Download backup with `curl` or `wget`
The discussion revolves around downloading a backup using curl or wget without SSH access. pfaffman initially asks for help, having trouble using curl due to redirects. michaeld shares a script that might solve the issue. However, Stephen suggests using SCP server-to-server, which is not feasible in this case due to the lack of SSH access, as clarified by pfaffman. Isambard faces a similar problem, complicated by email providers mangling the link. michaeld mentions that logging in is still required for the link to work, and Isambard asks about a simple way to log in via the command line before issuing the wget command. michaeld suggests trying the script shared earlier.
I occasionally have need to download a backup from an instance where I can’t ssh. Pulling 2GB down over my home internet connection where speedtest.net claims I get almost 500Mbps down isn’t that painful, but pushing it back up a 20Mbps is.
I thought that I might be able to use curl and pass an API key to download the backup, but what it gets is a redirect in an HTML document, and trying that URL in curl ends in a “bad request.”
Is there some way to do this that I’m missing?
Yeah, sounds familiar. I made this a few years ago. Haven’t used it in a while though so I’m not sure if it still works without modifications.
Wow! My dreams (maybe) answered! Thanks, Michael. I guess I should have searched a bit harder.
Why not just SCP server to server?
It uses SSH, will allow transfers that don’t hit your local line, and is already present on every host.
There exist Discourse instances on the planet where I have admin access, but not SSH/SCP access. :wink:
I just had this problem too trying to pull a backup from a machine that was not my machine (so no SSH access). It was further complicated as I use Brevo as the email provider and they mangle the link to redirect to their own server for tracking.
For the backup emails, it might be useful to explicitly show the full URL and token instead of hiding it in the a href which can be overritten by email providers.
You will still need to login otherwise the link won’t work either.
Is there a simple way to ‘login’ via the commandline of a remote machine before issuing the wget to download the backup?
Did you try my script in the second post?
