Version 2.2 de Discourse
Focus
Codename
Start date
September 11th, 2018
Planned release date
January 31, 2019
64 « J'aime »
NEW FEATURES
  • When only option is “existing topic”, autofocus input field
  • Fallback to logo_url as last resort for opengraph image url
  • Add the show user action to the user-card-after-username plugin outlet
  • Add topic list before status plugin outlet for mobile
  • Allow overriding text size from a different device (#6955)
  • Allow setting font size per-device using a cookie (#6947)
  • Support additional metadata in theme about.json (#6944)
  • Add recipient avatars in PM topic list even if they not yet replied
  • Import and export themes in a .tar.gz format (#6916)
  • List unused theme components (#6924)
  • Default block ahrefsbot crawler
  • Default block semrushbot crawler
  • Add total on stacked-chart tooltip (#6917)
  • Do not autoclose topics due to user flagging that are authored by staff
  • Adds a new chart report to track pageviews (#6913)
  • Support for localized themes (#6848)
  • Introduce ultra_low priority queue
  • Remove full quotes only from new posts. (#6862)
  • Allow calling user destroyer without a transaction
  • Consolidate likes notifications. (#6879)
  • Enable CSP by default on new sites (#6873)
  • Allow the base font size to be changed on a per-user basis (#6859)
  • Allow staff to select existing message via ID or URL
  • Plugin support for custom icons
  • Allow extending CSP base-uri and object-src
  • Set CSP base-uri and object-src to none (#6863)
  • Remove option for Google Plus sharing (#6864)
  • PWA compatibility checks in the Dashboard (#6850)
  • Push post rebake regular task to low priority queue
  • Keep the topic in closed status until the community flags are handled
  • Add support for Twitter cards.
  • Use email_site_title in From of digest emails
  • Include “via <site_name>” in email From header
  • Allow plugins to add custom emoji translations
  • Topic timer for bumping a topic in the future
  • Add S3 etag value to uploads table (#6795)
  • Add setting to bypass sending redis CLIENT commands
  • Remove global settings for redis sentinels
  • Make auth_redirect param options on user_api_keys
  • Tighter limits on per cluster post rebakes
  • Add rake task that resets ACL on every object in S3
  • Display error message when category restriction is applied for tags
  • Force rebake of all posts with images
  • Store thumbnail algorithm version in optimized image table
  • Allow custom HighlightJS languages
  • Allow TL4 users to reset bump date
  • Introduce lossy color optimization on resized pngs
  • Move posts to new/existing PM (#6802)
  • Poll’s min can be 0.
  • Display avatars of PM recepients in small topic header when scrolling down
  • Add Top Uploads report (#6825)
  • Invalidate broken images cache on Rebuild HTML action
  • Allow for custom excerpt BBCODE
  • Support YouTube rel parameter
  • Don’t create PM for successful automatic backups
  • Add /conduct as an alias for /guidelines
  • Show a blurry preview when lazy loading images
  • Remove full quote only if first paragraph. (#6793)
  • Prohibit S3 bucket reusage
  • Improve backup stats on admin dashboard
  • Rake task to list users which have been staff in the past month
  • Adds security tab to dashboard (#6768)
  • Require admins to re-validate their email addresses if they haven’t been seen for a number of days, configurable with the invalidate_inactive_admin_email_after_days site setting. Social logins are also revoked. Default is 365 days.
  • Adds site setting to let quotes on direct replies.
  • Add short_site_description setting to be included in title tag on homepage
  • Check if draft exists before starting a new one (#6755)
  • Polyfill intersection observer for IE11 / iOS Safari
  • Lazily Load Images as they scroll into the viewport.
  • Full height swipe enabled menus
  • Allow connecting associated accounts when two-factor is enabled (#6754)
  • Activate users invited via email when invite is redeemed
  • Option to use ruby-bbcode-to-md in bulk import script
  • Web Share Target Support
  • Remove full quotes of direct replies. (#6729)
  • Improved deprecation warnings (#6722)
  • Discourse.deprecate can report version
  • Show avatar flair on group, badges and directory pages (#6732)
  • Show autocomplete when enable_inline_emoji_translation is true.
  • Add support for inline emoji translation.
  • Add ‘Advanced Test’ for admin panel.
  • Filter topic and post web hook events by tags (#6726)
  • Multisite support for S3 backup store (#6700)
  • Disable notifications for small actions that are whispers
  • Allow advanced specification of excerpts for posts
  • Do not check consecutive replies for original poster. (#6714)
  • Allow plugins and themes to extend the default CSP (#6704)
  • Multisite support for S3 image stores (#6689)
  • Setting for short title used by Android on homescreen
  • Reimplement SiteSetting.max_oneboxes_per_post. (#6668)
  • Make uploads:missing task compatible with s3 uploads
  • If PM email bounced for staged user then alert in whisper reply (#6648)
  • Refactoring and better handling of special cases (#6666)
  • Allows html tooltips (#6665)
  • Allows plugins to register no module files (#6664)
  • Use translated name for ‘your email has been authenticated by’ (#6649)
  • Allow logo URLs to be overridden easily using reopenWidget()
  • Show post approvals in Moderation History (#6643)
  • Scroll-based logo on mobile (#6632)
  • Show change name of user in staff logs (#6647)
  • Do not switch to JPEG unless you meet 75k byte savings
  • Terms of Service v1.0.0
  • Plugin outlets on about page
  • Add new setting to force user edit last post. (#6571)
  • Compute distance between logins to generate login alerts. (#6562)
  • Report edit conflicts when saving draft. (#6585)
  • Upload Site Settings. (#6573)
  • Log password changes in UserHistory (#6600)
  • Allow expanded posts to return user custom fields
  • Add button to delete unused tags (#6587)
  • Better handling of quotation marks in site text search
  • Additional “related messages” section
  • Update Font Awesome to v5.4.1 and SVGs (#6557)
  • Adds ignored flags to most_disagreed_flags report (#6554)
  • Add Noindex to robots.txt for disallowed routes
  • Track how many user flags are agreed/disagreed/ignored
  • Show added date when looking at group members
  • New ‘simultaneous_uploads’ site setting
  • Add download script for Google Groups
  • Suspicious logins report. (#6544)
  • Revamps search-menu layout (#6543)
  • Special offline support restricted to Android only
  • Push related PMs to take first 3 slots
  • Allow admins to control PWA display mode per user agent
  • Adds a most disagreed flaggers report
  • Hide muted categories from /categories list (#6531)
  • Warn users via email about suspicious logins. (#6520)
  • Add server:before-head-close-crawler outlet for plugins
  • [Experimental] Content Security Policy (#6514)
  • [Experimental] Content Security Policy (#6504)
  • Add Wiki Editor badge. (#6511)
  • Adds latest to user-api-key session scope
  • New plugin outlets for user card customization
  • Allow plugins to whitelist user custom fields for public display (#6499)
  • Adds list#(unread|new) to user api key routes (#6494)
  • New rake task to anonymize all users
  • Upload tags from CSV (#6484)
  • Allow multiple secrets for Discourse SSO provider
  • Fullscreen composer mode on desktop
  • Support backup uploads/downloads directly to/from S3.
