Discourse logging options
Are there somewhere configuration options for logging?
I want to prevent discourse to log messages which are currently written by users. Is this somehow possible?
Hi there, can you try to explain again? It’s not clear what you’re asking for here, sorry!
Well, in discourse/rails/production.log every message is logged, like
Started POST "/posts" for 1.15.7.3 at 2020-11-12 13:46:27 +0000
Processing by PostsController#create as */*
  Parameters: {"raw"=>"This is a message which shouldn't be logged in my eyes"
And what are you wanting to change?
I don’t want to see these messages in the log, if possible.
To filter a specific parameter in Rails, you can do this (old method before “filter_attributes”, see below) via a plugin:
Rails.application.config.filter_parameters += [
  :raw,
  :signature,
  :return_url,
  :api_url,
  :access_token_url,
  :code
You can also use:
 filter_attributes
See also filter_attributes and other good info on this here:
Hope this helps @sbernhard
See also:
