Discourse view file update does not reflect in browser
The discussion revolves around a user, hussain_anver, who wants to make changes to the Discourse UI, specifically on the category and login pages. They aim to add a floating button, change the placement of elements, and add images. fefrei suggests using CSS customizations and plugin outlets to achieve these changes.
Regarding the login functionality, hussain_anver wants to validate users from their own server before allowing them to log in to Discourse. fefrei and Mittineague point out that this can be achieved through Single Sign-On (SSO). hussain_anver provides more details and a diagram of their desired changes.
Additionally, hussain_anver asks how to use a REST API request from another server to add articles to the category page in Discourse. The discussion is ongoing, with fefrei reiterating the potential use of SSO for user validation.
Hello everyone
I have 2 questions
  1. I want to change come ui elements of discourse
  2. I am not able to figure out from where login modal is triggering (I want to change UI)
    • I tried to change view file
    • I tried to change .hbs file under assets
    • I tried to change js files under assets
    • I tried to change assets and js files under lib section
    • I tried to change the route file
but nothing is getting updated and also i am not able to figure out the modal popup location
any help would be appreciated
What do you want to change, exactly?
Most modification can be easily implemented as a CSS customization, which doesn’t require mucking with Discourse internals :slight_smile:
i want to change some html tags and placement of login and some other pages
That may be possible with CSS, depending on what exactly you want to do.
If you draw a mockup of what you want to have (an ugly Paint drawing based on a screenshot is fine!), one of the CSS wizards hanging around here will probably be able to help you out :slight_smile:
ok i want to change html elements for example in category page i want to add a floating button .
in login and signup page i need to add a logo and another image and want to also edit login function, (i want to add a rest api request to my server with login prompt)
Some of these changes may require adding elements to plugin outlets – here is the easiest way to do that:
How do you want to change login functionality, exactly?
This sounds like you might be interested in SSO:
ok thankyou but i want to keep a track of users in discourse also for som reason thats why i needed to add rest api,
and for category also i want to add a image and change placement like i want to add a floating button
Again, this sounds like you want to use CSS customizations and plugin outlets. Without a more detailed description or mockup of what you want to do, I’m afraid I cannot provide any additional help.
While this is quite vague, it sounds like what you want to build would be insecure. Depending on what exactly you want to accomplish, SSO, the Data Explorer or a custom plugin might help you, but we need a detailed description of what you want to have to help you.
for category i want to add a small image before each category name for ex
  • image/icon category-name topic-count
    description
for login i want to be validated the user from my server before login to discourse server
ex: if user enters email and password i want to send it to server if user existing in my server then continue discourse logins otherwise display message as user not existing
is this details give an idea what i want to do
i have also attached a small diagram what i want
If I’m understanding correctly, having an image for a category is already possible via the category create / edit modal.
The automatic switch is a good idea, but I don’t know how code would determine between an existing account that was a typo fail and a new non existing account.
This absolutely sounds like you want to implement SSO :slight_smile:
If i want to use a rest api request from another server how can i do that with discourse,
for example lets say if i want to add some articles from a different server which is using rest api and json to the category page in discourse
