Does DMenu work in Modals?
A search TextField when nested inside a DMenu and DropdownMenu, doesn’t seem to work in Modals.
It works fine on a normal page, e.g. profile settings, but when placed on a Modal the TextField doesn’t seem to respond to typing.
Is this because DMenu is using a portal and there is some problem with its relationship with the modal div?
Here’s an example:
Simply put, if I place a debugger statement on the search action, I can show that when placed in a Modal, you never arrive at the search function, but on a “normal” page (outside of a Modal), the event will fire correctly and the search is started.
You cant even type, even if I remove the event hooks.
If I place the TextField in this component outside of the DMenu (still accessed on a modal)- typing behaves as normal.
What am I missing, and why does the behaviour change?
Yes I think so, the portal is located outside of the modal and our focus management might be getting in the way (modals capture focus)… does adding @inline={{true}} to the DMenu fix it? that will put the menu directly within the modal.
Sorry for slow response and appreciate your comment - I did try that but not sure it’s supported for DMenu :thinking: ?
I ended up building a nasty override to implement it (and would be delighted to be able to remove that code)
