Problem with SMTP configuration
Hi!
I went through most of the “SMTP problems” threads but still cannot solve my problem.
Ubuntu in AWS EC2, fresh Discourse installation, can’t receive confirmation email.
Current configuration:
DISCOURSE_SMTP_ADDRESS: smtp.motomirko.pl
DISCOURSE_SMTP_PORT: 465
DISCOURSE_SMTP_USER_NAME: admin@motomirko.pl
DISCOURSE_SMTP_PASSWORD: secretplainpassword
DISCOURSE_SMTP_ENABLE_START_TLS: true
I can telnet to smtp.motomirko.pl 465 from instance, connection is ok.
I test my mail server with setting outlook client, and there I saw the problem. When connection was set only to TLS than it was refused, when I set to SSL than connection was successful.
I’m not really sure is it helpful.
Dump from logs : [Bash] Started POST "/finish-installation/register" for 87.206.151.152 at 2017-07-09 14 - Pastebin.com
Please help!
Cheers!
Port 465 was, many years ago, SMTP over SSL/TLS – it doesn’t use STARTTLS. I say “was”, because it’s been deprecated for so many years that the IETF has deregistered smtps as a protocol. You should use either port 25 (SMTP) or port 587 (submission) and STARTTLS.
Yeah, you’re absolutely right, I moved from my old provier to gmail, and now everything works like a charm! Thanks!
Gmail is not recommended as it has limits for outbound mail. Check out MailGun - it is very straight forward to setup.
I hope it’s ok to bump instead of creating a new topic. My host only has smtps (465/ssl) available and I can’t seem to get it to work.
  DISCOURSE_SMTP_ADDRESS: mail.myprovider.com
  DISCOURSE_SMTP_PORT: 465  # smtps/ssl
#  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: login@mydomain.com
  DISCOURSE_SMTP_PASSWORD: "PASSWORD"
  DISCOURSE_SMTP_ENABLE_START_TLS: false           # (optional, default true)
These settings work in Thunderbird. Is smtps not supported or am I doing something wrong? Maybe I need to connect to mail.mydomain.com where a valid ssl cert is installed?
So my solution was first to switch to Gmail, but when google started making me problems (limits…) than i switched to MailGun like @ljpp suggested (thanks man it’s great!). I think that’s not possible to force discourse to use 465 anymore.
Thank you. I’ve signed up for SparkPost as I don’t want to change hosts for my mail. They give you 100 mails per day without verifying your mail, 500 if you do and 10.000 if you add your credit card details. Not too bad.
2018 年 1 月的一份 IETF RFC 建议将端口 465 用于“隐式”TLS。此举的动机之一是强制加密的趋势日益增强,这使得 STARTTLS 显得有些多余。RFC 8314 - Cleartext Considered Obsolete: Use of Transport Layer Security (TLS) for Email Submission and Access
你好,我在配置 Discourse SMTP 时遇到了问题。
我在 AWS EC2 上安装了 Bitnami 的 Discourse 镜像,
我按照这些说明和清单操作了,但没有任何效果。有什么建议吗?非常感谢!
说明
https://docs.bitnami.com/bch/apps/discourse/configuration/configure-smtp/
清单
Bitnami 未获得官方支持,如需支持,请直接联系 Bitnami。
好的,谢谢告知。
仍然无法正常工作。465 端口超时,587、25、2525 端口要求邮件必须使用 SSL 或 TLS 加密。我已尝试与以下公共邮件服务的所有可能组合:
你成功了吗?
我终于让它奏效了,Yandex 的问题在于 DISCOURSE_NOTIFICATION_EMAIL 应该与 DISCOURSE_SMTP_USER_NAME 相同。
