Hello
When I installed Discourse it didnt let me run chmod 700 containers and wont let me setup
Thanks for help
Hello
Thanks for help
From /var/discourse please list contents (ls), and check if the directory is there:
[maiki@disc discourse_docker]$ ls
bin discourse-doctor launcher samples templates
cids discourse-setup LICENSE scripts tests
containers image README.md shared
Ah, I see. You’ve got the wrong the repo:
sudo -s
git clone https://github.com/discourse/discourse_docker.git /var/discourse
cd /var/discourse
You want https://github.com/discourse/discourse_docker.git (with _docker).
Looks like I’m going to have to install linux for the 4th time. Thanks ![]()
Will update when I have somethin
You can probably remove that directory and start over without re-installing… but that’s how I learned, so go for it! ![]()
When I did that the first time it would just not let me make the directory again.
(I’m trying to learn so I can install my 2013 build with a modified launcher lol)
This is what it looked like
You need to be root.
sudo su -
First.
You cloned the wrong repo and typed cs rather than cd.
I would recommend that you follow the standard install instructions more carefully. And maybe try to copy and paste…
