Discourse Events
Hi there. I’m having some issues with the date/time format.
For some reason it is showing a mix of notation with date behind month and 12H time even when the timezone is Europe.
  • The post excerpt is different between events that have a start and end time, and all day events. The latter showing day before month, and the other showing 12H time with day behind month.
  • Then the event cards are different again between the date/time shown on the card, and the date/time shown in the popup. The card showing 24H time with day behind month, and the popup showing 12H time with day in front of month. A weird combo either way.
  • Setting the ‘display local time’ along with the correct timezone in the event settings makes no difference.
In all cases is should be day in front of month and 24H time in our region.
Thank you for this plugin, however I am having a small issue and I’m not sure if it’s my configuration or not.
I have enabled Events in my category and have a set a Default Calendar View of Year and a Topic Sorting of “Event Date”.
The Events are showing properly but it doesn’t automatically go to todays date. That is past events are showing at the top of the list.
I was sort of expecting the year view to show the current date at the top of this list? Was I misguided in this assumption? If not is there another setting I can set to always jump to the latest date?
TIA
Yeah, this is due to it being a yearly calendar rather than an ‘Agenda’ per se.
And it is a primary reason for why I made this theme component:
Thanks @nathank that has worked well.
How does one ask for a proper Agenda view on the bare plugin?
This is an old one along that theme, but perhaps it is time for a refreshed and more articulated Feature request:
I’d like to create a livestream event, but when pasting an URL other than from Youtube no livestream button is displayed. So only Youtube and Zoom are supported?
Is it possible to create a livestream event in conjunction with another chat channel? I don’t want a new channel for this event but use an existing channel.
Looks like only
youtube.com|youtu.be|twitch.tv|zoom.us|kick.com|tiktok.com|instagram.com|facebook.com
are now supported: :disappointed_face: see discourse/plugins/discourse-events/config/settings.yml at main · discourse/discourse · GitHub
it used to work with Vimeo and other platforms.
