I cannot find site_settings.yml to adjust my instance rate limits?
Hey, you need to edit your app.yml
config file, see the guide here: Available settings for global rate limits and throttling.
So I tried setting the rate limits extremely high and still the USER API rate limits are triggering only with a few actions.
Here is my app.yml values:
Where can I find all the logs for all rate limits so I can see which rate limit is being triggered, if it is on Discourses end or Cloudflare tunnel end? Any help is appreciatied!
Below it will let me click through a few things but then after a few actions it will error out(see images below):
The errors above only happen when I am logged in. If I am not logged in then there is no limit at all, I can do anything and view as many profiles and stuff as fast as possible without any errors. When I log in and authorize access with user API key then it starts limiting after like a few actions
First, make sure you properly indent the lines.
It should be at the same level as the # character.
Otherwise, there is a chance it won’t work.
Yes I just noticed that; it is rebuilding now. Stand by and will provide update
