Discourse Post Removal Appeal
A user, becl, had their post removed by the System account, despite containing only CSS and HTML code, similar to other posts in the same thread. becl is confused and wants to appeal the decision, but initially couldn’t find a way to do so. With help from Falco, becl discovered they can reply to the removed post, which is addressed to the System account, likely to be seen by a moderator or admin.
Hi, I am asking this question regarding the Discourse forum not my own. I posted yesterday regarding House Ads. The post had code in it I wanted advice on which was CSS and HTML that is not working. There was nothing bad in the post and I have seen others in the same thread posting code. I’m really confused.
I got up this morning and noticed it had been removed by the System account. It says I can appeal the decision but I can’t see anywhere I can do that?
Any ideas?
Can you reply the message with the warning you got?
Thanks Falco. I didn’t think of looking. Yes I can reply to the post. It is an account called system so I guess a moderator or admin will get the message.