  • Log long running jobs in the defer queue
  • Allow bulk removing users from a group
  • XenForo importer can import categories from the xf_node table and convert sub-categories beyond second level to tags
  • Automatically hide non-TL4 posts when flagged by a TL4 user
  • Add boxes with subcategories option for desktop categories page (#6471)
  • Option to disable user presence and profile
  • Support category slug when creating new topic via URL
  • Show “Recently used devices” in user preferences (#6335)
  • Added MaxMindDb to resolve IP information.
  • Added browser detection based on user agent.
  • Added recently used devices in user preferences.
  • Add branch option to remote theme import
  • Adds header text/background color to site (#6462)
  • Post deployment migrations. (#6406)
  • Only export settings that changed via rake task
  • Mixed case tagging (#6454)
  • Add indication if incoming email attachment was rejected and inform sender about it (#6376)
  • Enable the notification prompt by default
  • Add support for responsive images in posts
  • Change default to enable login by email out-of-the-box
  • Notify admins when scheduling of backup fails
  • Add Lithuanian locale
  • Display trust level descriptions in site settings (#6421)
  • Auto grant an available title when removing old title
  • Do not allow moderators to export user list (#6418)
  • Add external details to user fields
  • Log entity export in staff logs
  • New ‘search_ignore_accents’ site setting
  • Match user title when primary group changes
  • Unconditionally omit no-follow for staff
  • Updated CORS config to explicitly specifyhttp methods
  • Add SiteSetting for s3_configure_tombstone_policy
  • Don’t blow up when can’t reach theme’s repo, show problem themes on dashboard
  • Updated IPB import script
9 « J'aime »
BUG FIXES
  • Mobile button colors
  • PostActionCreator was not checking the guardian properly
  • Refresh admin/customize/themes route after import
  • Imported themes should set their color scheme automatically
  • Exporting themes when uploads are on S3
  • New mailgun webhooks
  • Google HD and Prompt settings should be checked at runtime
  • Use absolute url for /images/example.png links
  • Do not send welcome message to staged users
  • Regression with composer warnings
  • Email domain whitelist prevented user anonymizing
  • Secondary email addresses were not deleted during anonymizing
  • User_id attribute not found in posters array
  • Return 400 when username params is invalid.
  • User and group mentions in subfolder installs
  • Better error handling if a file cannot be sent
  • More resilient lookup in plugin-api (#6961)
  • Add autocomplete=off to composer textarea
  • Class name for external-link on customize page
  • More link in topic page search shouldn’t navigate to full page result
  • Don’t duplicate attachments
  • Support application/gzip theme imports, and improve error message
  • Convert lightbox html into proper image markdown
  • Javascript error when opening rename tag modal
  • Heisentest
  • Match drafts using key when deleting
  • Prevents race condition where the same report is loaded multiple times (#6953)
  • Properly handle attachments in received emails
  • Circular argument reference
  • Fix safe mode regression
  • Respect min_flags_staff_visibility for new flags too
  • Ensures ordering set in tags-show queryString works at first load (#6951)
  • Makes staff_logins show only admins (#6948)
  • User_id handling on remove user from group
  • Do not show backups stored in subfolder of bucket
  • Raise or log error when deleting of backup fails
  • Use context sensitive “create topic” via keyboard if possible
  • Ensures correct scroll position of textarea after autocomplete (#6942)
  • Discourse-poll-option test wasn’t working
  • Includes staff in staff_logins report (#6945)
  • Link to the user preferences page is incorrect in user admin page
  • Replaces inline button message with d-button
  • Allow sending PMs to staff via flag even when PMs are disabled (#6938)
  • Allow sending PMs to staff via flag even if the user trust level is insufficient
  • Displays user-card when clicking on avatar of post small action (#6941)
  • Lazy Loading: copy only present srcset
  • Fix URL to user profile. (#6881)
  • SiteNavigationElement was reversed (#6934)
  • Stop propagating keyboard event when replying to topic/post (#6930)
  • Corrects selector for move-to modal styles
  • migrate_to_s3 task not setting the right content_disposition.
  • ‘anon’ css class is missing for anonymous users
  • Icon missing due to typo
  • Keep tags when switching to shared draft
  • Don’t notify of pending flags if min_flags_staff_visibility not met
  • Improves stacked-chart layout on ie11 (#6922)
  • Better handling of resizing in stacked charts (#6921)
  • Don’t update User#last_seen_at when PG is in readonly take 3.
  • Don’t clear connections on failover.
  • Clear connections before disabling readonly mode.
  • Fallback Redis by checking status on master instead of slave.
  • Clear anon cache when clearing recently readonly.
  • Alignment for small-actions, gap, removing unneeded clearfix
  • Whitespace breaks activity column in Firefox
  • Badges appeared in wrong badge group
  • IE11 layout glitches
  • Don’t override user flair styles in topic map
  • Better legend labels for stacked-charts (#6914)
  • Incorrect subscription in PostgreSQLFallbackHandler.
  • ForumsController doesn’t need to inherit from ApplicationController.
  • Don’t update User#last_seen_at when PG is readonly take 2.
  • Don’t update User#last_seen_at when PG is in readonly.
  • Avoid throwing an error when processing PG down message.
