On the homepage by Top, Hot, Latest, etc. how can I add Unsolved?
You can use the Custom Top Navigation Links component to add custom links next to the ones configured in the site settings. To filter the topic list for unsolved topics, you can add solved=no
. For example https://meta.discourse.org/?solved=no
Running into the same incompatible plugin error mentioned up above, but we are using official release:
Logs
*** Please be patient, next steps might take a while ***
Cycling Unicorn, to free up memory
Restarting unicorn pid: 551
Waiting for Unicorn to reload.
Waiting for Unicorn to reload..
Waiting for Unicorn to reload...
Waiting for Unicorn to reload....
Waiting for Unicorn to reload.....
Waiting for Unicorn to reload......
Waiting for Unicorn to reload.......
Stopping 3 Unicorn worker(s), to free up memory
Stopping job queue to reclaim memory, master pid is 3004191
$ cd /var/www/discourse/plugins/docker_manager && git fetch --tags --prune-tags --prune --force
$ cd /var/www/discourse/plugins/docker_manager && git reset --hard HEAD@{upstream}
HEAD is now at 930ec25 DEV: Enable smoke specs again
$ bundle install --retry 3 --jobs 4
Bundle complete! 146 Gemfile dependencies, 189 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
3 installed gems you directly depend on are looking for funding.
Run `bundle fund` for details
$ if [ -f yarn.lock ]; then yarn install; else CI=1 pnpm install; fi
Scope: all 17 workspace projects
Lockfile is up to date, resolution step is skipped
Already up to date
Done in 3.2s
$ LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all
checking out compatible discourse-calendar version: 8d09cf8503b78f4c72b47a7319c0f4b9ad0247e7
HEAD is now at 8d09cf8 DEV: update regions (#717)
checking out compatible discourse-reactions version: f87583d9054421869ba0de16c24ad15e32bbebe7
HEAD is now at f87583d DEV: Add system spec to check core features are working fine (#361)
checking out compatible discourse-solved version: 4f0234f5be3aaa77db277e0f224cd9750d2713cd
HEAD is now at 4f0234f DEV: Add system spec to check core features are working fine (#357)
discourse-spoiler-alert is already at latest compatible version
docker_manager is already at latest compatible version
$ SKIP_POST_DEPLOYMENT_MIGRATIONS=1 bundle exec rake multisite:migrate
81: from /var/www/discourse/vendor/bundle/ruby/3.3.0/bin/bundle:25:in `<main>'
80: from /var/www/discourse/vendor/bundle/ruby/3.3.0/bin/bundle:25:in `load'
79: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/exe/bundle:20:in `<top (required)>'
78: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
77: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/exe/bundle:28:in `block in <top (required)>'
76: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/lib/bundler/cli.rb:29:in `start'
75: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor/base.rb:584:in `start'
74: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/lib/bundler/cli.rb:35:in `dispatch'
73: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor.rb:538:in `dispatch'
72: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
71: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run'
70: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/lib/bundler/cli.rb:452:in `exec'
69: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/lib/bundler/cli/exec.rb:23:in `run'
68: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/lib/bundler/cli/exec.rb:59:in `kernel_load'
67: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bundler-2.6.4/lib/bundler/cli/exec.rb:59:in `load'
66: from /var/www/discourse/vendor/bundle/ruby/3.3.0/bin/rake:25:in `<top (required)>'
65: from /var/www/discourse/vendor/bundle/ruby/3.3.0/bin/rake:25:in `load'
64: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
63: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:80:in `run'
62: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:214:in `standard_exception_handling'
61: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:83:in `block in run'
60: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:132:in `top_level'
59: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:147:in `run_with_threads'
58: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block in top_level'
57: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `each'
56: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block (2 levels) in top_level'
55: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:188:in `invoke_task'
54: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:188:in `invoke'
53: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
52: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `synchronize'
51: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:218:in `block in invoke_with_call_chain'
50: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:241:in `invoke_prerequisites'
49: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:241:in `each'
48: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:243:in `block in invoke_prerequisites'
47: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
46: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `synchronize'
45: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:218:in `block in invoke_with_call_chain'
44: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:241:in `invoke_prerequisites'
43: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:241:in `each'
42: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:243:in `block in invoke_prerequisites'
41: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
40: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `synchronize'
39: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
38: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `execute'
37: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `each'
36: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `block in execute'
35: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:559:in `block in run_tasks_blocks'
34: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:411:in `require_environment!'
33: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/zeitwerk-2.7.2/lib/zeitwerk/core_ext/kernel.rb:34:in `require'
32: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
31: from /usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `block (2 levels) in replace_require'
30: from /usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `require'
29: from /var/www/discourse/config/environment.rb:7:in `<main>'
28: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application.rb:435:in `initialize!'
