Discourse プラグインのテストが失敗しています
I am trying to run tests for a single plugin using
bundle exec rake plugin:spec["discourse-details"]
But its failing with the error
An error occurred while loading ./plugins/discourse-presence/spec/presence_manager_spec.rb.
Failure/Error: UserOption.create(user_id: id)
NoMethodError:
  undefined method `text_size_key' for #<UserOption:0x00007f84ddd6da80>
  Did you mean?  text_size
                 text_size=
# ./app/models/user.rb:1222:in `create_user_option'
# (eval):17:in `block (2 levels) in run_file'
# ./spec/rails_helper.rb:65:in `<top (required)>'
# ./plugins/discourse-presence/spec/presence_manager_spec.rb:1:in `require'
# ./plugins/discourse-presence/spec/presence_manager_spec.rb:1:in `<top (required)>'
This persists for every plugin I tried. My local discourse instance is in the latest version
Did you try to rails migrate you test database?
Oh I didn’t and it fixed the issue. thank you @j.jaffeux
