This plugin is intended to send an email alert to all administrators whenever a user logs in from a suspicious IP address. It does so by extracting the IP from the latest authentication token (using the client_ip
field), checking this IP against a blocklist defined in the site settings (ip_alert_suspicious_ips
), and if the IP matches any blocked pattern, it sends a warning email to all admin users.
Observed Error:
Despite the plugin code seeming correct and following standard Discourse plugin patterns, I still encounter the generic “Oops – The software powering this discussion forum encountered an unexpected problem” error upon login. The error logs do not show clear indications from our [DiscourseIpAlert]
log messages, and the stack trace does not pinpoint an issue directly within our plugin code.
Current Status:
I have reviewed and revised the plugin multiple times, including verifying site settings and ensuring that the hook (on(:user_logged_in)
) is correctly registered. The IP extraction and email sending logic also appear to be implemented properly, yet the 500 Internal Server Error persists without a clear stack trace linking it to our plugin.
Any help?
plugin.rb:
# frozen_string_literal: true
# name: discourse-ip-alert
# about: Sends an email alert when a user logs in from a suspicious IP address.
# version: 0.7
# authors: OrkoGrayskull (revised)
# required_version: 3.5.0
enabled_site_setting :ip_alert_enabled
enabled_site_setting :ip_alert_suspicious_ips
module ::DiscourseIpAlert
PLUGIN_NAME = "discourse-ip-alert"
require 'ipaddr'
require 'mail'
# Extracts the IP address from the latest authentication token
def self.extract_ip(user)
token = UserAuthToken.where(user_id: user.id).order(created_at: :desc).first
ip = token&.attributes["client_ip"]
Rails.logger.info("[DiscourseIpAlert] extract_ip: Extracted IP from UserAuthToken: #{ip.inspect}")
ip
rescue => e
Rails.logger.error("[DiscourseIpAlert] extract_ip error: #{e.message}")
nil
# Checks if the given IP address is present in the blocklist
def self.ip_blocked?(ip_address)
return false if ip_address.blank?
blocked_ips = SiteSetting.ip_alert_suspicious_ips.split(",").map(&:strip)
Rails.logger.info("[DiscourseIpAlert] ip_blocked?: Blocked IPs: #{blocked_ips.inspect}")
blocked_ips.any? do |blocked|
if blocked.include?('*')
regex = Regexp.new("^" + Regexp.escape(blocked).gsub('\\*', '\\d{1,3}') + "$")
Rails.logger.info("[DiscourseIpAlert] ip_blocked?: Comparing #{ip_address} with wildcard regex #{regex.inspect}")
ip_address.match?(regex)
else
begin
result = IPAddr.new(blocked).include?(ip_address)
Rails.logger.info("[DiscourseIpAlert] ip_blocked?: Comparing #{ip_address} with #{blocked}: #{result}")
result
rescue IPAddr::InvalidAddressError => e
Rails.logger.error("[DiscourseIpAlert] ip_blocked?: Invalid IP in blocklist: #{blocked} (#{e.message})")
false
rescue => e
Rails.logger.error("[DiscourseIpAlert] ip_blocked? error: #{e.message}")
false
# Sends a warning email to all admins
def self.send_warning_email(user, ip_address)
admin_emails = User.where(admin: true).pluck(:email)
return if admin_emails.empty?
subject = "⚠️ Warning: Login from a Suspicious IP!"
body = <<~BODY
Attention!
The user #{user.username} (#{user.email}) has logged in from the IP address #{ip_address},
which has been flagged as suspicious.
Please review this account.
BODY
admin_emails.each do |email|
begin
mail = Mail.new do
from ENV['DISCOURSE_NOTIFICATION_EMAIL'] || 'no-reply@example.org'
to email
subject subject
body body
Rails.logger.info("[DiscourseIpAlert] Sending warning email to #{email}")
mail.deliver!
rescue => e
Rails.logger.error("[DiscourseIpAlert] Error sending email to #{email}: #{e.message}")
rescue => e
Rails.logger.error("[DiscourseIpAlert] send_warning_email error: #{e.message}")
# Processes the user login: extracts the IP, checks the blocklist, and sends a warning email if necessary
def self.process_user_login(user)
Rails.logger.info("[DiscourseIpAlert] process_user_login for user: #{user.username}")
ip_address = extract_ip(user)
unless ip_address
Rails.logger.warn("[DiscourseIpAlert] No IP address extracted – skipping further processing.")
return
if ip_blocked?(ip_address)
Rails.logger.warn("[DiscourseIpAlert] Suspicious IP detected: #{ip_address}")
else
Rails.logger.info("[DiscourseIpAlert] IP #{ip_address} is considered safe.")
rescue => e
Rails.logger.error("[DiscourseIpAlert] process_user_login error: #{e.message}")
after_initialize do
Rails.logger.info("[DiscourseIpAlert] after_initialize: Plugin is being integrated into the login process.")
# Register the hook that is called on every user login
on(:user_logged_in) do |user|
begin
Rails.logger.info("[DiscourseIpAlert] on(:user_logged_in) hook called for user: #{user.username}")
::DiscourseIpAlert.process_user_login(user)
rescue => e
Rails.logger.error("[DiscourseIpAlert] Error in on(:user_logged_in) hook: #{e.message}")
config/settings.yml:
ip_alert_enabled:
default: false
client: true
type: bool
description: "Enable the IP alert"
ip_alert_suspicious_ips:
default: "192.168.1.1,203.0.113.0/24"
client: true
type: string
description: "List of suspicious IP addresses (comma-separated)"
