当我运行 bundle install 时,我遇到了这个错误:安装 xorcist (1.1.2) 时出错,Bundler 无法继续。
有人能帮忙吗?
这是我目前正在遵循的文档:
如果这有帮助,这是完整的错误信息。
在 Gemfile 中:
unf 被解析为 0.1.4,它依赖于
unf_ext
Gem::Ext::BuildError:错误:构建 gem 原生扩展失败。
当前目录:/var/lib/gems/2.7.0/gems/xorcist-1.1.2/ext/xorcist
/usr/bin/ruby2.7 -I /usr/lib/ruby/2.7.0 -r ./siteconf20211120-12641-1468e8.rb extconf.rb
mkmf.rb 找不到 ruby 的头文件,位于 /usr/lib/ruby/include/ruby.h
你可能需要安装单独的 ruby 开发环境包,例如 ruby-dev 或 ruby-devel。
extconf 失败,退出代码 1
Gem 文件将保留在 /var/lib/gems/2.7.0/gems/xorcist-1.1.2 以供检查。
结果记录在 /var/lib/gems/2.7.0/extensions/x86_64-linux/2.7.0/xorcist-1.1.2/gem_make.out
/usr/lib/ruby/2.7.0/rubygems/ext/builder.rb:97:in `run'
/usr/lib/ruby/2.7.0/rubygems/ext/ext_conf_builder.rb:48:in `block in build'
/usr/lib/ruby/2.7.0/tempfile.rb:291:in `open'
/usr/lib/ruby/2.7.0/rubygems/ext/ext_conf_builder.rb:30:in `build'
/usr/lib/ruby/2.7.0/rubygems/ext/builder.rb:167:in `block in build_extension'
/usr/lib/ruby/2.7.0/rubygems/ext/builder.rb:163:in `synchronize'
/usr/lib/ruby/2.7.0/rubygems/ext/builder.rb:163:in `build_extension'
/usr/lib/ruby/2.7.0/rubygems/ext/builder.rb:208:in `block in build_extensions'
/usr/lib/ruby/2.7.0/rubygems/ext/builder.rb:205:in `each'
/usr/lib/ruby/2.7.0/rubygems/ext/builder.rb:205:in `build_extensions'
/usr/lib/ruby/2.7.0/rubygems/installer.rb:844:in `build_extensions'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/rubygems_gem_installer.rb:71:in `build_extensions'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/rubygems_gem_installer.rb:28:in `install'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/source/rubygems.rb:200:in `install'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/installer/gem_installer.rb:54:in `install'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/installer/gem_installer.rb:16:in `install_from_spec'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/installer/parallel_installer.rb:186:in `do_install'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/installer/parallel_installer.rb:177:in `block in worker_pool'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/worker.rb:62:in `apply_func'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/worker.rb:57:in `block in process_queue'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/worker.rb:54:in `loop'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/worker.rb:54:in `process_queue'
/var/lib/gems/2.7.0/gems/bundler-2.2.31/lib/bundler/worker.rb:91:in `block (2 levels) in create_threads'
在 Gemfile 中:
xorcist
