Discourse は初回訪問時にヘッダーのみを読み込み、完全なアプリケーションをロードするにはリフレッシュが必要
Afternoon all, been stuck on this for a few days. My wack-a-mole approach is not working and haven’t been able to find a post on meta that directly addresses this problem. If I’m missing it, please share the link.
At any rate, has anyone had issues with Discourse only loading the header on mobile devices? I’ve tried turning off mobile layouts, setting “Latest” for the default view and a laundry list of other things.
Here’s a quick look at the issue.
Can you reproduce in Safe Mode ?
It looks like you have a broken theme customization.
Let me give it a shot.
Can’t reproduce in safe mode because when you go to safe mode it immediately refreshes the app and loads the home screen properly.
That’s because
So you should fix that.
こんにちは @pfaffman、まだこの件に取り組んでいます。すべての上書き設定を確認し、問題を引き起こす可能性のあるものをリセットしましたが、効果はありませんでした。また、すべてのプラグインが破損していないか確認しましたが、問題は見つかりませんでした。
          - git clone https://github.com/discourse/discourse-oauth2-basic.git
          - git clone https://github.com/discourse/discourse-patreon.git
          - git clone https://github.com/discourse/discourse-plugin-linkedin-auth.git
          - git clone https://github.com/discourse/discourse-plugin-office365-auth.git
          - git clone https://github.com/discourse/discourse-policy.git
          - git clone https://github.com/discourse/discourse-push-notifications.git
          - git clone https://github.com/discourse/discourse-saved-searches.git
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/discourse/discourse-spoiler-alert.git
          - git clone https://github.com/discourse/discourse-staff-notes.git
          - git clone https://github.com/discourse/discourse-tooltips.git
          - git clone https://github.com/discourse/discourse-voting.git
          - git clone https://github.com/communiteq/discourse-sitemap.git
          - git clone https://github.com/angusmcleod/discourse-quick-messages.git
          - git clone https://github.com/angusmcleod/discourse-locations.git
          - git clone https://github.com/angusmcleod/discourse-question-answer.git
          - git clone https://github.com/angusmcleod/discourse-ratings.git
          - git clone https://github.com/angusmcleod/discourse-topic-previews.git
          - git clone https://github.com/angusmcleod/discourse-layouts
          - git clone https://github.com/procourse/discourse-full-screen-videos-plugin.git
          - git clone https://github.com/procourse/procourse-static-pages.git
          - git clone https://github.com/featheredtoast/discourse-pwned-passwords.git
          - git clone https://github.com/iunctis/discourse-formatting-toolbar.git
          - git clone https://github.com/jannolii/discourse-topic-trade-buttons.git
          - git clone https://github.com/jgujgu/discourse-blocks.git
          - git clone https://github.com/LeoDavidson/discourse-reset-bump.git
          - git clone https://github.com/rux-pizza/discourse-awesome-bbcodes.git
          - git clone https://github.com/sekhat/discourse-yuml.git
          - git clone https://github.com/synweap15/discourse-voice-record.git
          - git clone https://github.com/unfoldingWord-dev/discourse-mermaid.git
          - git clone https://github.com/jomaxro/discourse-plugin-site-setting-override.git
          - git clone https://github.com/discourse/discourse-data-explorer.git
          - git clone https://github.com/cpradio/discourse-plugin-replygif.git
          - git clone https://github.com/merefield/discourse-onebox-assistant.git
そのため、Chrome で監査を実行し、以下の結果が得られました。何か手がかりとなるものは見えますか?
カスタム CSS をすべて削除してみましたが、何も変わりませんでした。 :neutral_face:
ブラウザの開発者ツールを開き、コンソールタブで警告やエラーがないか確認してください。
コンソールでエラーなしの200件すべて。最近、サイトログに同じ問題が多数表示されていることが判明しました……今は、この大量のJavaScriptを読み解く方法を学ぶ必要があります。
@falco@pfaffman が以前おっしゃった通り、テーマまたはテーマのカスタマイズに問題があります。テーマの JavaScript に構文エラーが存在しています。問題の箇所を特定するために、インストールされているテーマコンポーネントやカスタムテーマを一つずつ削除して確認する必要があります。
ありました。Easy Footer コンポーネントがずっと原因でした。ガッカリ。笑
みなさん、ありがとう!!
