Discourse ne livre pas de pages Web, installation fraîche sur Linode Ubuntu 14.04
Hi there. I’m new to Discourse and new to Docker.
I’ve got a Linode running Ubuntu 14.04 LTS. It functions as a basic webserver with Apache listening on port 80 and serving a handful of PHP+MySQL websites.
I have an existing site host.com and I’d like to get Discourse running at subdomain.host.com. Since Apache is listening on host.com:80 I’ve tried setting Discourse to run at subdomain.host.com:8080
Unfortunately when I point my browser at subdomain.host.com:8080 it produces a “connection refused” error.
DNS isn’t an issue, subdomain.host.com:80 delivers Apache’s default webpage.
Installation and config
To install Docker then Discourse I followed the installation instructions on GitHub.
I edited the file containers/app.yml thusly so traffic incoming on host port 8080 is redirected to container port 80:
templates:
  - "templates/cron.template.yml"
  - "templates/sshd.template.yml"
  - "templates/web.socketed.template.yml"
## which TCP/IP ports should this container expose?
expose:
  - "8080:80"
# Removed:  - "2222:22" # fwd host port 2222 to container port 22 (ssh)
# Removed:  - "80:80"   # fwd host port 80   to container port 80 (http)
Running ./launcher bootstrap app or ./launcher rebuild app plus ./launcher start app complete without errors, and I confirm all looks okay with docker ps (trimmed):
root@www:/var/discourse# docker ps
CONTAINER ID        IMAGE                 COMMAND        ...    PORTS                  NAMES
ab********00        local_discourse/app   "/sbin/boot"   ...    0.0.0.0:8080->80/tcp   app
However, when I point Chrome at subdomain.host.com:8080 it gives me ERR_CONNECTION_REFUSED.
Confirmed with telnet subdomain.host.com 8080 from my Windows desktop:
C:\dir\dir>telnet subdomain.host.com 8080
Connecting To subdomain.host.com...Could not open connection to the host,
on port 8080: Connect failed
Discourse is failing to listen on port 80, but succeeds on port 22 after I re-enabled in app.yml and rebuild:
me@my-linode:/$ ./launcher enter app
root@www-app:/# apt-get-install telnet
root@www-app:/# telnet localhost 80
Trying ::1...
Trying 127.0.0.1...
telnet: Unable to connect to remote host: Connection refused
root@www-app:/# telnet localhost 22
Trying ::1...
Connected to localhost.
Escape character is '^]'.
SSH-2.0-OpenSSH_6.6.1p1 Ubuntu-2ubuntu2
telnet>
Log files
Looking through docker logs app there are a few warnings, and some port numbers that don’t look right to me:
Started runsvdir, PID is 29
ok: run: redis: (pid 41) 0s
41:M 30 Jun 12:16:57.444 * Redis 3.0.1 (00000000/0) 64 bit, standalone mode, port 6379, pid 41 ready to start.
41:M 30 Jun 12:16:57.445 # Server started, Redis version 3.0.1
41:M 30 Jun 12:16:57.445 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
41:M 30 Jun 12:16:57.446 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
ok: run: postgres: (pid 40) 0s
41:M 30 Jun 12:16:57.452 * DB loaded from disk: 0.006 seconds
41:M 30 Jun 12:16:57.453 * The server is now ready to accept connections on port 6379
Server listening on 0.0.0.0 port 22.
Server listening on :: port 22.
rsyslogd: invalid or yet-unknown config file command 'KLogPermitNonKernelFacility' - have you forgotten to load a module? [try http://www.rsyslog.com/e/3003 ]
rsyslogd: warning: ~ action is deprecated, consider using the 'stop' statement instead [try http://www.rsyslog.com/e/2307 ]
rsyslogd: Could no open output pipe '/dev/xconsole': No such file or directory [try http://www.rsyslog.com/e/2039 ]
2015-06-30 12:16:57 UTC [61-1] LOG:  database system was shut down at 2015-06-30 12:16:35 UTC
2015-06-30 12:16:57 UTC [40-1] LOG:  database system is ready to accept connections
2015-06-30 12:16:57 UTC [65-1] LOG:  autovacuum launcher started
supervisor pid: 43 unicorn pid: 67
41:M 30 Jun 12:21:58.015 * 10 changes in 300 seconds. Saving...
41:M 30 Jun 12:21:58.017 * Background saving started by pid 460
460:C 30 Jun 12:21:58.023 * DB saved on disk
460:C 30 Jun 12:21:58.024 * RDB: 0 MB of memory used by copy-on-write
41:M 30 Jun 12:21:58.117 * Background saving terminated with success
41:M 30 Jun 12:26:59.016 * 10 changes in 300 seconds. Saving...
