OS: Ubuntu 14.04
Setup: AWS, EC2 with Ubuntu 14.04, Redis on ElastiCache, and PostgreSQL on RDS
Docker version: 1.10.1
Error Message:
root@ip-10-0-3-99:/var/discourse# ./launcher bootstrap web_only
cd /pups && git pull && /pups/bin/pups --stdin
docker: Error response from daemon: Could not get container for data.
See '/usr/bin/docker run --help'.
cat: cids/web_only_bootstrap.cid: No such file or directory
docker: "rm" requires a minimum of 1 argument.
See '/usr/bin/docker rm --help'.
Usage: docker rm [OPTIONS] CONTAINER [CONTAINER...]
Remove one or more containers
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
I think that happens when trying to bootstrap the app in multi-container mode (i.e. not using the standalone.yml config but the web_only.yml and data.yml or any other config which doesn’t setup database and webapp in the same container.
After bootstrapping the container with the database (e.g. ./launcher bootstrap data), you have to start the database container before you can bootstrap the web container (e.g. ./launcher start data before ./launcher bootstrap web_only).
If there is no database access when bootstrapping the web app, you get this (rather hard to understand) error message.
