After I ran ./launcher rebuild app for upgrading from 2.9.0.beta11 to beta14 (which successfully completed) , neither the other users nor I could access the Discourse forum. It showed 5 dots moving endlessly.
Update: when disabling JavaScript it can show the contents
Update: Finally found that it is due to the customized theme.
Yep have contacted and still waiting for the response. Cuz I found others have same error message in logs as well so wondering whether it is Discourse problem
The provider said they can ping the website so was not their fault.
Actually it can access the /admin/upgrade to upgrade, also can show contents when disable JavaScript.
