downey
(Michael Downey)
18 Junio, 2015 15:55
1
A feature request from one of our users:
Write a post in the editor. Start with an introductory paragraph.
Click the ordered list (or unordered list) button.
Replace the highlighted “List item” text with your first list item.
Press enter to move to a new line.
The editor should pre-populate a second list item.
According to this user, this is how they expected the editor to behave (similar to Gmail and other editors).
7 Me gusta
+1 Feels weird having to do it manually
Would also be nice to select text that’s already got line breaks and click the button to make it a list (ie. to match the behaviour of the code and quote buttons)
4 Me gusta
Tom_Newsom:
Since I can’t like it again, I’ll just quote and say YES, PLEASE!
2 Me gusta
I suppose the difficulty comes with nested lists. Does clicking the button while lines are selected de-list the items, or indent them further?
1 me gusta
alttext
(Ben Edwards)
14 Agosto, 2015 21:25
5
I swear there used to be a key combo I could use to continue a list - something like option + return but that hasn’t worked in a while.
3 Me gusta
Jagster
(Jakke Flemming)
28 Octubre, 2024 06:51
7
Totalmente fuera de tema, pero eso arruinó mi vida como usuario de iPad
Para mí es más fácil recordar las marcas de lista como * que recordar cambiar a minúsculas al principio de cada fila; las listas rara vez son oraciones independientes, y si lo son, el primer elemento de la lista comienza de todos modos con una letra pequeña.
¿Problema con la primera palabra? Definitivamente sí
Moin
28 Octubre, 2024 06:55
8
Puedes desactivarlo en tus preferencias
I merged a user preference for this today:
Go to Preferences > Interface and uncheck “Enable smart lists when writing in the composer”. Also site admins can change the default for all users with the default_other_enable_smart_lists site setting.
4 Me gusta
Jagster
(Jakke Flemming)
28 Octubre, 2024 06:57
9
Me perdí esa opción por completo. ¡Gracias!
Y ahora el primer mundo es un lugar un poco mejor de nuevo.
Editar: excepto que no está en mi foro Tendré que empezar a investigar más y abrir un nuevo tema si es necesario.
Editar2: esa opción es relativamente nueva, quizás debería reconstruir primero. Parece que uno de esos días…
1 me gusta
