For some reason, the dropdown box for the solved & unsolved post filter became wider. This only happened recently.
I dont know why you deleted your post.
But this was indeed an issue. I solved a similar one in https://github.com/discourse/discourse-topic-status-filter and forgot this plugin.
That should fix it:
https://github.com/discourse/discourse-solved/commit/26d247e3d7c9b43e77b87d0a3253905e64de8f9e
Thanks.
Oh, I see. I was doing tests to see if it was caused by a plugin or vanilla discourse. Turns out I didn’t test very thoroughly. Thanks for telling me.
