So it goes like this:
User A: Creates an ordinary topic.
Admin: Comes in to edit the topic by adding a Poll object to it.
Discourse: Freezes for ever, immediately after adding the poll.
Chrome: Eats all the memory there is to eat before suicide.
End result:
EDIT: by an admin adding a poll
zogstrip
(Régis HANOL)
Março 27, 2018, 1:57pm
Works fine here…
Do you know what poll the admin tried to add?
Do you know if there are any non-official plugins installed?
I cannot replicate it in my test environment.
Is there anything in your logs?
@mikechristopher @zogstrip
Found the issue it’s certainly a bug or limitation.
So the Poll plugin crashes without any warning and all Post changes are lost, if you try to add any float numbers to the numbers poll.
Like:
[poll type=number min=1 max=20 step=0.5 public=true]
[/poll]
It only crashes if step is float number! even in this forum too, can be replicated.
zogstrip
(Régis HANOL)
Março 27, 2018, 2:42pm
5
Let’s try it
[/poll]
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
@Yassine_Yousfi seems to be working here just fine…
Awkward!
It used to break! could it be breaking only on topics (first post) not in all posts!
Also noticed that in this discourse, it shows minimum step being 1, on mine not. and it broke for me when i was writing the topic as well!
jomaxro
(Joshua Rosenfeld)
Março 27, 2018, 7:33pm
7
Doesn’t crash on topics either. See https://try.discourse.org/t/testing-polls-with-float-steps/1030 (note that try resets daily so it won’t be there forever.
Somehow my discourse doesn’t auto update anymore, not even from the admin side! but it had an SSL issue and had to rebuild the app from ssh again. and now i got latest update!
And the error doesn’t seem to occur anymore
Thank you for your prompt replies guys!
Best
