Installed Discourse in Docker, Cannot Connect
A user installed Discourse in Docker and initially faced connection issues, unable to access the site via lynx on port 44443. Logs showed services were running, but the container wasn’t accepting connections. After testing, it was determined that the issue was with the Docker port mapping. The user realized the container was accessible from within itself but not externally. The solution involved using a reverse proxy setup with Apache2 and HestiaCP, configuring the Discourse Docker container to use Unix sockets instead of direct port exposure, and removing Let’s Encrypt from the app.yml. The user then created custom Apache2 configuration templates to proxy requests to Discourse via the socket, ensuring proper SSL handling and redirecting HTTP to HTTPS. The final setup successfully integrated Discourse with the existing web server environment.
So I used the standard install doc and everything seemed to go fine. I then edited the app.yml to change ports used, commented out LetsEncrypt and rebuilt. Looks like it all went fine.
But when I try to connect via the most direct method:
$lynx https://127.0.0.1:44443
I get the following error:
Alert!: Unable to make secure connection to remote host.
I cannot even ping the port.
This make any kind of sense? Are there logs inside the container?
—edit to add----
$ sudo ./launcher logs app
run-parts: executing /etc/runit/1.d/00-ensure-links
run-parts: executing /etc/runit/1.d/00-fix-var-logs
run-parts: executing /etc/runit/1.d/01-cleanup-web-pids
run-parts: executing /etc/runit/1.d/anacron
run-parts: executing /etc/runit/1.d/cleanup-pids
Cleaning stale PID files
run-parts: executing /etc/runit/1.d/copy-env
Started runsvdir, PID is 43
ok: run: redis: (pid 56) 0s
**chgrp: invalid group: ‘syslog’**
ok: run: postgres: (pid 55) 0s
supervisor pid: 57 unicorn pid: 85
(57) Reopening logs
----edit to add more----
root@hestia-app:/shared/log/rails# tail -f *.log
==> production_errors.log <==
==> production.log <==
==> sidekiq.log <==
==> unicorn.stderr.log <==
I, [2021-08-06T00:56:35.859967 #85]  INFO -- : master done reopening logs
I, [2021-08-06T00:56:50.911700 #142]  INFO -- : worker=0 done reopening logs
I, [2021-08-06T00:56:50.911698 #152]  INFO -- : worker=1 done reopening logs
I, [2021-08-06T00:56:50.935834 #162]  INFO -- : worker=2 done reopening logs
I, [2021-08-06T00:56:50.941733 #233]  INFO -- : worker=7 done reopening logs
I, [2021-08-06T00:56:50.945447 #203]  INFO -- : worker=5 done reopening logs
I, [2021-08-06T00:56:50.947354 #172]  INFO -- : worker=3 done reopening logs
I, [2021-08-06T00:56:50.949949 #187]  INFO -- : worker=4 done reopening logs
I, [2021-08-06T00:56:50.953453 #213]  INFO -- : worker=6 done reopening logs
==> unicorn.stdout.log <==
Sidekiq PID 131 done reopening logs...
root@hestia-app:/var/log/nginx# tail *.log
==> access.letsencrypt.log <==
==> access.log <==
==> error.letsencrypt.log <==
==> error.log <==
Must be a docker error, cuz… everything else looks fine.
I just installed a bare apache container mapped to 8088, and it works fine from lynx
I entered the app again, and ran ps ax, and it appears that everything is working. It just seems that the container is not accepting connections.
root@hestia-app:/var/www/discourse# ps ax
    PID TTY      STAT   TIME COMMAND
      1 pts/0    Ss+    0:00 /bin/bash /sbin/boot
     43 pts/0    S+     0:00 /usr/bin/runsvdir -P /etc/service
     44 ?        Ss     0:00 runsv cron
     45 ?        Ss     0:00 runsv rsyslog
     46 ?        Ss     0:00 runsv redis
     47 ?        Ss     0:00 runsv postgres
     48 ?        Ss     0:00 runsv unicorn
     49 ?        Ss     0:00 runsv nginx
     50 ?        S      0:00 cron -f
     51 ?        Sl     0:00 rsyslogd -n
     52 ?        S      0:00 nginx: master process /usr/sbin/nginx
     53 ?        S      0:00 svlogd /var/log/redis
     54 ?        S      0:00 svlogd /var/log/postgres
     55 ?        S      0:00 /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
     56 ?        Sl     0:33 /usr/bin/redis-server *:6379
     57 ?        S      0:04 /bin/bash config/unicorn_launcher -E production -c config/unicorn.conf.rb
     64 ?        S      0:00 nginx: worker process
     65 ?        S      0:00 nginx: worker process
     66 ?        S      0:00 nginx: worker process
     67 ?        S      0:00 nginx: worker process
     68 ?        S      0:00 nginx: cache manager process
     79 ?        Ss     0:00 postgres: 13/main: checkpointer
     80 ?        Ss     0:00 postgres: 13/main: background writer
     81 ?        Ss     0:03 postgres: 13/main: walwriter
     82 ?        Ss     0:00 postgres: 13/main: autovacuum launcher
     83 ?        Ss     0:00 postgres: 13/main: stats collector
     84 ?        Ss     0:00 postgres: 13/main: logical replication launcher
     85 ?        Sl     0:13 unicorn master -E production -c config/unicorn.conf.rb
    113 ?        Ss     0:01 postgres: 13/main: discourse discourse [local] idle
    131 ?        SNl    0:48 sidekiq 6.2.1 discourse [0 of 5 busy]
    142 ?        Sl     0:06 unicorn worker[0] -E production -c config/unicorn.conf.rb
    152 ?        Sl     0:06 unicorn worker[1] -E production -c config/unicorn.conf.rb
    162 ?        Sl     0:07 unicorn worker[2] -E production -c config/unicorn.conf.rb
    172 ?        Sl     0:06 unicorn worker[3] -E production -c config/unicorn.conf.rb
    180 ?        Ss     0:00 postgres: 13/main: discourse discourse [local] idle
    187 ?        Sl     0:07 unicorn worker[4] -E production -c config/unicorn.conf.rb
    203 ?        Sl     0:07 unicorn worker[5] -E production -c config/unicorn.conf.rb
    213 ?        Sl     0:07 unicorn worker[6] -E production -c config/unicorn.conf.rb
    233 ?        Sl     0:07 unicorn worker[7] -E production -c config/unicorn.conf.rb
  11733 pts/1    Ss     0:00 /bin/bash --login
  11748 ?        S      0:00 sleep 1
  11749 pts/1    R+     0:00 ps ax
Okay, so I entered the app and installed lynx inside the discord docker, and I can get the welcome page there! So the install is working, the network mapping from in the docker out to the server is the issue.
