Display an Image's alt or title attribute in ligthbox overlay
The discussion revolves around displaying an image’s alt or title attribute in the lightbox overlay instead of the original filename. ad-si suggests this change, as filenames can be unhelpful and cannot be changed later due to database constraints. Johani explains that a recent update (PR #8286 and PR #8291) allows users to change the text displayed in the overlay by editing the markdown code. Specifically, users can now replace fileName with their desired text or add a title using Markdown syntax (![image alt|690x380](upload://... "image title")). If no title is provided, the image’s alt text will be used as a fallback before defaulting to the filename.
Instead of displaying the original filename the lightbox overlay should display the alt tag and/or the title tag of the image.
35Z
The image name is often not useful at all. (E.g. something like shutterstock_1073920454325.jpg.) Futhermore the filename can’t even be changed later, since a new filename isn’t accepted, as an image already exists in the database using the same SHA1.
There’s a bit of a long story here. You can read the description of the PRs if you’re interested in learning more. Per
https://github.com/discourse/discourse/pull/8286
and
https://github.com/discourse/discourse/pull/8291
If you’re on the latest, you should now be able to change the text that shows in the overlay in the editor
When you upload an image, you’ll get this
![fileName|690x380](upload://zX6AuAdsNWYzcfIT08zVQPgaJbD.png)
You can edit fileName to whatever you want the image overlay to show.
A quick note:
This was always possible but would have required you to know how markdown handles titles
The way to add a title in markdown looks like this
![image alt|690x380](upload://zX6AuAdsNWYzcfIT08zVQPgaJbD.png "image title")
Given that not many people know about this, the first PR above adds the image alt as a fallback before defaulting to the file name. It being a fallback means that if a title is there, then it’s respected, if not, we use the alt.
This topic was automatically closed after 22 hours. New replies are no longer allowed.
