Dscourse aws EC2 G Suite troubleshoting
(Andrey Prisniak) #1
I’ve fresh installation of discourse on amazon EC2 instance and have been configured SMTP with G suite corporate account. But can’t finish initial settings because of SMTP. I’ve tried different smtp settings but with no success.
DISCOURSE_SMTP_ADDRESS: smtp.gmail.com
DISCOURSE_SMTP_PORT: 465
DISCOURSE_SMTP_USER_NAME: my@corporate.email
DISCOURSE_SMTP_PASSWORD: "mypassword"
DISCOURSE_SMTP_ENABLE_START_TLS: true
This is my final settings.
And I’ve read a lot of topics on discourse forum but haven’t solution. Please help.
https://meta.discourse.org/t/anyone-using-gmail-for-smtp/41371
(Jeff Atwood) #2
I suggest the official email troubleshooting #howto.
Also if you read that topic you’d see
Not entirely sure what you’re asking – you mean in the context of that error? Yes, the G Suite (neé Google Apps) domain is custom, not @gmail.com.
So if your SMTP_ADDRESS is gmail.com that already seems wrong. You should be using your actual domain there, as configured in G suite.
https://support.google.com/a/answer/176600?hl=en
Or per the above, smtp-relay.gmail.com maybe?
(Andrey Prisniak) #3
Thx Jeff, I’ve configured SMPT as it shown in google instructions. And I’ve also try smtp-relay.gmail.com and smtp.gmail.com ports 465, 587.
My email not a ****@gmail.com. I’m using exact my G Suite email account.
So, finally I did it!
DISCOURSE_SMTP_PORT: 465 → And I’ve also changed port to 587
DISCOURSE_SMTP_PASSWORD: “mypassword” ← error here. I’ve removed quotes and all works just fine.
By the way quotes where added while bootstrapping.
Thx for reply
