تسجيل دخول موحد (SSO) من Discourse إلى Discourse
I’ve been discussing this idea with one of my colleagues who also happens to be running a forum on discourse about the possibility to allow the users of one forum to sign in to the other forum without having to create a new account.
I couldn’t find anyone doing this so I wanted to ask if discourse SSO is capable of allowing other discourse instances as a client?
إعجابَين (2)
Yes, just enable “sso provider” on the “primary” forum that you expect everyone to have an account on.
إعجابَين (2)
I had thought of that, I’ll give it a shot but It’s more like a mutual thing, We have separate user base on both forums, Will it be possible to sync users of all the secondary forum to the primary forum?
The problem with SSO, as I think you’ve realized, is that it’s all it nothing. You’re likely better if just using social logins.
If you do want to have both sites share a single user database you’ll need to pull over the users. There’s not an easy way to do that that I am aware of. One solution might be to use category export /import, which would create the users (and then you’d hide or delete the imported categories). You’d need to know that everyone had posted at least once.
إعجاب واحد (1)
So basically local logins can’t be synced to the SSO server?
If you want server B to use server A as the SSO master, you’d need to create all of B’s users on A. I’m not aware of a script that does that.
There are a couple ways I could imagine doing it. If you’ve got a budget post in Marketplace or see my contact info in my profile.
I haven’t thought of a budget yet but I’d get in touch to discuss the possibilities…
إعجاب واحد (1)
Would it be a crazy idea to offer https://meta.discourse.org login as a social login for other Discourse instances (enabling this social login)? Imagine, a login for all Discourse instances.
إعجاب واحد (1)
Take a look at the old #discourse_hub topics: Unique user names in Discourse Hub
5 إعجابات