  • Don’t log request when Discourse is in readonly due to PG.
  • Use ENV values instead of ‘S3Helper.s3_options’ in migrate_to_s3
  • Changing owner of small action post failed
  • Update about/license URLs when updating theme from remote source
  • Ensures visits reports are correcttly differencing mobile/all (#6905)
  • PostLabel was not working for totals (#6904)
  • Correct deprecated theme settings in handlebars templates
  • Correctly import theme assets with spaces in filename
  • Mods weren’t able to see emails in admin user list
  • Keep original subject in emails to staged users
  • Since Ember 3 interceptClick was not working on buffered links (#6898)
  • Remove old reference and use MiniScheduler::Stat.
  • Text logo does not show up on non ember pages.
  • Refresh “/categories” on logo click (#6891)
  • Refresh discovery categories on logo click
  • Use ordered_posts for last post check, not the posts relation
  • Do not hide posts automatically when flagged by staff user
  • Navigate to full page search when enter key used in topic
  • Wrap theme javascript inside IIFE to prevent using global namespace
  • Theme settings are referenced in JS by settings, not themeSetting
  • Regression lead to a 404 when trying to filter user posts (#6893)
  • Avoid rescuing error in login hint initializer.
  • Liked notification consolidation has to account for user like frequency setting.
  • Improve rake emails:test task
  • Rake emails:test to bypass the “STARTTLS required” message
  • Too much j
  • Properly clean out post and user actions on destroy user
  • Sort topics/posts/links in descending order in user summaries
  • Ember.warn needs an id
  • Makes click-interceptor working with touchstart (#6890)
  • Makes whisper state more resilient (#6889)
  • Only add the trust level name for numeric trust levels
  • Add watching_first_post to NOTIFIABLE_TYPES (#6887)
  • Tweaking topic footer dropdowns (#6882)
  • Use GlobalSetting values instead of ENV variables in migrate_to_s3
  • Don’t show liked consolidated notification when frequency is never.
  • Allow liked notifications consolidation to be disabled.
  • Consolidated like notifications links to wrong user on user page.
  • Liked notifications should not be consolidated across multiple users.
  • Profile picture not showing up on user admin page
  • Refresh topic list on logo click
  • Prevent layout changes while images are lazy-loading
  • Tooltip for unlisted topics wasn’t shown in topic list
  • Prefix should precede folder path (follow-up on 10fbb07e)
  • Call method only if it exists
  • Include folder name in prefix for listing files on S3 (follow-up on 3ec38f5a)
  • expandAllPinned was not resetting after visiting a category
  • Use Handlebars 4.0.12
  • List staff users within the last month
  • Add meta details for user summary page
  • Do not show PM topics when moving posts to an existing public topic (#6876)
  • Do not show full name on summary page unless the setting is enabled
  • Fix registration dialog popup for ‘full screen’ social logins
  • CheckEmail was calling itself (#6878)
  • Previous annotations were broken
  • Show user avatar on User summary page (#6872)
  • Correct copy for flag_sockpuppets site setting
  • Use correct version when generating file path for optimized image (#6871)
  • Show title as home logo if title has been set and logo is blank.
  • Use discourse route_for function to check url route
  • Prensence was overlapping with full-screen icon
  • Ember3 regression, uses model as bufferedProperty for badges (#6875)
  • Add missing “merge selected posts” icon
  • Minor regression when acting on queued post
  • Remove google+ from share_links site setting
  • Add missing copyright icon
  • Remove expired subscription for push notifications
  • Uses compiler version to force rebaking of themes (#6870)
  • Show lock glyph to a user without permissions to see quote (#6854)
  • Partial reply key search in email sent logs.
  • Searching email logs by reply key (#6868)
  • Push notifications didn’t work anymore
  • Multisite DB was leaving old data in test mode
  • Bump onebox version for gfycat aspect ratio fix
  • Apply classes when lazily loading images
  • Match default <code> padding to highlightjs padding
  • Gyfcat onebox should have fixed aspect ratio videos
  • Add topic status to flagged topics list
  • Full page search results are unclickable
  • Do not show Uncategorized in category drop if setting is disabled (#6856)
  • Ensure ember transitions do not get hijacked by discourse intercept-click
  • Migrate_to_s3 rake task with folder path
  • Enforce a fixed height on generic oneboxed videos
  • Add compatibility for bucket folder paths in migrate_to_s3 task (#6855)
  • Remove trailing whitespace to fix build
  • Always serve new avatar for previous version
  • Set unique post key for a user outside of transaction.
  • Use absolute URL for twitter:image tag
  • Add more https hosts
  • Properly escape embed url
  • Better accept invite flow when user is invited via a link
  • Improve topic small header alignment in mobile
  • Emojis are hard :shrug:
  • BuildTranslationTree was erroring when translations overlapped (ie. “:-)” and “:-))”)
  • Emoji translations wasn’t working properly when translations overlapped
  • Prevent error when badge has already been awarded
  • Upload method in S3Helper will expect a file object param
  • Image rendered temporarily in wrong position while loading
  • Incorrect CDN URL for site setting uploads when s3 is enabled.
  • Posting without bump raised an error for TL4
  • Trim trailing slash from topic links
  • Show accurate error message based on invite token validity
  • Make full height menu and cloak respect custom headers (#6845)
  • “Toggle topic bump” wasn’t visible for TL4 users
  • Polls didn’t work in imported posts
  • Make test less fragile.
  • Pass all necessary options in migrate_to_s3 rake task.
  • Quote selection in IE11
  • Validate poll arguments. (#6740)
  • Validate number poll.
  • Show error msg on grant badge if message available from backend (#6801)
  • Calendar range was too wide (#6829)
  • Reports issues with ie11 (#6828)
  • Composer css fixes for ie11 (#6827)
  • Uses flex: 1 0 0; instead of flex: 1; for better browser compat (#6826)
  • Better left/right positioning in select-kit components (#6824)
  • Less fancy pages computation for browser compatibility (#6823)
  • RouteToTag mini-fix for IE11
  • Limit previous IE SVG click event fix
  • Recurrence was not applied when selected in the form (#6820)
  • Optimize collapse/expand select-kit codepath (#6818)
  • Remove storage_stats from the list of reports, too specific (#6817)
  • Delete dataset doesn’t work on safari
  • Dates should also store recurring (#6814)
  • Hashtags should work for non-english characters
  • Don’t use Redis#keys in production.
