Notifiche email per i post di un utente specifico
Hi,
One of my clients is looking to receive email notifications for posts made by me only. Is there a way to do this?
Thank you,
Scot
We don’t support watching individual users that way, though I would suggest they could consume your user’s RSS feed.
For example, https://meta.discourse.org/u/scot/activity.rss
Thank you Michael!
I was not aware of this option. I was able to add that link to http://ranchero.com/netnewswire/ and it worked great. My discourse is behind the login for my website so I think that might be causing an error with the newsreader. I am trying to figure out if I can add the login information for my website to the newsreader so it can read the feed. So far I am not having any luck :frowning:
If you’re a forum admin, you can generate an API key from the admin interface for the client’s account and add this link to the RSS reader instead:
https://discourse.example.com/u/scot/activity.rss?api_username=client_username&api_key=1234abcd
Make sure to generate a single-account admin API key and not an all-users key.
Be VERY CAREFUL doing this - both you and the user should understand that this API key represents credentials to BE that user and should be kept secure.
We do have a method for having the user create API keys and restricting scope on those… but I do not believe that is exposed in the UI.
As of Discourse 2.1, API keys auto-expire after ~6 months of non-use. Far from a complete solution but it does offer some general protection.
This is only the case for scoped “user API keys”, which are different from the global API keys in the admin panel.
As @supermathie said, there is no way to create user API keys from the user interface. I think they are only currently used for the mobile app.
Thanks for all the info guys. I really appreciate it.
