Don't show enable css check box
Hello, My Version discourse is v2.0.0.beta1 +4, and i can’t see box to check enable Css in customize tab
Before i see this box but now is not. How can i see it? Thank you!
If you mean this:
It may be because your custom theme is set as a child theme under the “Default” theme.
Which makes it automatically enabled if its parent theme or “Default” is enabled.
You should check the list of theme components in the “Default theme”
i Did it, i check enable by default
thank @lll