  • Validate YAML before save to avoid race condition
  • Do not raise error if most liked user is deleted
  • Hide group membership request button for existing members
  • Gfycat oneboxing
  • Show popup before bulk invite
  • Resetting bump date shouldn’t fail when first post is hidden
  • Narrative bot should ignore action on deleted post
  • Subfolder path is missing in category permalinks after slug update
  • Workaround for Edge issue with clicks on SVGs
  • Raises an error if q param is empty in search page
  • Use one-way binding to prevent unnecessary updates in site.periods
  • Use correct post object when logging exception
  • Skip adding sso diagnostics if sso object is nil
  • Copy old status to new poll. (#6788)
  • Bypass draft check when switching to shared draft. (#6782)
  • Hide emails on admin user list for moderators (#6781)
  • Move sso provider into its own class so it doesn’t interfere with sso client (#6767)
  • Use CDN for logos and icons. (#6698)
  • Preserve github fragment URL
  • Ensure that multisite s3 uploads are tombstoned correctly (#6769)
  • Ensure that multisite uploads are tombstoned into the correct paths
  • Broken spec
  • Allow sending test e-mails to any email address when disable_email is set to non-staff (#6792)
  • Disable multipart backup uploads to S3
  • Font tag resulted in wrong email trimming
  • Weird mixture of line breaks resulted in wrong email trimming
  • Enabling readonly mode should clear anon cache as well.
  • Rescue errors in job. (#6745)
  • Properly reset controller of admin-user-index. (#6760)
  • Strip remote url before import. (#6762)
  • Adusts select-kit position even if not expanded (#6785)
  • Ensures nothing is triggering rendering loop in after render (#6784)
  • Clear anon cache when disabling readonly mode.
  • Switch recently readonly mdoe cache to a DistributedCache.
  • Use new key for delete topic to make it lowercased as all other buttons label around it (#6778)
  • Create CORS rule on S3 only before a backup upload
  • Makes more resilient select-kit positioning (#6776)
  • Consistency about our response for invalid user id in Admin::UsersController.
  • Clear the site_contact_username setting if the user’s staff privileges are revoked
  • Use find_by_id method to prevent record not found exception
  • Suspicious login detection (#6772)
  • Only serialize group membership domains for administrators (#6771)
  • Delete all posts in batches without hijack (#6747)
  • Incorrect translation key on admin search logs.
  • Apply original margin-bottom to fix position placeholder (#6764)
  • Define actions on connector class early (#6763)
  • Incorrect arguments were being passed to Jobs::ClosePoll.
  • Remove slow platform detection from server side
  • Always show filtered site settings
  • Invalidating inactive admin emails should mark them as not active
  • Do not bump topic when removing full quotes.
  • Makes charts more resilient to resizing (#6758)
  • Sidekiq fails to start if any of the multisite has problems.
  • Support RTL languages in header menu
  • Return authenticated=true when reconnecting
  • Do not convert quote tags to markdown
  • Show every voter only once. (#6746)
  • URLs containing two # would fail to work
  • Redirect to default homepage when visiting /login
  • Use database to persist metadata during social registration (#6750)
  • Category-drop initial state was incorrect (#6743)
  • Don’t double add users to topic allowed users
  • Exec_params needs instrumentation
  • Support connecting GitHub with existing accounts
  • Add missing android icon
  • Prioritize explicit ‘connect’ over matching by email
  • Return 422 instead of 500 for invalid SSO signature (#6738)
  • Only hide shared draft topics from latest (#6737)
  • Do not serialize user fields unless they are specified for display (#6736)
  • Posts would not auto rebake unless gravatar download was enabled
  • Refactor lightbox mobile icon
  • Wizard tries harder to find existing Welcome Topic
  • `UserNotificationsHelper#logo_url’ to work with S3 based uploads.
  • Always allow admins upload selectable avatars.
  • Properly secure poll message bus
  • Ignore query parameters when displaying counter on internal links
  • Do not reset link counts when post is rebaked
  • Method extraction caused push notifications to include incorrect post
  • Variable name typo in subcategory image
  • Clamp integers to prevent ‘PG::NumericValueOutOfRange’ errors
  • Improve avatar loading, and add tests
  • Increase timeout when trying to reload unicorn.
  • Use safe navigation operator throughout statement
  • Topic is nil when first post is being created
  • Use safe navigation operator when looking for avatar URL
  • Tooltip regression in admin dashboard
  • Fixed tests. (#6716)
  • Raise exception when getting dimensions of missing image
  • Don’t steal focus when text in editor is replaced (#6712)
  • All multisite upload paths should start with /uploads/default/.. (#6707)
  • Make staff_edit_locks_post work with download_remote_images_to_local
  • Show generic title when quoting off-topic secure category posts
  • Do not store key tracking last seen time indefinitely
  • Lightbox expand icon on mobile
  • Add vkontakte icon alias
  • Log name changes only when the name is actually updated
  • Incoming email matches the wrong user if null bounce key available in db
  • Redis leak when visiting large amounts of topics
  • Jobs::CleanUpUploads fails when value of upload data_type is an empty string.
  • Refactor commit a8c3ca, add test
  • Limit SvgSprite scan to string setting values
  • Refactor ImageSizer.resize
  • Call ImageSizer only if width/height are available
  • Defer flags (only) when handling a flag and deleting replies (#6702)
  • Prevent minimum_required_tags on category being set to null (#6703)
  • More resilient whisper state between composer states (#6687)
  • Call onSelect plugin callbacks for noop rows (#6682)
  • Always prepend watching user timezone to previews (#6695)
  • Error with tags enabled and no tags created (#6701)
  • Fix query selecting users not accepting PMs.
