Gedownloade bekeken woorden voor automatische tagging exporteren geen overeenkomende tags niet
The “Download” button for watched words does not currently export the mapping to tags, and its format is not documented. bigfudge suggests that the download should be a CSV file with two columns: “word” and “tags”, with tags separated by commas or semicolons, to match the upload format. sam agrees that this is an oversight and suggests assigning the task. The issue has been addressed, and nbianca notes that watched word imports and exports have been improved by switching to CSV format, allowing for two columns, in a pull request.
I have a few watch words set up to be auto-tagged.
In the UI for this feature there is a ‘Download’ button which produces a list of the watched words, but not the mapping to tags.
Relatedly, as far as I can tell there is no documentation for the appropriate format for the “Add from file” button.
I wonder if the download should be a csv file with two columns: “word” and “tags”? Tags could be comma or semicolon separated.
It would be ideal if the download format matched the upload format — that way it’s at least partially auto-documenting.
This sounds like a bit of an oversight, @zogstrip maybe we should assign this out?
@nbianca can you add that to your list?
We improved watched word imports and exports by switching to CSV format. This allows having two columns, one for the word and the other one for the tags.
https://github.com/discourse/discourse/pull/12444
This topic was automatically closed after 2 days. New replies are no longer allowed.
