Discourse installation on OCI ampere A1
I am trying to install discourse on OCI ampere a1 instance and the unicorn process is failing for me, when I check the logs it shows this. Any idea ?
I, [2022-07-04T04:55:03.949240 #1286]  INFO -- : Refreshing Gem list
I, [2022-07-04T04:55:06.123255 #1286]  INFO -- : listening on addr=127.0.0.1:3000 fd=10
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/actionview_precompiler-0.2.3/lib/actionview_precompiler/precompiler.rb:29: [BUG] Segmentation fault at 0x9999f332b3efba58
ruby 2.7.6p219 (2022-04-12 revision c9c2245c0a) [aarch64-linux]
My OCI arm based installation went ok and the discourse server is live. I firstly tried on 2022-Dec, everything went ok on an ubuntu ARM server.
We have some error warning messages below, but it still load the server.
I, [2023-03-04T22:17:55.978057 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
Bundler::PathError: The path `/var/www/discourse/vendor/bundle/ruby/3.2.0/bundler/gems/sprockets-f4d3dae71ef2` does not exist.
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/source/path.rb:209:in `load_spec_files'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/source/git.rb:205:in `load_spec_files'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/source/path.rb:107:in `local_specs'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/source/git.rb:172:in `specs'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/lazy_specification.rb:82:in `materialize_for_installation'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:195:in `map!'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:195:in `specs_for_dependency'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:33:in `block in for'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:22:in `loop'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:22:in `for'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/spec_set.rb:79:in `materialize'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/definition.rb:209:in `missing_specs'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/definition.rb:213:in `missing_specs?'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/installer.rb:255:in `resolve_if_needed'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/installer.rb:82:in `block in run'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/process_lock.rb:12:in `block in lock'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/process_lock.rb:9:in `open'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/process_lock.rb:9:in `lock'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/installer.rb:71:in `run'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/installer.rb:23:in `install'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/cli/install.rb:62:in `run'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/cli.rb:260:in `block in install'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/settings.rb:131:in `temporary'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/cli.rb:259:in `install'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/cli.rb:34:in `dispatch'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/cli.rb:28:in `start'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/exe/bundle:45:in `block in <top (required)>'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
  /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/exe/bundle:33:in `<top (required)>'
That warning happens with every git sourced gem, but the install proceeds just fine.