  • Use File.join for relative_base_url, fix spec
  • Map discord/patreon FA5 icons for login buttons correctly
  • Restrict logo width for small screens
  • Throw error when link in reason for grant badge is an external link (#6690)
  • Positioning issues with local-dates (#6693)
  • Add FA Discourse icon, update setting instructions
  • Get email address from email_log if bounced with verp
  • Script was missing newlines when generating hosts
  • Create whisper post in PMs when bounces with verp and user is staged
  • Title was repeating on about page
  • Static page title should be consistent on client side and server side
  • Makes sure we have a zone (#6686)
  • Better fix for #ca84c06 (#6684)
  • Fix editing built-in badges after removing _.include
  • Revert to using _.each (#6683)
  • Better handling of same offset timezones (#6680)
  • Set overridden param for customize site text query only when checkbox value changes
  • Popular posts font weight in summary email
  • Compares timezones on utc offset and not name (#6672)
  • Removes country from timezone indicator (#6677)
  • Resets timezone default after callback (#6675)
  • Randomly failing QUnit test.
  • Do not agree flags by default when deleting posts
  • Enable caching on SVG sprites
  • Uses appropriate z-index for tooltips (#6674)
  • Notify only invited users about mentions in PMs
  • Upwards scrolling occasionally broken
  • Fix mentions for mixed case group names
  • Bug and typo in admin user badges
  • Group mentions missing after post processing.
  • Incorrect “rel” used for apple icons in <head>.
  • Alignment issue in PM inbox when bulk selecting
  • Validate topic deletion when acting on a flag
  • Properly migrate polls/votes stored as array
  • Fix routes ending in :username for usernames containing periods (#6660)
  • Auto-closing poll wasn’t working
  • Fix broken theme field URLs. (#6622)
  • Couldn’t delete users who voted on a poll
  • Ensure poll options keep their order
  • Don’t trigger header:hide-topic at the bottom on desktops
  • Categories/delete_categories can be undefined (#6657)
  • Improves code, tests and utc handling of local-dates (#6644)
  • Broken badge groupings modal UI (#6653)
  • Use Discourse.deprecate instead of Rails.logger.warn
  • Better alignment of badge selector and edit btn (#6651)
  • Better alignment of groups header filters (#6650)
  • Failed to delete post belonging to non-existent topic
  • Remove unneeded keys from failed response
  • Mention lookup should be case insensitive.
  • Check whether group is mentionable by user when cooking post.
  • Assign default value for category.findByIds method
  • Staged users should not be mentionable.
  • Wizard icons step fields have incorrect values.
  • Give up migrating url site setting if endpoint doesn’t return data.
  • Give up migration of URL site settings if there is an SSL error.
  • Setting DISCOURSE_S3_REGION env variable had no effect
  • A search term containing '& could lead to errors
  • Make danger locale warning work with plugin locales (#6639)
  • Raise Discourse::NotFound unless the user is present
  • Respond with proper error message if user not found
  • Raise Discourse::NotFound unless the topic is present
  • Browser infinite recursion when editing post
  • Never attempt to log invalid post numbers
  • Handle nil topic value when removing allowed users
  • Properly disable serializable attributes when poll plugin is disabled
  • Handle nil user value on password reset
  • Escape sso_secret string when migrating to sso_provider_secret (#6634)
  • Use count variable for pluralized string.
  • Skip gsub for normalizing whitespaces when text is nil (#6631)
  • Remove site settings override for deprecated url site settings.
  • Clear theme cache when restoring
  • Adds support for missing reports from old dashboard (#6624)
  • Do not show nested user cards. (#6621)
  • Show Google video preview on iOS devices
  • Convert relative image url to absolute url
  • Don’t show the Quote popup if posting is disabled
  • Clear uploads cache on SiteSetting.refresh!.
  • Job to clean up old URL settings when new setting has been set.
  • S3 CDN for markdown it bundle
  • S/save/finish for wizard exit early button (#6614)
  • Select-kit items shouldn’t have flex-grow
  • Improves category/tag drops header shortcuts (#6610)
  • Avoid using absolute positioning for box category style in emails (#6607)
  • Only use blockquote which is immediate child of aside
  • Better handling of missing welcome topic in wizard (#6606)
  • Make Discobot image tutorial accept URL that points to images.
  • Only check for conflict on edit drafts
  • Makes sure an hex is always at 6 chars (#6608)
  • Change ‘max_consecutive_replies’ default to 3
  • Reset bump date resets bumped_at to the last regular post in topic (#6605)
  • Only send originalText when we need to
  • Don’t hide information from the card that is visible in the topic
  • Change title when primary group changes (#6602)
  • Category row title (#6597)
  • ‘migrate_from_s3’ rake task should respect max sizes (#6598)
  • Update logster to handle logging of invalid encoding strings
  • Prevent uploads used in site settings from being deleted.
  • Stricter window.opener checks (#6578)
  • Cache url data for failed inline oneboxes
  • Translation improvements for unused tags (d89ffbe)
  • Opts is a hash in ‘log_on_user’
  • Do not check for suspicious login when impersonating. (#6534)
  • Handles not found reports in bulk loading (#6582)
  • Improve performance for Group.posts_for (#6588)
  • Don’t enqueue topics if the user can’t create them
  • Fix/removes broken elements of old dashboard
  • Fix vertical scrolling in modals
  • Never redirect back to /sso it will cause a loop
  • Ensure we never cache login redirects by mistake
  • Relative links in translations should work with subfolder
  • Do not display broken image on crawler/print view (#6575)
  • Relative links in templates should work with subfolders
  • Correct svg handling for images
  • Clarify User.group_locked_trust_level.
