Editor too small on Galaxy S6 / Chrome in some languages
A discussion on the Editor size issue on Galaxy S6 using Chrome, particularly in certain languages, has been initiated. Lutz reported the issue, providing screenshots of the problem, where the editor window appears too small, almost unusable. codinghorror requested clarification and was unable to reproduce the issue on a Nexus 5.
Lutz explained that the issue can be reproduced by changing the interface language, showing that the editor window size increases when switching from German to English. This led codinghorror to suggest that the issue might be due to a longer translation for the “Save Edit” button, proposing a shorter translation or CSS limit on button width as solutions.
Lutz agreed to address the issue in the German translation thread, while codinghorror recommended fixing the issue in CSS to restrict width for all languages. Lutz will search for a shorter translation, acknowledging that German words can be lengthy.
I got some problem reports from users with Galaxy S6 and Chrome. This is how meta looks on a Galaxy S6 Chrome 56.0.2924.87. I put this under the bug category because this basically (almost) excludes S6 users from editing posts.
To get this view, the Edit button must be at the bottom of the screen.
If the button is more in the middle, it works. But the users do not know. I found it more by accident during the test.
I am not following this, can you explain?
I am not able to reproduce this on Nexus 5 and chrome 56. You must mean editing the first post only?
Of course, excuse the imprecise explanation. Unfortunately, I can not repore the effect now itself.
What can be reproduced: the very small editor window. . Less than one line. Is this perhaps a problem of German translation? Perhaps because the “save” button has two lines?
Yes, if I change the interface in English, I have three lines to edit, instead of one.
I do not know if this is still a bug, if it is because of a too long translation?
More of a translation issue, a shorter translation is needed for “Save Edit”
Another solution is to force a limit on button width with CSS.
1 лайк
Ok, I’ll take care of it in the german translation thread.
1 лайк
Might be better to fix in CSS for all languages by restricting width.
Well, that is true. I will still search for a shorter translation. Unfortunately, German words are always so long :slight_smile:
5 лайков
