Works perfectly. Thanks for your swift action
I did installed this Retort plugin recently and its work fine thank you for the nice plugin
Iām facing two bugs:
- When I did installed Retort plugin Iād started to get an error with Rating plugin (I did reported at Rating Plugin Cat.)
- Iād just tried Retort functionality with Firefox last version (Win 10), Iād noticed that when I click on the smiley icon to react, Iām getting my screen darkened but without the icons to react from (not even there white background). If I click again anywhere, the screen get back normal. No error log on this. But when Iām doing the same with Chrome at the same PC, there is no problems. Everything working as expected.
Edit:
Iām getting the same bug at Chrome too. For testing, Iām using my site opened on two tabs with different user names at the same Chrome -last version. (Normally you canāt do it because of cookies but Iām having one tab opened this domain https://community⦠and the other https://www.communityā¦). One of them is working fine, the other is acting as explained above with Firefox!.
Edit 2:
Itās interesting. I did tried the same scenario of two tabs at Firefox and I discovered something strange. If your site domain start with :// then you have a problem. If your site domain starting with ://www. then the plugin is working fine!.
So itās seems that this may be the issue of whom having problems depends on there site domain setup!
I hope this could help you to debug and fix the real reason.
Unfortunately I really canāt imagine anything in Retort being affected by something like this. Are you able to see this erratic behaviour with the regular emoji picker in Discourse? Are you able to repro on discourse-babble.com?
No Iām not. I just tried it in both tabs. Itās working fine.
I just tried at discourse-babble.com from my Chrome & Firefox and it was working just fine too!
The reason maybe something else but this is what I was able observe from here. It was strange to have this exact behavior of Chrome and Firefox effected if I had the www sub domain or not! And its effecting only the behavior of Retort for that I thought you are the only one who could help!
Edit:
You are right. It wasnāt related to the sub domain type. It was happening randomly. When I logout and login with different user, it was working sometimes, other times not! I lost what could be the reason but its still happening randomly!
They donāt; retorts are stored in a completely separate fashion to likes in
the system. Tying that sort of stuff into this plugin will make it much
more prone to breakage, so Iād be hesitant to introduce this kind of thing.
I must say I have the same issue with current safari on OS Sierra.
More often than not, the grey overlay occurs and shows no emojis.
It seems to work more often on mobile versions of Safari at this stage.
I know others on the forum have the issue too, so they just donāt use it.
I might try to do some further testing myself.
Iām very sad to say this but the plugin does not work with version 1.8.0. The plugin settings appear in the backed but the button is not showing on posts. Seems that 1.8 did some breaking changes as other plugins stopped working too.
Current version: 1.8.0.beta6
http://discourse-babble.com is running the latest version of retort and Discourse, and seems to work alright. Any other circumstances you can identify to recreate this?
Thats weird. I double checked, everything seems to be correct. The plugin is active, changing settings does not affect anything.
The only errors logged in the console are caused by application.js and ember_jquery.js:
Hereās my plugin list, maybe you know a plugin that caused problems with Retort in the past?
If thereās any other way to debug this behaviour Iām ready to do so, but I donāt have a clue about both Ruby and Ember.
Hello, Iāve downloaded this plugin, and also tested the plugins on your test site. Unfortunately itās not working for me either, as the guy above said thereās no emoticon to select in the post menu. I looked in the log and didnāt see any errors.
Thanks for the report; there was a conflict with the latest discourse version. Updating to the latest should fix it.
After running the updates it is now working fine.
Thanks for your aweome work!
We are having a bit of an issue on our forum. It seems for some users (myself included), when they click on an existing reaction or try to add a reaction that has already been used, the count for that reaction doesnāt automatically update. If you refresh the page, the count updates, but if you donāt know to do that it looks like itās just not working. Until another user pointed out the refresh, I assumed it wasnāt working for me so I stopped using it. Iām using Chrome, another user has reported the same behavior on Firefox.
Also, random dark screens with no emoji picker here as well for several users across browsers and platforms. Iāve found a log out and back in to the forum usually fixes it.
Seeing the same bug here
Thanks for the report. This should now be fixed in latest.
Hi there;
Hey there, Iāve installed the plugin, however, the button/emoji are not appearing below the topics. Is there any additional step i need to take of is it not working with the latest Discourse version?
The plugin is activated!
discourse-babble.com is running the latest version, so I donāt believe it is broken. Do you have errors in the console? What do your plugin settings look like?
Hi there, thanks for responding.
I installed it; it shows as activate on the admin panel. I get no error, nothing. The button that is supposed to be there for reactions is just not there!
On the latest version of Discourse, I am running into this error. Assuming that the plugin just needs to be updated to support the new emoji picker.
Error: Could not find module discourse/lib/emoji/toolbar
imported from discourse/plugins/retort/discourse/initializers/retort-init