  • Search within topic not working correctly in CJK
  • Edit category tags select-kit inputs width were wrong (#6568)
  • Disable flagging hidden posts
  • Uses hex to compare images
  • Don’t allow adding a value containing vertical bar char to the secret list
  • Topic-map spec with VDOM and i18n plural (#6564)
  • Don’t strip eml attachments from received emails
  • Disables dates filtering on most_disagreed_flags report (#6556)
  • Uses more semantically correct spans in post map (#6555)
  • Use ‘require’ for dependencies. (#6552)
  • Translation error
  • Only extract script tags with certain types (#6553)
  • We shouldn’t include topics when mobile view is enabled
  • Do not create superflous sessions when logged on
  • Do not leak information about post revisions. (#6536)
  • Correct bookmark button class
  • Return 400 for missing required params (#6546)
  • Improve error handling for missing maxmind dbs
  • Add ‘log in via link’ to email templates. (#6545)
  • Fix ‘New Login Alert’ message. (#6539)
  • Uploads didn’t work for subfolder anymore
  • Sso provider copyedit
  • Prevents y-axis labels to show useless/wrong values
  • Flash authentication data not rendered in latest iOS safari browser
  • Add String.includes polyfill for IE11
  • Remove orientation from the webmanifest
  • Add polyfill so that Array.includes works in IE11
  • Ensures reports links are correct on subfolder installs
  • Don’t seed flags if ids don’t exist
  • Don’t use srcset on cropped thumbnails
  • Do not update last_seen for API access
  • Do not track right clicks. (#6530)
  • Support comma in ‘sso_provider_secrets’ site setting
  • Ensure the like button always has a title, for accessibility (#6525)
  • GlobalPath#upload_cdn_path when S3 bucket has a folder (#6523)
  • If poll has not options do not break serializer
  • Remove duplicate referrer policy
  • Strip accents from search query
  • Validates import theme form (#6513)
  • Stop logging every 404 error when searching for gravatars
  • Fix order of recently connected devices. (#6517)
  • Proper naming for the GNU/Linux OS
  • Fix browser detection for Microsoft Edge. (#6516)
  • Clean tag before searching for matches
  • Sanitize tags before creation
  • Count emoji shortcuts in topic title
  • Prevent duplicate tags in tag-choosers (#6512)
  • Strip @ when searching for users and groups. (#6506)
  • User AvatarLookup for looking up avatar details (#6508)
  • Lowercase username for add/rem group members
  • Always update ‘last_gravatar_download_attempt’ when updating gravatar
  • Properly import vBulletin’s hashed password
  • Extracted theme JavaScripts for multisite (#6502)
  • Extracted theme javascripts for multisite
  • Wrap custom fields database statements in a transaction.
  • Don’t rescue PG::UniqueViolation within a transaction.
  • Discourse script didn’t allow backups with paths anymore
  • Mbox importer and rake task were broken
  • Use topic summary for meta description if topic excerpt is blank
  • Closing an empty fullscreen composer with toggler prevents scrolling
  • Support for local-date email preview without time attribute
  • Do not set null value to remove cookie
  • Clear color scheme cache when clearing theme cache
  • Force enable a user’s email_private_messages option when user replies via email (#6478)
  • Do not award badges for links in restricted categories. (#6492)
  • Reduce amount of work onceoff does
  • SSO provider secrets - check wildcard domains last, toggle secrets visibility
  • Can’t clean a tag if the given string is frozen.
  • Remove code that restricted “header” theme field from admin
  • Keep emoji syntax for custom emojis in quotes (#6488)
  • Don’t show empty user stats in the card when profile is hidden
  • Make time attribute as optional for local-dates bbcode
  • Do not allow revoking the token of current session. (#6472)
  • Email preview content not updated in second local date
  • Error looking at users in admin when tl3_promotion_min_duration is set to a very high value
  • Typo, should be authentication
  • Do not use force timezone value in display timezone
  • Don’t reply to Unsubscribe email sent to mailing list mirror
  • Groups list does not refresh when query changes. (#6481)
  • Allow theme edit route name to be overridden
  • Fix open quote links in new window. (#6477)
  • Properly escape name of custom emoji
  • Strip null bytes in mail subjects.
  • Multiple loadScript to the same url may resolve prematurely (#6474)
  • Do not add lightbox to onebox images (#6479)
  • ‘none’ tag page would not load
  • Generate Onebox for posts of type moderator_action. (#6466)
  • upload:migrate_to_s3 rake task not remapping properly.
  • When associating Github account disassociate others
  • Maxmind download task does not need environment
  • Make error in Discourse Hub more descriptive. (#6438)
  • Add missing variable in params
  • Add missing param for import_theme method
  • Add missing space to scss style
  • Add missing div start tag
  • Allow_uppercase_posts didn’t work for topic titles
  • Adds a title attribute on value list input (#6463)
  • Raise if staged user creation failed (#6461)
  • Convert tag string to array when filtering topic list by tags
  • Safari issue with some emojis (#6456)
  • Display large/broken image placeholders for image oneboxes
  • Topic admin menu was clipped on short posts due to overflow hidden
  • Redirect users to top when latest is the homepage
  • Generate webhook payloads before destroy events (#6325)
  • Stop logging every time invalid params are sent
  • Redirect users to SSO client URL after social login
  • Retry sending email in case of temporary issue. (#6375)
  • Correctly censor strings starting or ending with non-word characters (#6445)
  • Avoid redirection when not leaving forum. (#6419)
  • No longer educate users who are editing
  • Edit checks for editing posts with no topic
  • Display errors in single theme pages (#6449)
  • Move overflow from cooked to parent element to allow for slight overflow of blur/italic/shadow
  • Limit concurrent assets:precompile to number of available cores.
  • unicorn_launcher should shut down unicorn gracefully.
  • Keep files in order when adding multiple uploads (#6306)
  • Recover public actions (likes) when recovering a post (#6412)
  • Corrects typo and adds a spec for likes report (#6439)
  • s3BaseUrl with small s
  • Sync client & server rules regarding tag names. (#6400)
  • Force enable user PM emails option when user posts to a group by email.
  • Don’t send multiple requests when changing category notification (#6435)
  • Async reload of locales could result in missing translations
  • Hide Delete Category button while creating a new category
  • Onceoff job to fix missing user profile backgrounds.
  • Close data-preloaded div tag
  • Don’t update user_profile URLs unless upload is persisted.
  • Dashboard test depended on the last month has 31 days
  • Advanced search ordering broken when using tags
  • Correct compilation issues on clang 10
  • Corrected copy on post_edit_time_limit site setting
  • Validate auto_close_hours category setting
  • Make theme import’s public key field readonly (#6424)
  • Links in TL1 promotion system message for subfolder installs
  • Links in narrative bot messages for subfolder installs
  • Do not revise post if post revision is not present
  • Improved category merging in discourse_merger. Use full paths to look for uniqueness instead of category names.
  • Don’t try to recover an invalid sha1.
  • Correct readonly timeout
  • Avoid race condition when enqueuing job.
