I’m following off this guide discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub to install discourse/docker/ on digitalocean. When I get to .the point where I need to type in ./discourse-setup
I get told that there is no such file. I’m in root as well am I suppose to type something before typing ./discourse-setup
in which directory you are now? You must be in Discourse installation path (in most cases ~/var/discourse)
I’m in /var/discourse but ./disourse-setup still isn’t working. This is what it gives me below
bash: ./discourse-setup: No such file or directory
I did everything correctly before this step. I remember running into this problem on my last droplet. Can’t remember how i fixed it.
check spelling and make sure you have discourse-setup file by running ls command
:var/discourse$ ls
Resolved:
I put this:
git clone GitHub - discourse/discourse_docker: A Docker image for Discourse · GitHub
Instead of this: git clone GitHub - discourse/discourse_docker: A Docker image for Discourse · GitHub /var/discourse
Thank you for the help
