With huge thanks to the sponsorship of @Hifihedgehog and the community of:
This has been brought back into compatibility and is no longer broken with 3.2.
NB: as per The Team and Sam, it is intended that the Reactions plugin will take on the additional features of this plugin (mainly the ability for multiple reactions) at some point in the future and hopefully (not yet confirmed) this will include provision of a migration tool.
For those who are interested, this fork maintained by SJTU Shuiyuan community staff also works: ( also installing this version will destroy your data used in the primary repo , see @merefieldās post below)
Also I might point out though, on this fork, there are no:
Front end tests
Working back-end tests
GitHub workflow
Modern linting configs
Which are now implemented on the primary repo
Also installing this version will destroy your data used in the primary repo
I see no warning of this in the README.
So I cannot recommend people even try that fork unless on a fresh instance with no history or you intend to rely on the author to maintain things in the future ā¦
hmmm ⦠no doubt some significant effort has been put into it, but not actively communicating and sharing this work with the community is not ideal because it leads to some level of duplication and in this case it destroys the data used in the primary repo! That alone should have been a really good reason to PR so the approach could have been reviewed and harmonised across the forks. Now these forks are incompatible and if you install this one, there is no going back!
There was a change that ruined it, they moved the retorts in-line with the post controls, this ruined it on mobile, if the retort container stayed above the post controls like in this post Discourse Retort - #383 by Vaping_Community it would still be amazing, the ability to retort multiple times was a feature enjoyed by all
The new reaction plugin is good but it shows only one reaction.
Is it this line in the code that decides where to put the retort-container?
Ok so I did a thing but I have no idea what Iām doing⦠Iāve been using this plugin since 2018
@merefield Please advise how to credit on my GIT, I really have no clue on how anything works
Git is here: https://github.com/GrubbyVc/Retort-Reloaded
I cloned the retort plugin and edited it to display the retort-container above the controls again, this allows for multiple retorts on mobile. I wanted to change it only for mobile but didnāt know how.
Generally itās bad practice to create a new repo with a new name.
What you should consider doing is forking the main repo (which is easy there is a simple button), apply your changes to your fork and then later once you are fully happy and if you think the changes might be generally useful you PR to the main repo. Someone (usually the āmaintainerā) will review your PR, possibly make some suggestions, allow you to update your PR and then merge it into the main repo.
The main reason for doing this is that then all maintenance activity can be focussed on one repo which is far far more efficient. (which you will possibly discover when there is a breaking change!)
Hi all. Weāre big fans of Retort over on my Community. The latest discourse versions are making the plugin incompatible. See here. Iām trying, slowly, to make proper updates to the plugin but javascript is not my strongest area so am struggling to get it to work.
As part of our continuous effort to improve the Discourse codebase, weāre removing uses of the legacy āwidgetā rendering system, and replacing them with Glimmer components.
Can anyone take a look at the plugin and this notice and comment/advise as to what is needed? Maybe Iāll figure it out but wanted to bring it up that this plugin needs some TLC. Any help or contributions would be appreciated. Iām not sure if Iāve even done it properly but I have a draft PR open that is definitely a work in progress.
As I understand it, the official Reactions function still doesnāt support multiple reactions per user. As some of us argued all along, this was a poor design choice from the beginning. People should be able to express multiple reactions, and those tools which support that are simply a better experience.
Until thatās changed in Reactions somehow, losing Retort would be tragic. I hope someone can update it to keep it working. Just want to thank anyone who is working on this or might consider itā¦
It really depends. Many platforms only have 1 direct in post reaction. Depending on the community this is preferred to avoid an emoji smorgasbord mess.
I personally like Retort as at the time it gave a boost vs simple bland likes. I even had both reactions & retort on one of my forums. Worked well as most were conservative with number of emojis used.
The post above yours if you have knowledge he needs it could help to get Retort working again.
.I am sure with the team saying they are planning to add multiple reactions it will come. It just maybe not high on the priority list to implement with other projects currently having priority.
With updating official Plugin , Theme , Theme component and even core with the big changes needed takes up a fair amount of resources to meet internal deadlines.
Whatās great about Retort is communities can set a limited number of meaningful reactions. Beyond those, people can include whatever emoji in a normal reply post.
So the choice isnāt stuck between just-1 or āsmorgasboardā.
I really hope the multiple-reactions official support will arrive. The transition toward that for those at risk of losing Retort is potentially very awkward. Much appreciation to everyone who has been and will in the future be able to help with this.