Here is the docker ps output:
CONTAINER ID   IMAGE                 COMMAND        CREATED          STATUS          PORTS                                             NAMES
c6d0209e4e72   local_discourse/app   "/sbin/boot"   51 minutes ago   Up 51 minutes   127.0.0.1:8880->80/tcp, 127.0.0.1:4443->443/tcp   app
…and here is the app.yml info:
templates:
expose:
  - "127.0.0.1:8880:80"   # http
  - "127.0.0.1:4443:443" # https
params:
  db_shared_buffers: "2048MB"
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  UNICORN_WORKERS: 8
  DISCOURSE_HOSTNAME: [redacted]
  DISCOURSE_SMTP_ADDRESS: [redacted]
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: [redacted]
  DISCOURSE_SMTP_PASSWORD: "[redacted]"
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  DISCOURSE_SMTP_DOMAIN: [redacted]
  DISCOURSE_NOTIFICATION_EMAIL: [redacted]
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
Ah, I see what I did. The 8880:80 works fine, I was only testing the 4443:443 side. It did not work as there is a certificate error. I am intending to install and manage the certificate at the webserver level in the virtual host. I will post a final solution for those interested once I get it all working.
Install environment
Hestia Control Panel (For Server Management)
Apache2 (Webserver)
Discourse in Docker reverse proxied to Apache2
Let’sEncrypt not reverse proxied, but managed by Hestia in the www_root
  1. Setup unix sockets in app.yml (and rebuild):
  - "templates/web.socketed.template.yml"
  1. Remove port mapping and Let’sEncrypt from app.yml (and rebuild)
#  - "templates/web.ssl.template.yml"
#  - "templates/web.letsencrypt.ssl.template.yml"
#  - "80:80"   # http
#  - "443:443" # https
#  LETSENCRYPT_ACCOUNT_EMAIL: {your email, probably}
  1. Create Alternative apache2.conf templates for HestiaCP as follows (for those of you not using hestiacp, just realize that the %{replace tags}% are pretty standard and obvious if you look at any other apache2.conf file. The most important parts do not use many %{replace tags}%. Also note that the text standalone could be socket-only depending on your setup. Look to see what is in the /var/discourse/shared/ dir if you don’t remember.
{Custom Template}.stpl
<VirtualHost %ip%:%web_ssl_port%>
    ServerName %domain_idn%
    ProxyPreserveHost On
    ProxyRequests Off
    ProxyPass / unix:/var/discourse/shared/standalone/nginx.http.sock|http://localhost/
    ProxyPassReverse  / unix:/var/discourse/shared/standalone/nginx.http.sock|http://localhost/
    ServerAdmin %email%
    Alias /vstats/ %home%/%user%/web/%domain%/stats/
    Alias /error/ %home%/%user%/web/%domain%/document_errors/
    CustomLog /var/log/%web_system%/domains/%domain%.bytes bytes
    CustomLog /var/log/%web_system%/domains/%domain%.log combined
    ErrorLog /var/log/%web_system%/domains/%domain%.error.log
    <Directory %home%/%user%/web/%domain%/stats>
        AllowOverride All
    </Directory>
    <Directory %sdocroot%>
        AllowOverride All
        SSLRequireSSL
        Options +Includes -Indexes +ExecCGI
    </Directory>
    SSLEngine on
    SSLVerifyClient none
    SSLCertificateFile %ssl_crt%
    SSLCertificateKeyFile %ssl_key%
    %ssl_ca_str%SSLCertificateChainFile %ssl_ca%
    IncludeOptional %home%/%user%/conf/web/%domain%/%web_system%.ssl.conf_*
</VirtualHost>
{Custom Template}.tpl
<VirtualHost %ip%:%web_port%>
    %alias_string%
    ProxyRequests Off
    RewriteEngine On
    RewriteCond %{REQUEST_URI} !^.well-known/acme-challenge
    RewriteRule ^(.*) https://%domain_idn%/$1 [R=301,L]
        AllowOverride All
    </Directory>
        AllowOverride All
    </Directory>
    IncludeOptional %home%/%user%/conf/web/%domain%/%web_system%.conf_*
</VirtualHost>
Ah, I missed something above, you will also need this in each file:
RequestHeader set X-Forwarded-Proto https
