Hi guys,
First post here, sadly it’s regarding support. Docker seems to use my /root partition which is only 20 GB and the rest of my 2TB drive is on /home.
root@legio:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 20G 8.3G 9.9G 46% /
devtmpfs 7.8G 0 7.8G 0% /dev
tmpfs 7.8G 4.0K 7.8G 1% /dev/shm
tmpfs 7.8G 394M 7.4G 5% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup
/dev/md2 487M 25M 433M 6% /boot
/dev/md4 1.8T 51G 1.7T 3% /home
overlay 20G 8.3G 9.9G 46% /var/lib/docker/overlay2/aa30e247cdd1f95098ce909f333aae8a968b431c07856f242614528d6e2490c3/merged
shm 64M 4.0K 64M 1% /var/lib/docker/containers/201cd5c089c15b57b38fc94b3331212494d0a9514ea6ca51ec88bbcacce0cf0a/shm
overlay 20G 8.3G 9.9G 46% /var/lib/docker/overlay2/d249b6017bcfdae9742caed4402fe02936b1ddb55eb5178504d161061d49f178/merged
shm 64M 0 64M 0% /var/lib/docker/containers/0b11fcac390be8525e451bf00270916063c7da519c368e170c49f5f741c1b425/shm
Can you let me know of any way I can make use of more space without having to resize partitions? It’s risky business while they’re mounted and data loss isn’t something anyone likes to deal with.
Running Debian 9.1 stable on a dedicated machine.
Any help will be appreciated.
Do we have a howto for this @techapj ? That is, configuring Discourse to use another drive for the high storage requirement items like the database, file/image uploads, backups, etc?
That would be the easiest solution, yeah.
dax
(Daniela)
3 Septiembre, 2017 23:48
4
This topic, though related to digital ocean block storage, can help you at least for uploads:
The man makes a point. It appears to be less than 1/3 the speed on the simplest of benchmarks. (I checked and both the host and the storage are at SFO2.)
root#:dd if=/dev/zero of=/tmp/output conv=fdatasync bs=384k count=1k
1024+0 records in
1024+0 records out
402653184 bytes (403 MB, 384 MiB) copied, 0.590498 s, 682 MB/s
root#:dd if=/dev/zero of=/mnt/volume-sfo2-01/test conv=fdatasync bs=384k count=1k
1024+0 records in
1024+0 records out
402653184 bytes (403 MB, 384 MiB) copied, 1.99937 s, 201…
You should read all the topic, there are pros and cons.
Creating symlinks doesn’t seem like a very good way in my opinion, it’s too workaround-y. Lets see what @codinghorror and @techAPJ will come up with.
techAPJ
(Arpit Jalan)
4 Septiembre, 2017 10:28
6
There is no howto for this as of now, added on my list to look into it and write one.
Thanks! The 20 gigs I have should be sufficient for now but it’ll be useful.
sam
(Sam Saffron)
13 Octubre, 2017 05:07
8
I did this for free codecamp:
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
- volume:
host: /var/postgres_data
guest: /shared/postgres_data
Basically I keep /var/postgres_data in root and then mount /var/discourse/shared/ on the second volume, additionally I put docker containers in /var/discourse/shared/docker
There are many ways of skinning this, just keep postgres_data on the fastest drive and you should be good.
thabbs
(Thomas Abraham)
13 Octubre, 2017 17:04
9
Another solution on OS level can be to mount /var/lib/docker on a dedicated partition.
To do this, please, stop Docker, make sure that no process accesses /var/lib/docker and do the following:
Provide an additional volume. In this example it is /dev/sdx8.
Format it accordingly, i.e.
mkfs.xfs -n ftype=1 /dev/sdx8
or
mkfs.ext4 /dev/sdx8
etc.
If it fails in mkfs.xfs you might run a newer version of mkfs.xfs which has ftype=1 already as default. Just issue
mkfs.xfs /dev/sdx8
Stop Docker.
service docker stop
Make sure the directory is not used anymore:
lsof | grep /var/lib/docker
Prepare directories and mount the new volume:
mv /var/lib/docker /var/lib/__docker
mkdir /var/lib/docker
mount /dev/sdx8 /var/lib/docker
Move all contents there to:
rsync -aH /var/lib/__docker/ /var/lib/docker
# mind the trailing slash. It takes care to copy the whole tree to the right position.
Don’t forget to add /dev/sdx8 to /etc/fstab.
Remove the old directory if everything is fine.
rm -rf /var/lib/__docker
If following the above guide, as a semi-newb, let me know if I got this right:
Assume mounted volume is at /mnt/someVolume/
Make an empty dir at mnt vol?
mkdir /mnt/someVolume/discourse/shared/
When you say ‘mount’, do you mean symlink ?
ln -s /mnt/someVolume/discourse/shared /var/discourse/shared
Edit /var/discourse/containers/app.yaml …
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
- volume: #KEEP THE SAME, right?
move docker containers?
mv /var/discourse/containers /mnt/someVolume/discourse/shared/containers
Then maybe stop/start again? Do I need to rebuild? Anything missing or need correcting?
sam
(Sam Saffron)
23 Noviembre, 2017 19:28
11
This stuff is messy, I recommend you create a test droplet and try it out there, it’s the easiest way to answer all questions with zero risk
Does this mean my summary interpretation is also on the right track?
I’m not sure if a test droplet is the best way to go, in my case. The IPs will be different, I’d have to setup a new host, and even if I did all that, nginx would be completely off… I’m pretty sure this would be even-more confusing. I’d probably be better off just making a backup before I change anything.
About to try this on a fresh install. I’ll report back.
Okay, this is my /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
/dev/md3 / ext4 errors=remount-ro,relatime 0 1
/dev/md2 /boot ext4 errors=remount-ro,relatime 0 1
/dev/md4 /home ext4 defaults,relatime 1 2
/dev/sda5 swap swap defaults 0 0
/dev/sdb5 swap swap defaults 0 0
proc /proc proc defaults 0 0
sysfs /sys sysfs defaults 0 0
tmpfs /dev/shm tmpfs defaults 0 0
devpts /dev/pts devpts defaults 0 0
When I do mkfs.ext4 /dev/sdx8 do I have to do it to /dev/md4? It’s my biggest partition.
Thanks.
techAPJ
(Arpit Jalan)
6 Junio, 2018 17:39
15
Based on @sam ’s suggestion I spun up a new droplet → installed Discourse → added a block storage volume → moved uploads and backups to that volume. Everything worked out fine. Here is the howto:
