Easy install fails on AWS EC2 + Ubuntu 14.04
I followed the 30 min installation instructions on Ubuntu 14.04 on AWS EC2 and the webserver is not started like the instructions say it should be. I am expecting the server to listen on port 80, but curling returns an empty result, curl 127.0.01. I also tried:
  • curling the domain I used during setup, which says connection reset by peer
  • curling the IP address which the installation log says the docker image is running on, “172.17.0.1”, and it says connection refused.
Here is a dump of the installation log: Discourse Installation Log · GitHub
The Docker host IP is 172.17.0.1; the container’s IP address will most likely be 172.17.0.2, but you should confirm that with docker inspect app | grep IPAddress.
Thanks for the response, Matt.
I determined that NGINX was failing to start because it can’t find the SSL cert from Letsencrypt. Letsencrypt was failing because I was using Cloudflare as my nameserver, which I now know interferes with Letsencrypt. I disabled the SSL template in my app.yml and rebuilt, and viola! NGINX was alive and well.
Hope this helps someone else, too.
Hey, @tgxworld. Can or should the let’s script template check for people using cloud flare?
Maybe even better would be having better fault tolerance and/or warnings for when Let’s Encrypt fails.
