Sorry for restarting an old thread. But my question is can you use Discourse in a main directory? e.g. example.com (I have it like this)? Because there are images which are not showing up because they are using the url (http://discourse.example.com/blah/blah).
Sounds like you have your hostname improperly defined then… (in your app.yml – make sure you do a ./launcher rebuild app after changing it)
Awesome! I’ve changed it just don’t know how to rebuild it because I enter it and it just keeps creating a new line lol
you should be in /var/discourse and then run that command, be sure to have the entire command
Yes, you need to press CTRL + X to exit, it will ask you about saving.
I’m getting permission denied, so now I believe I need to change the file permissions, how and what do I change them to?
No, just use sudo.
sudo nano containers/app.yml (save your changes)
sudo ./launcher rebuild app
That worked! Thank you