  • Do not send tl1 welcome message when a user has the basic user badge
  • Always unpause Sidekiq after backup and restore
  • Backup logs were usually missing the first few lines
  • Use a tmp file in UploadRecovery for local store.
  • In redis readonly raise an exception from DistributedMutex
  • User correct steam placeholder image url
  • UploadRecovery should look at links too.
  • Ensures onSelect/onDeselect are called
  • Do not treat ignore_redirects domains as blacklisted
  • Moving upload to tombstone should update modification time.
  • Tag groups page should only be visible to staff
  • Error because last_id is nil in discourse_merger script
  • Improves themes/components UI on mobile
  • Allowes forcing timezone displayed in local-dates
  • Permit unpinning an unlisted topic.
  • Error in response body to blocked crawlers, showing 500 Internal Server Error with status of 403
  • Don’t block api requests when whitelisted_crawler_user_agents is set
  • Poll modal date selector width
  • Correctly keep stylesheet cache entries
  • Onceoff job to recover missing post uploads.
  • Don’t index urls to local files
  • Ensures errors in report initialization fail nicely (#6392)
  • Ensures we have a color for reports (#6396)
  • Treats users_(by_type|tl) as other reports (#6391)
  • Update PG gem
  • Ignore and log bad json values for custom fields
  • Do not try to recover invalid Upload#short_url in UploadRecovery.
  • Remove div used to measure textarea position
  • Allows forcing unsafe string in select-kit (#6386)
  • Uploads not being linked correctly to posts.
  • Display a correct error when attempting to agree on a deferred flag
  • Use current user color scheme when filling theme-color attribute (#6384)
  • Use current user color scheme when filling meta attribute theme-color
  • Rescue ActiveRecord::RecordInvalid in find_or_create_by_safe! (#6385)
  • “false” didn’t work as locale_default
  • Pop3 polling password and mailgun API key should be secret
7 « J'aime »
UX CHANGES
  • Badge checkmarks should be round
  • Overflow hidden was causing some icons to be cropped
  • Make button icons use lighter color instead of opacity
  • Add post action text in non-JS topic view
  • Do not prepend discourse to theme filename if it’s already there
  • Improves copy of various reports (#6950)
  • Bump up notification panel width to accommodate larger text
  • Improve global notice description
  • Change topic reminder notification icon
  • Removes width constraint in user-card badge section
  • Use solid circle to indicate selected option in polls
  • Protection for very wide category-logo images on narrow screens
  • Removes margins from categories in suggested topics message
  • Admin badge page improvements
  • Improving aligment within topic timer modal
  • Invert pikaday png for dark themes
  • We don’t have bulk select on mobile, so we should hide the button
  • Improve button alignment, fix invite header
  • Improve alignment of new post badge on mobile
  • Correct innacurate descriptions for short_title, pwa_config_title_warning
  • Remove unused translations (#6885)
  • Improving user stream alignment and spacing
  • Badge alignment adjustments
  • Bump up base font size 1px, add smaller text size option
  • Improve short_title SiteSetting description
  • Improve logo setting texts to hint that dimensions are a requirement (#6892)
  • Normalize all SiteSetting text dimensions to use the ‘512 × 512’ format
  • Larger/Largest font-sizes should be 1px larger on mobile
  • Soften dashboard warning PM
  • Soften the “problems” alert on dashboard
  • Improves dates display in emails (#6805)
  • Sort admins and moderators by last seen date on /about page
  • Only show active admins and moderators on /about page
  • Use generic label for S3-compatible storage provider
  • Better help text for private invite-only instance
  • Reducing usage of btn-small, simplifying styles
  • Don’t save automatically when resetting site settings in admin page.
  • Close button shouldn’t get :visited color
  • Always scope the composer categories dropdown to current category
  • Search all categories even if category-chooser is scoped to particular category
  • Use default H2 and H3 sizes on user profiles for better hierarchy
  • Tag container should wrap if there’s a large number of tags
  • Moves topic-list excerpts out of category / tag div
  • Default search log index to yearly.
  • No need for margin if participants is first-child
  • Display user and group cards over the small PM header
  • Improve PM small header alignment with recipient avatars
  • Excerpts don’t wrap on IE11 (#6847)
  • Update site setting description to match current function
  • Remove gray background from lighbox
  • Add group name next to PM recipient avatar
  • Show generic message when reloading ‘activation email resent’ page
  • Aligns categories and tags in topic lists
  • Header needs a bit of padding on narrow screens
  • Removes unnecessary margin in header tag wrapper
  • Improves help text for admin and wizard logo settings
  • Improves flags-status report (#6773)
  • New site setting to define activity metrics displayed on dashboard
  • Show lazy loaded images while they are downloading
  • Adds missing wizard icons
  • Switch placeholder to an SSH url if importing a private theme
  • Adding reports dashboard tab, new layout, report descriptions (#6790)
  • Use new FA5 icons on Backups tab
  • Change default date range of dashboard trending search report to a month
  • Improve dashboard report title copy
  • Removes superfluous posters column header (#6765)
  • Increase selector specificity so that “inline” lightboxes in quotes don’t get backgrounds
  • Fix cropped image thumbnails
  • Reduce show dismiss.. at top of unread/new to 15
  • More consistent category lock and topic-status styles
  • Add styling for updated twitter status icons in onebox
  • Globally dim categories slightly
  • When composer is minimized, let user open composer in regular size instead of full screen
  • Dim visited post info along with title
  • Add missing icons
  • Refactoring topic statuses for consistent icon sizes & colors
  • Make shared drafts behaviour consistent for non-staff users (#6734)
  • Improve code highlighting diffs for dark themes
  • Show smaller Emojis within some HTML elements
  • Moving categories under topic title in topic list, removing category column (#6731)
  • Wrap pre element.
  • Truncate long topic tiles to prevent badges and date from wrapping
  • Replace FA5 compress/expand icons
  • Do not restrict width of category image, only height
  • Strip class when link is not oneboxed due to site setting limits.
  • Use aspect ratio to calculate width and height precisely
  • Style group flair in /groups same as in topic avatars
  • Topic stats were hard to translate
  • Category images have no sizes (#6662)
  • Better handling of logo size
  • Add height attribute to logo on error pages
  • Ensure unstyled .btn-social elements have a contrasting background
  • Improving theme upload modal alignment, markup
  • Contain site setting uploads within the div.
