Hey all,
I’ve tried running both: /containers/app.yml and ./discourse-setup to fix my SMTP username but neither seem to work for me
and instead send me to the attached error page.What am I doing wrong?
Hey all,
Those are command-line paths, not HTTP resource paths.
I had tried it in terminal and got the “no directory message” so I assumed it was a path in browser, sorry ![]()
Would you happen to know which directory I’m meant to run that command in?
/var/discourse, of course. Note that there is no leading slash on containers/app.yml, and that ./discourse-setup is meant to be run, not edited.
I’ve opened terminal, run /var/discourse and again “no directory”
Do I need to cd into anything beforehand? Sorry
How did you install discourse?
Those instructions have you
cd /var/discourse
./discourse-setup
Unless you did something else to install
I used the DO tutorial: https://www.digitalocean.com/community/tutorials/how-to-use-the-discourse-one-click-application-on-digitalocean
I don’t recall ever cd’ing into /var/discourse
Either search here for the install instructions or all digital Ocean for help.
@tyraniczar I believe the DO one-click install uses Docker containers. Does this thread https://meta.discourse.org/t/how-do-i-change-my-smtp-settings-discourse-docker-install/20067 help you out? I don’t have an instance setup on DO at the moment to try it myself.
note: always make sure you create a snapshot of your droplet before playing with any settings so you have something to revert to if things go wrong ![]()
Nothing has worked so far. Opened a ticket with DO
What version of discourse do you have installed? I am new to Discourse (using Meta to learn it better
), but not to DO - I’ve been using them for a couple of years. I might be able to find a couple minutes on my lunch to spin up a Discourse droplet and see if I can help you figure it out.
I’m on 2.1.0.beta2 but there’s really no need to waste your lunch on this lol. I was able to access the Ubuntu server via ssh and I ran ./discourse-setup and changed the username but my emails still aren’t being delivered. I guess there’s another issue. Attached is a screenshot of my email config. Is anything missing/incorrect?
Not a waste, curious at heart. But sounds like you are having a different issue than I thought. While I assume you have already found it - it looks like Connecting Mailgun with Digital Ocean deals with your exact combination of setup MailGun + Digital Ocean - though there is a bit to wade through in the discussion. My best guess is after changing the mail config you didn’t reload (./launcher rebuild app)?
edit: actually the last reply may be the most useful to you? Connecting Mailgun with Digital Ocean have you tried using port 2525?
Haha thanks, you are all super helpful. I’ve done the reload twice. I’ll try port 2525 next
Now that I’m not on my phone, I can say that discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub is what you should do to install.
It’s not clear that your port is being blocked, but I always install using port 2525 because Digital Ocean does block outgoing SMTP for lots of their clients and which ones and why is apparently a trade secret.
Thanks, I don’t know if re-installing it would work though. I’ve been able to access and edit my SMTP info via ssh and I ensured that its the same as what I’m using in Discourse. I’ve tried port 2525 and 587 but my emails still aren’t being delivered. Still waiting on ticket @ DO
Next is to check the mail logs of the mail service.
My logs @ Mailgun are empty lol.
Im thinking that the original problem was that my username credential in Discourse was the default user@example.com while the username credential in Mailgun was the correct one. The screenshot is from the tutorial you sent over. Could that have permanently broken email?
you need to run /discourse-setup located in the location where you have clones the discourse application for me I have clones it inr /var/disourse/ so I did
cd /var/discourse
/discourse-setup
this will stop the existing discourse container and then ask the new configuration once everything is set it will rebuild the application
