I’ve noticed many times that when connecting on Discourse via a mobile device suffering from a intermittent/bad internet connection, the user may post the same content twice. For the user, it’s as if he or she had posted only once, given that the console only closes once, thus displaying only one acknowledgement client-side.
Probably no-one is encountering this problem since the default “unique posts mins” and “rate limit create post” settings should prevent it from happening most of the time. I’ve set mine to 0 and 1 sec, respectively, for reasons I will not explain. However, I’m not even sure that setting this to a higher value will be enough if for instance the user modifies his/her post in-between “post failures”, and waits enough seconds to repost after some unpredictable timeout. Bottom-line, I’m not sure how and why this actually happens and little do I know about the current implementation, but I would like to know if anyone else has encountered this issue. I’m actually not comfortable with the idea that tuning a parameter is the only way to fix this problem.
If somebody else has encountered this problem with the default settings it would be nice to have a feature to prevent this happening that would be based on some unique client-side id generated for each post/topic that the user creates, thus not requiring rate-limiting workarounds. I realize my settings are quite rare, but I also think that a difference should be made between rate-limiting features and a double-post prevention feature. Nonetheless I also understand that such a feature might be hard to pull off properly, without too many side-effects, and might not be worth the effort.