  • More consistent category setting layout
  • Leave room for floated radio input on mobile
  • Fixes display issues in split to existing topic modal
  • Better related messages condensed layout
  • Shows a save changes for intermediate steps (#6612)
  • Improve category reordering functionality
  • Maintain aspect ratio of cropped image thumbnails
  • Don’t show 0 vote count in crawler or print view
  • Switch to neutral background color for image uploader in site settings.
  • Improve copy for tag upload
  • Condense layout when suggested and related messages are available
  • Use header top to calculate docking position
  • Minor tweaks to theme components selection UI (#6596)
  • Take custom markup into account when docking header
  • Improving group directory layout for small screens
  • Rename Most Disagreed Flaggers report to “User Flagging Ratio”
  • Inform users old dashboard is going to b removed (#6592)
  • Trash icon displaying when there is no upload take 2.
  • Trash icon displaying when there is no upload.
  • Make long sign-up forms scrollable in modal
  • Make the edits indicator a real link for accessibility (#6570)
  • Adds new categories layouts to the wizard (#6569)
  • Minor copyedit.
  • Uses presentation role for accessibility in topic map (#6561)
  • Don’t show crawler navigation in print view (#6551)
  • Adds CSS classes to crawler navigation links
  • Hide crawler navigation in print view
  • Include subcategories in search result of all categories drop down
  • Updates category muting instructions
  • Remove “at” word from relative dates in local dates
  • Use latitude and longitude for more precision.
  • Use user locale for locations. (#6527)
  • Bumps the user-api-key version to 3 (#6526)
  • Make title on Instagram less redundant
  • Adding Google-compliant logo
  • Increase size of topic title tap target on mobile
  • Improve spacing on composer controls
  • Allow vertical timeline to fit on narrower screens
  • Show error when hitting the rate limit on password reset
  • Warn users if the post that’s currently edited has changed. (#6498)
  • Header items wrap on small screens for anon
  • Presence-users overlaps with composer toggles
  • Images should be responsive in embedded comments
  • Add link to Groups in admin dashboard. (#6480)
  • Site settings have immediate effect.
  • Make time attribute optional and set default timezones
  • Use dashed underline for local dates
  • Move Recently Used Devices to the bottom. (#6483)
  • Use local timezone for “Insert date” modal result
  • Use local timezone for insert date modal result
  • Do not show ‘Show more’ button if there aren’t more tokens.
  • Changes CSS class added to local dates
  • Prompt for custom invite message was hard to translate
  • Change staff actions logs user label
  • Use ‘trash’ icon instead of ‘times’ for deleting small actions
  • Disable button hover effects on touch devices
  • Category colorpicker restyle
  • Improve custom field layout on signup
  • Make responsive_post_image_sizes a visible site setting
  • When admin is deleted, make it clear in staff action logs when records belong to a deleted user and show their username in the details
  • Label of checkbox site setting needs a span for nested HTML
  • Slightly taller progress bar for mobile
  • Makes reports fade in when loading is done (#6440)
  • Improve error messages for minimum and maximum username lengths.
  • Confirmation before changing group membership in admin (#6426)
  • Remove flex basis from first item
  • Correct ordering of username / fullname in UX
  • Updating style of mobile navigation dropdown
  • Improve spacing & alignment for Category edit modal (#6432)
  • Improve shared_drafts_category description
  • Improve owner_groups text to fit combo-box in a single line
  • Improves topic-title flexbox alignment
  • Remove double scrollbars from backup logs
  • Removes bottom margins from inputs in admin controls
  • Ensure ac-wrap input height matches other inputs
  • Better padding for multi-select items
  • Label alignment for Firefox / IE
  • Select-kit filter input size fix
  • Radio / checkbox inputs margin fix
  • Last-seen input alignment fix
  • Multi-select items alignment fixes
  • General cleanup of inputs, buttons and select elements - part 1
  • Lighter style for category and tag dropdown nav
  • Improvements to admin theme UI
SECURITY CHANGES
  • Fix possible XSS with badges (#6912)
  • Escape title HTML for inline onebox
  • Users can pick non-avatar uploads.
  • User could non-avatar uploads.
  • Do not delete avatars uploads when deleting accounts
  • Require groups to be given when inviting to a restricted category. (#6715)
  • Enforce hostname to match discourse hostname
  • Update rack from 2.0.5 to 2.0.6
  • Add CSRF protections to OpenID callback
  • Update loofah for CVE-2018-16468
  • Only allow picking of avatars created by self (#6417)
  • Correct XSS on long topic titles
  • Remove admin memory diagnostics routes
PERFORMANCE
  • Add index on user_id to single_sign_on_records.
  • Delete potentially large associated tables before user_destroyer.destroy transaction
  • Bulk feature topic users & reset topic counters after an import
  • Delete user and post actions vs destroy on user destroy
  • Reduce workload when optimizing images
  • Run sidekiq with nice 5
  • Run ImageMagick conversions with nice 10
  • Index on topic_id for user_histories table
  • Remove image optimization throttling from Sidekiq
  • New ‘migrate_to_s3’ rake task
  • Automatic upload size calculation not persisted
  • Eradicate N+1 queries from the theme admin page
  • Use JSONP for SVG sprites so they are served from CDN
  • Move processing of inline onebox out of V8 context. (#6658)
  • Move mention lookups out of the V8 context. (#6640)
  • Fix N+1 for non-staff users when tagging is enabled.
  • Cache path for svg-sprite in upcoming FA5
  • Try to match users before groups.
  • Avoid left joins and distinct on posts_for query
  • Speed up migrate_to_s3 rake task.
  • Exclude tables when remapping in migrate_to_s3 rake task.
  • Reduce number of database queries for DbHelper.remap
  • Use mini_sql for the query
  • Avoid DNS lookups when getting IP info
  • Remove total unread notifications from message bus (#6529)
  • Limit unread count to 99 in blue circle
  • Limit unread count to 99 in the blue circle
  • User imports would slow down the more users were imported
  • Quit out of the email job quickly if disabled (#6423)
10 « J'aime »