27: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:60:in `run_initializers'
26: from /usr/local/lib/ruby/3.3.0/tsort.rb:208:in `tsort_each'
25: from /usr/local/lib/ruby/3.3.0/tsort.rb:229:in `tsort_each'
24: from /usr/local/lib/ruby/3.3.0/tsort.rb:350:in `each_strongly_connected_component'
23: from /usr/local/lib/ruby/3.3.0/tsort.rb:350:in `call'
22: from /usr/local/lib/ruby/3.3.0/tsort.rb:350:in `each'
21: from /usr/local/lib/ruby/3.3.0/tsort.rb:352:in `block in each_strongly_connected_component'
20: from /usr/local/lib/ruby/3.3.0/tsort.rb:434:in `each_strongly_connected_component_from'
19: from /usr/local/lib/ruby/3.3.0/tsort.rb:353:in `block (2 levels) in each_strongly_connected_component'
18: from /usr/local/lib/ruby/3.3.0/tsort.rb:231:in `block in tsort_each'
17: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:61:in `block in run_initializers'
16: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:32:in `run'
15: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/initializable.rb:32:in `instance_exec'
14: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/application/finisher.rb:94:in `block in <module:Finisher>'
13: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:77:in `run_load_hooks'
12: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:77:in `each'
11: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:78:in `block in run_load_hooks'
10: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:92:in `execute_hook'
9: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:87:in `with_execution_control'
8: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:94:in `block in execute_hook'
7: from /var/www/discourse/config/application.rb:241:in `block in <class:Application>'
6: from /var/www/discourse/lib/plugin.rb:6:in `initialization_guard'
5: from /var/www/discourse/config/application.rb:241:in `block (2 levels) in <class:Application>'
4: from /var/www/discourse/config/application.rb:241:in `each'
3: from /var/www/discourse/lib/plugin/instance.rb:629:in `notify_after_initialize'
2: from /var/www/discourse/lib/plugin/instance.rb:629:in `each'
1: from /var/www/discourse/lib/plugin/instance.rb:631:in `block in notify_after_initialize'
/var/www/discourse/plugins/discourse-solved/plugin.rb:172:in `block in activate!': undefined method `register_category_list_topics_preloader_associations' for an instance of Plugin::Instance (NoMethodError)
** INCOMPATIBLE PLUGIN **
You are unable to start Discourse due to errors in the plugin at
Please try removing this plugin and rebuilding again!
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:211:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:109:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:44:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:44:in `block in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/execution_wrapper.rb:91:in `wrap'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:70:in `conditional_executor'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:178:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor.rb:538:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:73:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:71:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:149:in `with_argv'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:69:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands.rb:18:in `<main>'
bin/rails:18:in `<main>'
Spinning up 3 Unicorn worker(s) that were stopped initially
tldr logs:
We arenāt too far behind, but something is unhappy.
Edit: So, everything about this update went south. docker_manager failed as logged above, but then it showed as āup to dateā afterward. A main Discourse update utterly failed - showed as updating but never made progress and no processes changed. I disabled Solved! in app.yml and rebuilt the app - everything seems good now - minus Solved. If anyone comments that itās safe to turn back on Iāll rerebuild it.
FWIW I have the Solved plugin installed and I updated earlier today through the UI and it went through okay.
Should have checked before I posted⦠Looks like thereās one new commit for Solved that has been added in the meantime. Let me do a command line rebuild just to check and confirm everything goes through okay.
ETA: @Frully My rebuild (including Solved) was successful
To add to what Jam said. I too havenāt had any issues with solved
If this is the first time you installed Solved verify that your GitHub address is correct.
If you can maybe also share if youāre running Stable or the Recommended Test-Passed
If you can post part of your app.yml plugin section may help as well.
Thanks both for checking. Now that it is updated I feel safer reenabling the plugin. Will advise when I have time to test and note the results.
Weāre still suffering from this issue (although as no-one else seems to have reported it, Iām starting to wonder if itās just us?)
Digging a little deeper, I have found that adding a padding-top
and padding-bottom
of 15px to the topic-statuses
CSS class works around the problem. Iām hoping for a maintainer of the plugin to be able to fix this in a more permanent way.
I think this is connected to Discourse Tooltips. Itās not just the unsolved boxes on your site, but also any pins and padlocks as well.
I think there are a couple of other reports too:
Since weāve updated discourse, solved webhooks are inverted.
If I solve a topic the webhook will be sent like this :
"can_accept_answer": true,
"can_unaccept_answer": false,
"accepted_answer": false,
"topic_accepted_answer": null
and if I unaccept the answer, itās the other way around