41:M 30 Jun 12:26:59.018 * Background saving started by pid 786
786:C 30 Jun 12:26:59.026 * DB saved on disk
According to /bin/ps Docker appears to be proxying host port 8080 to container port 80:
root@www:/var/discourse# ps ax | grep -i dock
10647 ?        Sl     0:00 docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 8080 -container-ip 172.17.0.79 -container-port 80
I confess ignorance of iptables, but hunting through similar threads I’ve seen clues emerge from there, so here is output from iptables -L
root@www:/var/discourse# iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
fail2ban-ssh  tcp  --  anywhere             anywhere             multiport dports ssh
ACCEPT     all  --  anywhere             anywhere
REJECT     all  --  anywhere             127.0.0.0/8          reject-with icmp-port-unreachable
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTABLISHED
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:http
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:https
ACCEPT     tcp  --  anywhere             anywhere             state NEW tcp dpt:ssh
ACCEPT     icmp --  anywhere             anywhere
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:3000
LOG        all  --  anywhere             anywhere             limit: avg 5/min burst 5 LOG level debug prefix "iptables denied: "
DROP       all  --  anywhere             anywhere
Chain FORWARD (policy ACCEPT)
DOCKER     all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate RELATED,ESTABLISHED
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (1 references)
ACCEPT     tcp  --  anywhere             172.17.0.79          tcp dpt:http
Chain fail2ban-ssh (1 references)
REJECT     all  --  106.243.125.195      anywhere             reject-with icmp-port-unreachable
REJECT     all  --  43.255.189.23        anywhere             reject-with icmp-port-unreachable
RETURN     all  --  anywhere             anywhere
…and iptables -L -t nat
root@www:/var/discourse# iptables -L -t nat
Chain PREROUTING (policy ACCEPT)
DOCKER     all  --  anywhere             anywhere             ADDRTYPE match dst-type LOCAL
DOCKER     all  --  anywhere            !127.0.0.0/8          ADDRTYPE match dst-type LOCAL
Chain POSTROUTING (policy ACCEPT)
MASQUERADE  all  --  172.17.0.0/16        anywhere
MASQUERADE  tcp  --  172.17.0.79          172.17.0.79          tcp dpt:http
Chain DOCKER (2 references)
DNAT       tcp  --  anywhere             anywhere             tcp dpt:http-alt to:172.17.0.79:80
Should I really be running Nginx or HAProxy as suggested in other threads? I have a feeling this should be working without that sort of thing.
Many thanks in advance.
Okay, this seems partially fixed. It was largely an oversight on my behalf, and I’ll post it here to save anyone else tearing their hair out.
Short version:
Edit containers/app.yml to forward host port whatever (8080 in my case) to container port 3000, which is where Discourse is communicating web traffic:
expose:
  - "8080:3000"
Followed of course by ./launcher rebuild app
HOWEVER… while I can now browse to subdomain.host.com:8080 the resulting Discourse pages appear completely blank in Chrome. If I view-source there’s plenty of HTML, so I’m unsure why the browser isn’t rendering it. More on that later, hopefully.
Long version:
I trawled the log files:
root@www-app:/# ls -l /var/log
total 176
-rw-r--r-- 1 root   root        606 Jun 30 17:00 alternatives.log
drwxr-xr-x 2 root   root       4096 Jun 30 15:46 apt
-rw-r----- 1 syslog adm         272 Jun 30 14:41 auth.log
-rw-r--r-- 1 root   root       1218 Jun 30 17:00 dpkg.log
drwxr-xr-x 2 root   www-data   4096 Jun 30 10:12 nginx
-rw-r----- 1 syslog adm      154031 Jun 30 17:29 syslog
I looked through the syslog but didn’t see much to enlighten me in there. So I looked at the Nginx logs:
root@www-app:/# tail /var/log/nginx/error.log
2015/06/30 17:05:57 [emerg] 2026#0: bind() to unix:/shared/nginx.http.sock failed (98: Address already in use)
2015/06/30 17:05:57 [emerg] 2026#0: still could not bind()
2015/06/30 17:05:59 [emerg] 2030#0: bind() to unix:/shared/nginx.http.sock failed (98: Address already in use)
That didn’t look good. Back on the host file system I deleted /var/discourse/shared/standalone/nginx.http.sock as advised in several other threads, and restarted Discourse.
Then I decided to investigate Nginx a little closer.
root@www-app:/# less /etc/nginx/conf.d/discourse.conf
upstream discourse { server 127.0.0.1:3000; }
That looked like a clue. So I updated the host’s app.yml and rebuilt.
Now to uncover why the webpages that Discourse is serving are failing to render in the browser. Curiouser and curiouser.
1 « J'aime »
we need to add a host_run command to web.socketed. template.yml to delete that file on rebuild, this is about the third time or something
2 « J'aime »
Yes can you take that @riking? I agree it is happening too much.
1 « J'aime »
Thanks for that, great to see you guys responding to issues like this.
I’ve raised the blank pages issue separately, for anyone who wants to follow it:
https://meta.discourse.org/t/discourse-delivering-blank-web-pages-on-ubuntu-14-on-linode/30665
Happy for this thread to be closed.
1 « J'aime »
Not really the correct solution. On stage one is should delete any existing socket file, on stage 3 it should also do that.
We support boot stages like init.d does in our docker image.
Ce sujet a été automatiquement fermé après 3265 jours. Les nouvelles réponses ne sont plus autorisées.
