Ellipsis button no longer visible for posts actions
Hi, the ellipsis button for post actions is no longer visible on my three Discourse sites. Shouldn’t they be visible if I have items in my “Post menu hidden items” setting ? Thanks.
Is it possible to send links to these forums? I can’t see this on Meta.
Yes see my settings below, so the Flag, Bookmark and Share buttons should be visible when we click the ellipsis button, but there is no ellipsis button to click, for example in that discussion.
Does it happen in safe mode? Perhaps a TC/plugin causing this.
Yes same thing in safe mode.
But the ellipsis icon appears on certains topics like this one : Usine désaffectée, par Titi95 - #11 by _Steven - AutoCAD - Dessein-Tech
Could you try to add bookmark, share, and flag also to the post menu? I think you add them to the menu with the first setting and move them to the ellipsis with the second.
Yes, that was that, didn’t realize they had to appear in both settings…
