...[Babel: ember-this-fallback > applyPatches]
...[Babel: ember-cached-decorator-polyfill > applyPatches]
...[Babel: ember-exam > applyPatches]
...[Babel: ember-functions-as-helper-polyfill > applyPatches]
...[Babel: ember-resize-observer-service > applyPatches]
...[Babel: ember-router-service-refresh-polyfill > applyPatches]
...[Babel: float-kit > applyPatches]
...[Babel: select-kit > applyPatches]
...[@embroider/compat/app]
...[@embroider/webpack]
info Visita https://yarnpkg.com/en/docs/cli/run para documentación sobre este comando.
I, [2023-12-06T20:42:53.304072 #1] INFO -- : Terminando procesos asíncronos
I, [2023-12-06T20:42:53.306771 #1] INFO -- : Enviando INT a HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 41
2023-12-06 20:42:53.307 UTC [41] LOG: recibido pedido de apagado rápido
I, [2023-12-06T20:42:53.309208 #1] INFO -- : Enviando TERM a exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 110
110:signal-handler (1701895373) Recibido SIGTERM programando apagado...
2023-12-06 20:42:53.311 UTC [41] LOG: abortando cualquier transacción activa
2023-12-06 20:42:53.331 UTC [41] LOG: trabajador en segundo plano "logical replication launcher" (PID 50) salió con código de salida 1
2023-12-06 20:42:53.335 UTC [45] LOG: apagando
110:M 06 dic 2023 20:42:53.367 # Usuario solicitó apagado...
110:M 06 dic 2023 20:42:53.369 * Guardando la instantánea RDB final antes de salir.
2023-12-06 20:42:53.379 UTC [41] LOG: sistema de base de datos apagado
110:M 06 dic 2023 20:42:53.392 * Base de datos guardada en disco
110:M 06 dic 2023 20:42:53.393 # Redis está listo para salir, adiós...
FALLIDO
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' falló con retorno #<Process::Status: pid 3186 exit 134>
Ubicación del fallo: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec falló con los parámetros {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
bootstrap falló con código de salida 134
** FALLÓ EL BOOTSTRAP ** por favor desplázate hacia arriba y busca mensajes de error anteriores, puede haber más de uno.
./discourse-doctor puede ayudar a diagnosticar el problema.
ce5db16b179d8bbe8be1cc8898c2d89a9f8259e5f4f6d6bbeda8e6fa69723aa5
==================== FIN DEL REGISTRO DE RECONSTRUCCIÓN ====================
Fallo al reconstruir la aplicación.
Verificando tu nombre de dominio . . .
La conexión a forum.jimclair.com tuvo éxito.
Probablemente deberías eliminar cualquier plugin no estándar y reconstruir.
IntentoIntentando reiniciar el contenedor existente. . .
Se detectó arquitectura x86_64.
+ /usr/bin/docker run --shm-size=512m -d --restart=always -e LANG=en_US.UTF-8 -e RAILS_ENV=production -e UNICORN_WORKERS=2 -e UNICORN_SIDEKIQS=1 -e RUBY_GC_HEAP_GROWTH_MAX_SLOTS=40000 -e RUBY_GC_HEAP_INIT_SLOTS=400000 -e RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR=1.5 -e DISCOURSE_DB_SOCKET=/var/run/postgresql -e DISCOURSE_DB_HOST= -e DISCOURSE_DB_PORT= -e LETSENCRYPT_DIR=/shared/letsencrypt -e DISCOURSE_FORCE_HTTPS=true -e LC_ALL=en_US.UTF-8 -e LANGUAGE=en_US.UTF-8 -e DISCOURSE_HOSTNAME=forum.jimclair.com -e DISCOURSE_DEVELOPER_EMAILS=REDACTED -e DISCOURSE_SMTP_ADDRESS=in-v3.mailjet.com -e DISCOURSE_SMTP_PORT=587 -e DISCOURSE_SMTP_USER_NAME=495e2921d498a8d1d5ebb0afaccd7b1e -e DISCOURSE_SMTP_PASSWORD=REDACTED -e DISCOURSE_SMTP_DOMAIN=forum.jimclair.com -e DISCOURSE_NOTIFICATION_EMAIL=noreply@forum.jimclair.com -e LETSENCRYPT_ACCOUNT_EMAIL=REDACTED -h JimClairDiscourse-app -e DOCKER_HOST_IP=172.17.0.1 --name app -t -p 80:80 -p 443:443 -v /var/discourse/shared/standalone:/shared -v /var/discourse/shared/standalone/log/var-log:/var/log --mac-address 02:43:18:d7:5e:e0 local_discourse/app /sbin/boot
No se pudo encontrar la imagen 'local_discourse/app:latest' localmente
docker: Error response from daemon: pull access denied for local_discourse/app, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
Vea 'docker run --help'.
Error al reiniciar el contenedor.
==================== PLUGINS ====================
No se detectaron plugins no oficiales.
Vea https://github.com/discourse/discourse/blob/main/lib/plugin/metadata.rb para la lista oficial.
Versión de Discourse en forum.jimclair.com: NO ENCONTRADA
Versión de Discourse en localhost: NO ENCONTRADA
==================== INFORMACIÓN DE MEMORIA ====================
SO: Linux
RAM (MB): 998
total used free shared buff/cache available
Mem: 952 363 254 3 493 589
Swap: 2047 87 1960
==================== VERIFICACIÓN DE ESPACIO EN DISCO ====================
---------- Espacio en disco del SO ----------
Filesystem Size Used Avail Use% Mounted on
/dev/vda1 24G 7.7G 16G 33% /
==================== INFORMACIÓN DE DISCO ====================
Disk /dev/loop0: 73.9 MiB, 77492224 bytes, 151352 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 180.94 MiB, 189730816 bytes, 370568 sectors
Disk /dev/loop2: 40.86 MiB, 42840064 bytes, 83672 sectors
Disk /dev/vda: 25 GiB, 26843545600 bytes, 52428800 sectors
Disklabel type: gpt
Disk identifier: F62235F3-8D92-4E44-9154-0DCF72CBCB9D
Device Start End Sectors Size Type
/dev/vda1 2099200 52428766 50329567 24G Linux filesystem
/dev/vda14 2048 10239 8192 4M BIOS boot
/dev/vda15 10240 227327 217088 106M EFI System
/dev/vda16 227328 2097152 1869825 913M Linux extended boot
Las entradas de la tabla de particiones no están en orden de disco.
Disk /dev/vdb: 466 KiB, 477184 bytes, 932 sectors
==================== FIN DE LA INFORMACIÓN DE DISCO ====================
==================== PRUEBA DE CORREO ====================
Para una prueba robusta, obtenga una dirección en http://www.mail-tester.com/
Enviando correo a REDACTED . .
==================== ¡HECHO! ====================
Puede examinar la salida de este script con
LESS=-Ri less /tmp/discourse-debug.txt
