Bitnami Discourse 2.6.0-0
support code: c3100986-c3c7-bbfe-d6c5-4df60d77b7f5
VM Debian
Hi, I have a question how to connect my Discourse with Office365. Is there any possibility to connect without plugin?
Also when I execute in folder:
cd /opt/bitnami/apps/discourse/htdocs
command: RAILS_ENV=production bundle exec rake plugin:install repo= https://github.com/discourse/discourse-plugin-office365-auth
I have an information:
Plugin directory, /opt/bitnami/apps/discourse/htdocs/plugins, already exists.
david
(David Taylor)
January 18, 2021, 11:17am
3
No, you will need to use a plugin
Unfortunately we can’t support the Bitnami installation here. The only installation we (the discourse team) support is discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub
But on Bitnami forum they told me:
https://community.bitnami.com/t/discourse-login-office365/91026/2
Thanks for using Bitnami. Your question is related to a plugin for the Discourse application, can you open a new question on their support system? Note they can provide you with better support on their product than we can.
So what can I do?
david
(David Taylor)
January 18, 2021, 11:25am
5
We recommend that you do not use bitnami to install Discourse: Troubleshooting Bitnami Installations
