Discourse droplet לא ניתן להגיע אליו ביציאות 80,443 לאחר התקנה על Ubuntu 20.04
סיכום מבוסס בינה מלאכותית
Discourse Installation Issue on Ubuntu 20.04
The user, Pro_Remont, is experiencing issues accessing their Discourse installation on Ubuntu 20.04 after installation, despite not encountering any errors during the process. The installation was attempted in two ways: official GitHub (docker) and one-click install.
After investigation, pfaffman suspects that the issue may be due to hitting Let’s Encrypt rate limits, which can cause certificate errors. Pro_Remont shares the error log, which confirms the certificate issue.
pfaffman explains that the error is related to nginx failing to start due to the absence of a certificate, and not a firewall issue.
To resolve the issue, pfaffman recommends adding a second subdomain for the same IP address, as described in Setting up Let’s Encrypt with Multiple Domains. Alternatively, waiting a week would also resolve the issue. The solution worked for Pro_Remont.
I’m trying to install Discourse on ubuntu 20.04 LTS on Digital Ocean(on GCP as well, with the same result). Installed in 2 ways:
  1. Official from github(docker)
  2. One click install
    my domain: proremont.io
    SMTP provider - Mailgun (my mail domain: mail.proremont.io) dns record correct.
    There was no error during installation. But the Discourse was not accessible from the browser, curl. (same sitiation when I tried send curl request to localhost:80 and 433)Ping droplet IP adress without problem. UFW firewall disabled inside droplet, on Digital Ocean - settings 80 and 443 allowed.
    Can someone help me with this problem?
If you did a bunch of installs then you hit let’s encrypt rate limits.
you can see
  tail /var/discourse/shared/standalone/log/var-log/nginx/error.log
IF you see errors about certificates I’m right. You can wait a week or try to add another subdomain to the ticket request as described in Setting up Let’s Encrypt with Multiple Domains.
A 3rd party tool suggests both the ports are blocked. This means either a firewall on your VPS or cloud provider is blocking those ports. You may want to disable the digital ocean firewall and check UFW on ubuntu
its my tails outpus:
2022/03/07 13:59:32 [emerg] 9889#9889: cannot load certificate "/shared/ssl/proremont.io.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0909006C:PEM routines:get_name:no start line:Expecting: TRUSTED CERTIFICATE)
2022/03/07 13:59:33 [emerg] 9892#9892: cannot load certificate "/shared/ssl/proremont.io.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0909006C:PEM routines:get_name:no start line:Expecting: TRUSTED CERTIFICATE)
2022/03/07 13:59:34 [emerg] 9894#9894: cannot load certificate "/shared/ssl/proremont.io.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0909006C:PEM routines:get_name:no start line:Expecting: TRUSTED CERTIFICATE)
But I dont Inderstand, why , firewall disabled on droplet, and on DO settings I add rules to 80 and 443
That is an error about certificates.
It has nothing to do with firewall and everythig to do with nginx failing to start because you don’t have a certificate.
but acme.sh was downloaded and started during installation. How can I fix it?
See the link in my previous message and add a second subdomain for the same IP address. www, would be a good choice. Or wait a week. I did my best to describe the problem and solution above.
Thank You, Its work for me
