Trying to get discourse up and running I used gmail for the SMTP mentoned in app.yml. A feature of gmail is allowing this according to this article. It doesn’t work. My settings are something like this (I changed my email and pw).
DISCOURSE_DEVELOPER_EMAILS: 'myemail@gmail.com'
DISCOURSE_HOSTNAME: 'localhost'
## TODO: The mailserver this Discourse instance will use
DISCOURSE_SMTP_ADDRESS: smtp.gmail.com
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: myemail@gmail.com
DISCOURSE_SMTP_PASSWORD: thepassword
DISCOURSE_SMTP_ENABLE_START_TLS: true
Pretty sure the terms and conditions of Google would disallow you from using GMail as an SMTP endpoint. You are probably risking freezing your account or something. Plenty of free options for an smtp service … https://sendgrid.com and for local dev you would just use mailcatcher.
@clay, we have used a google for work email account setup for discourse with minimal issues. our reply via email works smoothly. I see they just renamed g suite
